It actually sounds like when I upgraded my AK-47 with the KD driver and tried using my Trustfire 5000mAh cells. They didn’t have the power to get the light to work and would only flash for a second.
yup, sounds like the same problem i had when i tried putting 3x18650 in my modded ak47. bright flash just like you mentioned.
but i just kept playing with the switch , tried switching modes lots of times, then eventually low was able to come on. but everytime i tried switching to a higher mode, bright flash and then nuthing.
but when i switched over to some 26650’s the problem went away. so if i was thinking positive, id say its the batteries. but thats a very expensive risk to take to buy some better 26650’s and the problem sstill exists.
but thats wierd, tom e used the same batteries in his and it works, so i dunno now.
Tom, how do you take apart the light to get to the emitters? I don’t “think” that’s the problem as the light was working before with the stock driver (just it was really dim).
As for not enough power from the batteries…. I have to clarify that I only saw the flash once or twice… during a course of 40-50 try’s…. and it was not at “full power” as I would have expected.
When I modded a small sun zy-t13 a few weeks back (added a pot)… I had the “bright flash” when the pot was turned up to high… I remembered that flash was at “full power”.
1)Unscrew the head.
2)Unscrew that backing plate.(that copper plate with 2 holes at side)
3)Pull out drive- shake it abit or pry out with little force if it is stuck.(Mine just rest there)
4)You should see 2 + screws inside the head, take it out. It is screw to lock the reflector.
5)Anti clockwise open the top “bezel or crown”? o-ring & glass will come out.
6) With a little tug, that reflector will come out, exposing the emitters & wires within.
ok… quick update… I don’t think it’s the emitters or the wiring…
Reason is that I put the stock driver back in and the light works again (like it did before I yanked the driver out).
What I mean is…. the light will turn on, all the modes work… looking at the head, all the led’s do light up…. the problem now is that it’s very dim (hence the original reason I yanked out the driver).
I mean… on high…its not much brighter than my single R5 flashlight with a 14450……….
I wonder if it could be that your flashlights emitters are connected in parallel instead of series? This could explain the fact that it works fine with the original driver. Could you take the reflector apart and take a photo?
Pokasaha, it’s funny you mention that. My Skyray 9x T6 light is wired 3s3p and my Trustfire AK-47 is wired fully series. When I tried to use the Skyray driver in the AK47, the light wouldn’t work. I was sure the grounds were in proper contact, but I came to the same conclusion with my lights that perhaps the drivers were not compatible due to different wiring. Although Jonney’s light is a Trustfire J18, it’s not unreasonable to think the drivers are not compatible. I’d like to confirm this somehow.
I’d guess that the drivers are not compatible. Emitters in 3S3P config are driven around 10V. Emitters in 9S1P are around 30V. I doubt a driver designed for one of these general voltage ranges (8-12V and 25-35V) is going to be OK with the other range.
Your solution would be to rewire the emitters to match what the driver should have for a load.
Yeah, exactly. And this is why I ask. I’ve just ordered this torch and a driver and would like to know if they are compatible. If there is this normal wiring, these combined parallel/series solutions are ok but if the leds are put on a circuit board as in my friends torch I’m in trouble.
Yeah, I’m just concerned that are some of these TR-J18 wired differently since there seems to be these not getting on issues and also you can see that there are several models of this lamp sold. You can tell it from the differences in the body.
Update, with nothing to loose, I decided to play with the driver a bit.
The J18 driver I got looks almost the same as the ak-47 driver found here
and looking at the post by richie, he mentioned that one of the resistor was loose.
Well, I am not sure if mine is the same, but I do not have a resistor on that far spot…… does not even look like anything was there to start with (this light did work properly in the beginning tho).
Anyhow, I got my 20 ohm trim pot I had left over from modding my small sun zy-t13… soldered it into the spot, and just played with it. Turning the trim pot I can make the flash light brighter… up to a point…… once you pass this point the flashlight will give you a very bright flash then shut off…
Using 3 cells, I just tuned it until I got the max brightness without getting the bright flash followed by nothing……
To be honest, I do not think this is a proper fix. The light is still not as bright as it should be (I am showing just a hair over 2 amps draw at the tail with 3 cells… not sure what this works out to be) and the driver gets HOT. I mean that round coil on the driver gets up to ouchie temps in about 2 seconds when I was holding it.
What I can see is that, I think I do in fact have a driver problem… or a really bad battery problem… haha…
The light is brighter with 2 cells…
two 26650 TF flames I am drawing just shy of 6 amps at the tail… dropping fast… haha…. down to 4.5 amps in under 3 seconds.
About 2.1 amps with 3 cells is grossing 23.31 watts which is very low. At 4.5 amps using 2 cells, you’re looking at grossing 33.3 watts, which is the same as a stock AK-47 with only 2 sense resistors on the driver.
Ok, one more update. The light seems to be pulling less and less amps. On 2 cells I am now only able to pull 2.3 - 2.4 amps and on 3 cells, about 2 amps. Seeing how all the led’s seem to be working, wiring seems to be “in tact”… and batteries are able to (at least for a short while) pull 6A without the protection kicking in… I’m thinking it has to be the driver…
so… one last try…. I orderd one more driver from IO this time (the last one, which looked the same was the customer programed one from KD… which looks identical to the IO one).
fingers crossed. I will let you guys know when I get the new driver delivered and installed
Hey, I got mine today. Can’t figure out, how to remove the reflector? Are there not a custom drop-in module? Should the driver be screwed out to gain access to the screws holding the reflector?
Btw the light force doesn’t impress with the originall driver at all. My modded TR-DF003 with three xm-l has the same brightness or even brighter… This has tighter spot though.
