Thanks for the information! I have numerous atx supplies in the garage that I couldn’t part with! Now look what i can make. The woman will be so happy that i have another BLF inspired project. Lol
Thanks, guys! Yeah, even my step-son came home last night with his girlfriend and saw it on the kitchen table. He came into the living room where I was and asked, "did you make a power supply inside a cigar box?". I replied, "yeah, man" to which he said, "that's awesome!" :bigsmile:
If you happen to have them lying around. I think I have about 50 of them so anyone within 3 hours drive of me can have one for free. It’ll help clearing the crap from my house.
Power supplies need a certain minimum load to work properly. The min. load for mine is around 0.8 amps. Thus if you plan on powering LED’s or other such low-power device exclusively, you’ll need a resistor to provide a load. Otherwise you will damage the PSU.
A meaty 10-Ohm, 10 watt resistor from Radio Shack is a good choice. Wire it across 12 volt and ground.
interesting! I wonder if one of these could be used to do home anodising? Most guides I read specify a certain amount of current per surface area, whereas these are voltage controlled instead. It certainly would make it a whole lot cheaper if it would work.
That greatly depends on the size of item being anodized. I have read through post that did use a computer power supply for anodizing with small pieces. I use my automotive battery charger to anodize with. It works well with a small host like a cut down mini mag with very good results. I tried a full sized 2D Maglite one time and didn’t turn out so well. The current wasn’t high enough for the amount of surface area in the mag.
Rit clothes dye from wally world, Sunshine Orange.
Also, you can easily get voltages that aren't officially supplied by the PSU. For example using the +12v as positive and +5v as negative will give you the difference between them, in that case 7 volts.
