Sorry if I sound ignorant mates, but could someone explain the numbers?
Or basically, are they repackaged Eneloops?
Yeah, at some point we just need to sum up all the numbers and data. This goes for all these testing threads with pages of data.
Yes and summarize the findings after extracting all the info possible, preferably with graphs & formulas & best fit curves. Along with this there should be a clear idea of the goals of the data collection.
Doing this will provide insights into how better to collect data. It’s a feedback loop - data collection > summaries > goals > data collection.
Spreadsheets have some data reduction tools and I have notes from a stats course that give practical methods for reducing all types of engineering data: Student’s T table, tolerance limits to some confidence level, hypothesis testing, ANOVA and whatnot. These very tedious stat calculations are no problem for spreadsheets.
Bell-shaped curves, anyone?
Thus far, fancy stats are unwarranted. The initial discharge is of limited usefulness as I do not know when they were manufactured or charged though they were certainly manufactured after mid-2010 if they (As seems extremely likely) are rebadged Eneloops. What we’re really looking for here is consistency and hopefully consistency with real Eneloops. The 2G eneloops I have were charged in late May 2012 and have been untouched since - they were manufactured in March 2010. What I want to see is capacity over time and consistency.
So from the initial results we see a very good consistency in voltage - not really a surprise as voltage is not a useful indicator of charge in NiMH cells. But someone might have a use for the data.
The consistency in charge available to 1.000V under load with a span of 73mAh between the most and least charge - or in real world terms a variation of about 5%. My measurement errors may be greater than this, though I hope not.
Well, if they are nearly 3 years old and have 75% of there capacity left then I am impressed. I would also say that is a tick in the eneloop box.
So far so good.
Thanks for doing this Don,
Marc.
And so testing aged batteries is pretty useful. The battery makers must respond to market forces and so maybe their production line is changed somewhat every six months, maybe less often.
All 16 came off the charger between 1.450 and 1.455V so good consistency there.
First full cycle on 8 of them underway - results in the morning.
And so testing aged batteries is pretty useful - batteries that wear out soon is a hidden cost of ownership.
The battery makers must respond to market forces and so maybe their battery chemistry is changed somewhat every ~6 months.
I'm not too happy with the numbers on Run 2 thus far - looks like my charging regime isn't cramming in every ounce of charge it could. Cells 9-16 discharging just now.
Contour ?Gen 2 eneloops | |||||
Intial | Intial | Intial | |||
Voltage | Discharge | Charge | Run 1 | Run 2 | |
Cell 1 | 1.306 | 1,529 | 2,086 | 2,008 | |
Cell 2 | 1.306 | 1,538 | 2,094 | 2,019 | |
Cell 3 | 1.306 | 1,529 | 2,096 | 2,016 | |
Cell 4 | 1.307 | 1,498 | 2,070 | 1,986 | |
Cell 5 | 1.307 | 1,472 | 2,032 | 2,078 | |
Cell 6 | 1.307 | 1,486 | 2,043 | 2,091 | |
Cell 7 | 1.307 | 1,477 | 2,056 | 2,078 | |
Cell 8 | 1.307 | 1,459 | 2,006 | 1,900 | |
Cell 9 | 1.307 | 1,520 | 2,183 | 2,200 | |
Cell 10 | 1.308 | 1,529 | 2,244 | 2,253 | |
Cell 11 | 1.308 | 1,524 | 2,235 | 2,205 | |
Cell 12 | 1.306 | 1,502 | 2,232 | 2,187 | |
Cell 13 | 1.307 | 1,479 | 2,154 | 2,128 | |
Cell 14 | 1.307 | 1,489 | 2,149 | 2,117 | |
Cell 15 | 1.307 | 1,484 | 2,109 | 2,117 | |
Cell 16 | 1.307 | 1,455 | 2,189 | 2,029 | |
Av. | 1.307 | 1,498 | 2,187 | 2,107 |
first step.
How many significant figures need to be posted for these values? IMHO the first column could be rounded to 1.31 unless this two mV difference means something.
By way of answering, how sensitive to room temperature are these voltages? What the accuracy and resolution and repeatability of your meter (you may be seeing variations in your meter)?
The trees and branches and leaves can hide the forest.
I’ve done the courses in sampling theory. And don’t assume how many digits there are on my meter.
“The Devil is in the details”
Good work Don, I have purchased 4 of these to try. I look forward to your future tests/conclusions, I’d be interested to see any results you have even if others aren’t ( they don’t need to read the thread do they :zipper_mouth_face: )
Mine all arrived at exactly 1.309 (Fluke, calibrated to nation standards)
First discharge cycle netted;
1 - 1975
2 - 1966
3 - 1965
4 - 1970
Ambient 19c, results from my uncalibrated Maha. The glaring omission is the lack of discharge rate, I forgot to note this as it is decided by the charger based on capacity, which I set to 2500mah, if I get a chance I will check and update :8)
Jeansy, Really this is a little too much information! Just round them up to 2A.
@ Don. Thanks for your work Don It is very much appreciated. You too Jeansy. :bigsmile:
Marc.
Thanks Don for all the hard work here, following your post ordered one set myself to see what all these are about
Ordered from I Cell - look like 2nd gens as you say comparing sanyo’s have on hand here.
Discharge/refresh on LaCrosse BC700
1- 2008 1.49v
2- 2013 1.49v
3 –2010 1.48v
4- 2008 1.49v
No readings taken beforehand, just threw them in charger
Date coded on wrapper 11-06 also said on packet 2011 seems a little old to me anyway see how they do in my nitecore EA4
regards B
Anymore info on this yet. Is there enough evidence to conclusively say they are re-branded Eneloops?
Cheers.
Not yet. Nor will there be soon. The quickest way of getting conclusive proof would be to check the business press to see about the details of any deals between Contour Energy (A US firm who own contourenergy.co.uk) and Sanyo/Panasonic. Since I rapidly lose the will to live when looking at biz press releases, I’m not the guy to do this. There are probably SEC public record filings as well.
But there probably is a public record of Contour Energy (?Systems) doing a deal with Panasonic (Who own Sanyo).
I can only produce indicative stuff depending on the relative performance of some of these against a smaller number of genuine Eneloops from the same generation. (16 Contours & 8 Eneloop Tones (2G))
My opinion is they almost certainly are 2G Eneloops, but I have no data to back this up. Since I can only discharge one set of eight a day, and they are still in their first couple of cycles, it’s going to take a while to get the data.
The limiting factor is the Maha C808M I’m using to charge them - for maximum charge the cells need to spend 24 hours in it.
I could change the regime and use a hobby charger to charge all 16 at a time but that would rather invalidate the previous results. I’ll have a think about charging regimes while I’m on holiday in about an hour from now.
Chicken drumstick -
Having both sets here to compare myself all I could say is the physical characteristics,similarities in the end caps, same size, colour and appearance in grain effect of steel they look pretty close, it isnt scientific conclusion however at £3.99 pack delivered was worth a risk.
They also say made in japan
B
Cheers. Well pay day is next Thurs, so hoping to order then as I’m in need of 6 packs of the AA’s and 3 of the AAA’s.
I presume people are also assuming the AAA’s are also re-branded Eneloops?
If they also say Made in Japan then it’s highly probable.
This may be relevant.
http://www.contourenergy.com/news/press_releases/20110621-2.html
Gem is a wholly owned subsidiary of DCC (www.dcc.ie) who don’t mention Sanyo/Panasonic anywhere…
