This has took out of sale?..Can Not find
It’s a viper with falcon wings flying past a mountain.
Original Products still there although the price has dropped slightly. Remember we ordered the Silver C8 Q5, but they substituted the Black with R5 emitter.
After such excellent review,I search for with R5))
Last night when I looked, there were no R5 Palight C8s listed, just Q5 and a few others over $100. I bought this light on Squidboy's recommendation and like Between said, we originally ordered the silver version. Jim e-mailed offering the black instead of waiting. My guess is that because it is a great light for the money (my opinion notwithstanding) and popular, it will be available again at some point. Jim might (probably) knows more.
Foy
This Ultrafire C8 R5 looks very similar to the palight http://www.shenzhen-wholesale.com/ultrafire-c8-cree-r5-led-aluminum-flashlight_sku1534.html?cPath=1_20&zenid=so3lvtgll9e96bt54ag7l44qj0
I ordered what looks to be the Ultrafire version of it with an XM-L at 3000mAh...I hope
$29 http://www.dealextreme.com/p/ultrafire-th-t60-ha-ii-xm-lt60-5-mode-1200-lumen-white-led-flashlight-with-strap-1-x-18650-57007
Circuitry: Digital Regulated 3000mA Current Output Brightness: 1200 lumens maximum brightness (manufacturer rated)
That appears to me to have a much smaller head and looks like yet another incarnation of the Golston body.
Since I can now measure amps I used this opportunity to revisit the Palight. As I first reported, "the Palight C8 (XP-G/R5 version) is no slouch." Not only is it not a slouch, it is a superb performer and although I take back nothing I said, I must admit that I may have understated some of this flashlight's capabilities.
Tonight while taking out the trash, I shined the Palight on a palm tree about a block away. This bad boy lit up the top of that tree so bright that I felt it would be disingenuous to this flashlight if I did not report its incredible performance. This is one hell of a bright torch and clear proof that XP-G lights can run with the big dogs. I'm still not a fan of the 5-mode/flashy board but I can say with no reservation that at $17, the Palight C8 (R5) has to be one of the top flashlight bargains of all time. Has it worked its way up the Foy-favorite-o-meter?
No. (but I do respect it more)
Foy
Glad you added to this thread. It is still my favorite light, and a fantastic thrower.
A good XM-L with a smooth reflector throws a wider hotspot, but the hotspot on the XP-G Palight is still brighter and throws farther.
Foy, what kind of draw did you get at the back of the light? I'd like to test mine and see if I'm getting the same results as you with my Harbor Freight MM. I'm getting 2.3A on high.
Now just think; what if we could get the P8 with a decent XM-L that pulled, say 2.5A and was a good match for its smooth reflector. Wow... but so far the XM-L's I've seen with SMO reflector don't work as well, I think the emitter is too big and the beam gets too diffused before it ever leaves the reflector.
I think the beam shape is what makes the P8 such a strong light. It has a very well defined hotspot and still gets good spill.
I updated the specs with my new readings. 1.60 on high was the highest on my cheapo $40 Extech DMM. .50 on medium and .06 on low. That's still, probably over 400 lumens on high if I'm reading the Cree chart right and yes, I would love to see what this guy could do if it were pushed a little.
Foy
It and asn't appeared on sale.
Periodically I check
Strange, I wonder why it looks like I'm getting 2.3A with mine.
troop - I just measured again after I've been using the light outside for a while and I can't get any higher than 1.50. You're using an 18650, right?
Foy
I just checked it again with a couple different batteries, none of them freshly charged so not sure how accurate this is.
With protected Ultrafire 2600's, 2.25A (hi) .65(mid) .09(lo)
With HiMax 2600 1.95(Hi) .6(mid) .08(Lo)
With Ultrafire 3000mAh 1.65 (Hi) .65(mid) .08(Lo) I need to charge this one and try again later.
Looks like this light is no longer available on MF with the R5 (XP-G) emitter. I can only find the Q5 ones now, for about $10 less. Wonder if it is because the emitter is driven too hard for an XP-G?
I wouldn't think so. I didn't notice any heat issues or anything. It doesn't make any sense because I would think they could sell every XP-G Palight they made. Would a Q5 version be worth a darn? I'm not sure I would stop long enough to look - Q5 lights don't do anything for me. On the other hand, the Palight reflector would make the most of a Q5 so . . .
Just seems like every site has an ocean of Q5 flashlights for sale.
Foy
The cat seems to be thinking "WTF am I doing in this Review ?" but I liked the non-sequitir relief.
Nice amazingly detailed Review.
