I’d just like to confirm to everyone that this Nitecore holster is a PERFECT fit for the Terminator.
Also, at $10 delivered it’s good value as it’s a very well made holster. Doing Outdoor Nitecore Holster
Sorry, not very good at this caper, so my images are a funky size.
I’m particularly impressed with this holster because the base of the torch fits perfectly into the base of the holster, so no baggy bits. The neck of the holster around the torch is perfect. Tight enough to need a wee wiggle just to coax it in, but not that tight you need 2 hands. Also, my favourite bit lol, the velco strips marry-up perfectly too! No rubbish overlaps!
No problem squire
You’re as fast at ordering as I can be with photos sometimes haha :bigsmile:
Oh yeah, and just so you know, mine took 1 day from ordering to dispatch, then only another 10 days to get to Scotland. Pretty impressive
Thanks denbuc ordered one aswell.By the way i took the handle off mine and sealed the hole where the wires from switch enter head ,used non acetic silicone.
It was another member that tried the dunking test and noticed bubbles coming from around the handle,so i thought i had better seal it.Sorry i cant remember which member it was.
I used a thick rubber washing machine belt inbetween the jaws of a set of mole grips to unloosen the two top reflectors.Removed the two alen bolts,.Lift up the handle slightly,on mine there wasn,t much room ,noslack on the switch wires.Using a very small flat screwdriver i pushed in some silicone .Tightened the bolts back in and wiped excess off with a damp cloth…
