Long-term test Contour NiMH
It’s a little simpler than that. Would you, if you were Sanyo let someone call their batteries ‘the worlds best battery’ unless they had your cells inside?
Marc.
I wouldn’t take too much notice of the ‘world’s best battery’ thing. That’s just an advertising puff.
As far as I can see this is a good deal, and I’m happy with the calls. Besides, I’m giving them away to my nephew, so it’s his problem lol.
They work fine in my nitecore EA series, hold out much better under hight drain than my ageing enerloop’s
For the money I’m not complaining 8)
B
Just discharging the second eight for their third cycle. The eneloops await charging.
Contour ?Gen 2 eneloops
Initial Initial Initial
Voltage Discharge Charge Run 1 Run 2 Run 3
Cell 1 1.306 1,529 2,086 2,008 2,148
Cell 2 1.306 1,538 2,094 2,019 2,159
Cell 3 1.306 1,529 2,096 2,016 2,154
Cell 4 1.307 1,498 2,070 1,986 2,090
Cell 5 1.307 1,472 2,032 2,078 2,073
Cell 6 1.307 1,486 2,043 2,091 2,094
Cell 7 1.307 1,477 2,056 2,078 2,076
Cell 8 1.307 1,459 2,006 1,900 1,878
Cell 9 1.307 1,520 2,183 2,200 2,126
Cell 10 1.308 1,529 2,244 2,253 2,174
Cell 11 1.308 1,524 2,235 2,205 2,151
Cell 12 1.306 1,502 2,232 2,187 2,096
Cell 13 1.307 1,479 2,154 2,128 2,221
Cell 14 1.307 1,489 2,149 2,117 2,216
Cell 15 1.307 1,484 2,109 2,117 2,213
Cell 16 1.307 1,455 2,189 2,029 2,186
Av. 1.307 1,498 2,187 2,107 2,097 2,084
Yes, but what I mean is the fact that they would not be allowed to call them the ‘worlds best battery’ unless their competition agreed with them. Or supplied said cells of course. Sanyo eneloops are generally considered the best, therefore so are Contour. To me without them actually being eneloops they could not make that statement without a very large court case.
Marc.
eneloop can’t be the best batteries in the world if they don’t say so on the packaging. :~
I’ve asked nicely and some high discharge rate tests will be done. Just don’t hold your breath.
Thanks HKJ! You’re a star!
Think Carlsberg.
Marc.
I always thought it was (probably) the best cat’s output in the world. Yellow beer is what happens after beer.
:bigsmile:
Marc.
I’m with Woody, i don’t think a marketing slogan can be read too far into. After all, why are Eneloops the best? They certainly don’t give the best capacity. Not a dig at Eneloops they are my fav NiMh but things can be easily spun :wink:
I will hopefully get some internal impedance readings soon, properly done with a dedicated industry standard, calibrated meter.
IMHO i’d say its to do with quality of materials used and processes involved, battery manufacturers can make good stuff if the market place dictates.
just my 2 cents B
Yes but, you would be hard pushed to find a better battery than eneloop. So imagine what would happen if contour came along with a cell and said ‘it’s the best in the world’ Sanyo would have them in court quick smart. However if they were Sanyo then they could do nothing. But the point I am making is that to make that claim they be Sanyo. I can’t think of a better battery. That’s one of the reasons I suspected they must have been eneloops.
Marc.
I’m with you on that Marcl, I’ve not heard any reports of a better quality battery than sanyo’s own enerloop.
You would think maybe likes of Samsung might come out with something they’ve got some pretty hefty R & D
B
yep there isn’t much. Sanyo are king to me. I have some Panasonic evolta’s which are good, but the eneloops hold a slightly higher voltage. Vapextech have some, but I have heard as many bad things as I have good. The rest of them are all a bit have arsed. The next best are probably GP recyko’s .
Marc.
I’ve had 60 Vapex LSD cells. Less than 20 of them remain.
Just don’t.
Trust me on this. Just don’t.
+1 on that Don all my 8 Vapextech cells are in the trash
B
So the things I’ve heard are true then. There really does only seem to be eneloop. I have 8 or 12 GP recyko’s which seem to be good but one vented some salty looking liquid in my charger, but the cell works perfectly apart from that.
Marc.
Not wanting to hijack Don’s post, suppose its related to contour’s if don doesn’t mind here.
Maybe worth making new thread Marcl on different types
Based on my own small sample and experiences, only other cells i’ve had any mileage out of apart from
Enerloops have been duracells offering (think Sanyo make them) & Uniross Hybrio’s LSD (AAA) All the remainder of my Ni-Mh Lsd cells of 4 different brands have crapped out.
I use various chargers BC700 and couple of other makes alternating so i wouldn’t say they have been overcharged ,I also never run them to nothing either
I haven’t tried the GP recyko’s, Panasonic Evolta’s so I couldn’t comment on quality.
Four year old Uniross cells are still going albeit lower slightly in capacity
regards B
I thought the uniross were eneloops, could be wrong though. Don will probably be able to tell you.
Marc.
