Xtar WK30
Reviewer's Overall Rating: ★★★☆☆Copy and paste, maximum ★★★★★
Summary:
Battery: | If it is 14mm in diameter and around 50mm long it'll probably work |
Switch: | Reverse clicky |
Modes: | The usual 5 |
LED Type: | Cree XP-E Q5 |
Lens: | Feels like glass to me |
Tailstands: | Yes |
Price Payed: | List price US$39.99. SZWholesale say $15.96 plus shipping |
Date Ordered: | March 2011 |
Pros:
- Type 3 hard anodising.
- Comes with a spare switch and two spare O rings.
- Comes with a useful keychain attachment and a lanyard.
- This one won't roll.
- Very durable finish.
- Reverse polarity protection.
- Well put together.
- Available in seven colours
- Nice gift box and presentation.
- Can't see any PWM even on low.
Cons:
- The head and body don't line up perfectly when the head is fully tightened down.
- Claimed maximum voltage is 3.2V though I've fed it 14500's with no trouble.
- There are rings in the beam. White wall hunters are likely the only folks who'll be bothered by this.
- I'd like it better without any flashing modes.
Features / Value: ★★★★★
This was provided for free by SZ Wholesale (Who seem to be the main distributor for XTAR lights). Once this review is finalised, I'll be giving the light away as is my policy for review stuff. If I like it enough, I can buy my own one.
At the list price of $39.99 it isn't a very good deal to me. However, from the SZWholesale link above, it sells at $15.96 plus shipping. Unless the shipping is silly expensive I'd give this one 5 stars. I'm giving it 5 stars assuming it can be had for $20-22 delivered. At $40 I'd only give it three stars - at $20 I'd say it is an excellent deal. It is now available from szws here for $20 in three colours. At that price it richly deserves five stars for value.
It has the usual five modes but no detectable PWM flicker. As an aside since most of Europe's AC power is 50Hz as opposed to the US/Japan's 60Hz, Europeans seem to be much less sensitive to flicker than Americans.
I like the hexagonal body design - you put it down and it isn't rolling.
The package is rather nice.
The upper box is the WK30's one, the lower the WK20's. Ignore the CR123 which came with the WK20 for review.
It comes with some nice extras. A spare switch is unusual. The two spare O rings are very good to have, the handmade lanyard does little for me but the crab claw keychain attachment is very good.
I have no way of testing whether or not the finish is Type 3 anodising or not, but the light spent a month attached to my work keys so I can vouch for the durability of the finish.
There are a small number of marks visible on the tail end after a month of sharing a pockets with keys, coins and all the other stuff one keeps in pockets. The marks round the switch retaining ring were my attempts to remove it to play with the replacement switch.
The head end also has a few marks. With my normal usage of lights, none of these marks would have happened as I don't normally put anything bigger than an AAA light on a keyring.
One good feature is the reverse polarity protection. A wrong way round battery isn't going to do bad things to the driver. The black foam ring at the base of the head has a hole for the battery's + contact. A wrong way round cell can't complete the circuit.
It is a pretty big light as AA lights go. It is a couple of millimetres longer than the Trustfire F22/Yezl S5 but smaller in "diameter"
WK30, Yezl S5, Trustfire F22 (A replacement for the much-loved lost one), Trustfire R5-A3, Uniquefire S10 singlemode, Tank007 E07, Zebralight H50 and an XTAR WK20 whose review will be up soon. All but the last one are AA lights.
Design / Build Quality: ★★★★★
The design is a matter of taste. My taste doesn't like the extra engraving. I like plain and simple.
If they'd just left it with the XTAR logo I'd have liked it more. The build quality is very good. The only niggle I can find with it is that if you screw the head down hard, the head and the body do not line up.
It gets the five stars for the hexagonal body and the build quality, most emphatically not for the extra engraving. It may appeal to some, but doesn't to me. Some appropriately coloured filler would fix that easily enough. If the engraving bothered me more, I'd give it 4 stars.
Battery Life: ★★★☆☆Copy and paste, maximum ★★★★★
Current Draw:
Battery Type | High | Medium | Low | Strobe | SOS |
NiMH | |||||
Alkaline | |||||
Li Primary | |||||
NiZn | |||||
LiFePO4 | |||||
14500 | |||||
Runtime graphs to follow:
Alkaline High
Alkaline Medium
Alkaline Low
Light Output: ★★★★
The reflector is pretty deep for an AA light and has a narrower beam than many AA lights. On the left, the XTAR on a 14500, on the right an Ultrafire C303 on medium. As you can see the beam is relatively narrow. Both are tailstanding on top of a door 60cm from the ceiling.
The beam on its own.
I need to add results from LiFePO4 cells which arrived last week. I also need to add throw numbers, which I am sure I have already done, I just can't find the numbers.
Light | Battery |
Xtar WK30 High | NiMH |
Xtar WK30 Medium | NiMH |
Xtar WK30 Low | NiMH |
Xtar WK30 High | Alkaline |
Xtar WK30 Medium | Alkaline |
Xtar WK30 Low | Alkaline |
Xtar WK30 High | Li primary |
Xtar WK30 Medium | Li primary |
Xtar WK30 Low | Li primary |
Xtar WK30 High | NiZn |
Xtar WK30 Medium | NiZn |
Xtar WK30 Low | NiZn |
Xtar WK30 High | 14500 |
Xtar WK30 Medium | 14500 |
Xtar WK30 Low | 14500 |
Some outdoors beamshots.
It wasn't all that dark but I was in urgent need of sleep. It was, however, a lot darker than these pictures make it seem. Living in a city with plenty of light pollution and rapidly lengthening days, we don't get all that good-quality darkness round here till around the end of September.
I'm not working this weekend so will do better pictures later at night.. The white balance is locked on daylight so I also used an outright yellow light (Mega warm designed for jewelry inspection) for comparison.
Control
Strange jade inspection light. According to DX this is a very warm bin Cree XR-E P4. According to my lightbox it puts out just short of 100 lumens at switch on, down to 70 after a couple of minutes. It gets hot.
WK30 High
WK20 High This is an XP-G as is the Ultrafire C303
Ultrafire C303 High
WK30 Medium
Ultrafire C303 Medium
WK30 Low
WK20 Low or medium. It is a 3 mode light with high, less high and strobe.
Ultrafire C303 Low
The level spacing is good at 175 / 57 / 14 lumens on a 14500, 69 / 26 / 6 on an NiMH. This is not the brightest AA light, but performance is respectable on 14500 and perfectly acceptable on NiMH where it is in the same ballpark as the Tank007 E07 but is much throwier.
Summary: ★★★☆☆Copy and paste, use rounded average, maximum ★★★★★
I like this light a lot. It will be given away, but I think I might well get myself another one. My rating is absolutely dependent on the shipped price. I'm expecting it to be available for $20-22 delivered. If it is at the RRP of $40 I'd not be interested. SBFlashlights are selling it for a little over $40 shipped.
