Yes the TK75 will maintain its turbo mode for 20min. I personally tested one and it went from turbo to high right at about 21min. It did loose about 230L during that the 21 min. period, but that’s very reasonable for a high output light that had no extra cooling during the testing.
When I first got into this crazy flashlight game, all that mattered to me was throw. I ended up working my way up to a couple of pretty good throw lights costing just over $100.00 each. Fenix TK41 and Olight M3X. Both throw longer than my aging eyes will probably ever need. I ended up liking and using the TK41 more even though it didn’t throw quite as far because it has a much more useable beam with more spill and more modes. As time passes I find that even though I like throw, a good spill light with decent throw is what I use the most.
I picked up a Black Shadow Termonator last week it has become my favorite light. Maybe it’s because it’s new and after the newness wears off or after I buy a TK75, my view may change. However, the masive amount of light it puts out and more throw than I’m likely to ever really need along with it’s handy size has moved the Termonator to the top of my list of around 30 lights that I own.
I'd say you're insane ....I'd also say it to Match ,Don, foy ,-the-, or anyone else on the forum
If your skin is that thin I'd suggest cpf . I'm sorry but members who joined yesterday shouldn't ever mention that they are thinking about leaving because they aren't feeling the love .. welcome to blf or see ya on cpf :P
The Termonator is not perfect. A memory would be nice as would a lower low mode. I didn’t think I would like the green light coming from the on/off switch but after putting the light on the night stand I have found that it makes a wonderful night light. The whole light is smaller than I thought it would be and I think the handle will come in very handy for camping. It will make a wonderful hook to hang it in the tent. I had to laugh. My wife suffers from cold hands. She has asked me to turn the light on high a couple of times to heat it up. Makes a great hand warmer. LOL
I have a ThruNite TN31 XM-L2, Trustfire X6, HD2010, and a Fenix TK70. Honestly, the TK70 poops all over the other ones. The TK70 and the TN31 have the same throw value (130kcd), but the TK70 lights up a much larger area while having the same throw. I just picked up a 2nd used TK70 for $135 shipped from another forum member here. You can get one new off eBay for $190, but I know that’s a lot more than you want to spend.
The Trustfire X6 is a great thrower, but a decent light. I got one off Aliexpress for $78 shipped. It’s definitely a major thrower and it has great heat sinking, however, I have some complaints. The one I got is unbranded, came with a completely borked tail cap rubber gasket (there are 2 so not a huge deal), and it is a reverse clicky switch. My biggest complaint though is that the battery tube is very short. I bought some Panasonic NCR18650B 18650 3400 mAh protected batteries from fasttech.com for it and I couldnt screw down the tail cap. I then tried some Sanyo UR18650FM 18650 2600 mAh protected batteries from fasttech.com and I could screw down the cap, but it caved in the negative contacts on the battery protection circuits. To be fair, the protection circuits that fasttech offers on those batteries are abnormally long, which doesnt help. So if I want to use the light, I generally put in my protected Trustfire flame 18650’s, which I don’t trust to not explode in that light. As Scaru mentioned in another post, this problem could probably be fixed by cutting down the tail cap spring, but it was kind of an off putting problem for me. I’m not sure why Trustfire couldnt add 5mm of extra length to the battery tube…Would it really cost that much? All my complaints aside, the light throws like a mofica, is fairly cheap, is a great candidate for modding to push A LOT more lumens from the stock emitter, and its cool to have a light that has something other than a Cree LED in it (It uses a Luminus SST-90 LED).
I bought my TN31 XM-L2 from another forum member here, JOE, and it is an absolutely fantastic light. He sells them for $145 shipped new and he is a great guy to work with. I really like the user interface of the light. It uses a ring at the top of the body, below the head. You twist the ring to switch between the mode settings. The modes are nicely spaced apart lumen wise and include a standby and strobe feature. The lowest mode is the lowest lumen output of any flashlight I own, which is really nice if you need just enough light to read a map or something where you don’t want to ruin your night vision. The switch on the tail cap is also forward clicky, which I VASTLY prefer to reverse clicky.
The HD2010 from Tmart is a nice light and hard to beat for $30, but I have some reservations about it. It definitely throws nicely for the price, but every time I turn it on, I feel like I am in a James Cameron movie at night. The tint of the emitter is very much on the blue side of the spectrum, or at least mine is. While its really not a concern unless you are shining it at a white wall 10 feet away, the beam is also very non-uniform. Also, there isn’t a very good selection of 26650 batteries out there and not a lot of chargers support them. I would probably spend the extra $7 and get a Fandyfire STL-V6 from fasttech.com so you can use 18650’s. If you go with the HD2010, I would probably get a Protected Trustfire Flame 26650 or King Kong 26650 for it.
Isn't the TK70 is little weaker than the BTU Shocker? If so you're TN31 should be beating it. Granted I have the NW Shocker, but there is no comparison for throw with mine.
Thanks for the compliant I think the reasoning for forward clicky is the UI. I prefer reverse clicky when you have to cycle through the modes with the tailcap button. For 1-mode and magnetic ring lights I think forward is better. (I am a die-hard reverse clicky guy too)
I would go with the STL-V6 as well. It is a truly great thrower for the price.
I have three lights that are pretty much throwers. The jacobs A60 it throws a pinpoint of light a country mile for $14. For $25 I have a small sun ZY-T08 it throws a long way too and it isn’t a pinpoint but bigger decent sized beam. For the money it’s a great buy. Then I have a SST-80 Trustfire T8 huge head and out throws the rest. Mine was $47 but it was a sale. If what you are looking for is throw it’s great and can be modded to be a true monster. I’m putting in a de-domed XM-L2 on Monday.
The most impressive light that I own is both a thrower and a flooder. It’s the BTU shocker and it is something else. I paid $120 for mine and got $20 in store credit and an extra DRY driver tossed in. This light competes with the TK70 heads up and uses 18650’s.
Yes it’s big and yes it’s heavy and yes it kicks! You won’t find anything for sale that is significantly better at least not anything that I know of for under $500.
The BTU Shocker is more closely compared to the Fenix TK75. The TK75 puts out more lumens than the BTU Shocker and throws further. The TK70 puts out 400 less lumens than the TK75, but it throws further than the TK75 (606 vs 720 meters ANSI rated). My friend and I went to a really big cemetery with my TN31, TN30, TK70, and Trustfire X6. The TK70 was by far the best thrower of the bunch. I think its just due to the reflector design. It has very deep and narrow reflectors so it sends the light downrange in a VERY tight beam, but the 3 LED's make up for the beam tightness by letting it still have excellent flood. Again, the TN31 has the same throw, but the area it lights up at distance is much smaller than the TK70. The TN30 is undoubtedly brighter up close, but it just doesn't have the range of the TK70. The TN30 is a much more versatile light because of the size and modes, but it has it's place. It's definitely not what I would classify as a pure thrower. The only light I have that is brighter than the TN30 is my Ultrafire 9xT6. But that thing is pure flood with very limited throw. I would say the TN30 XM-L2 is definitely the most versatile light I own and one of my favorites.
Generally for throw it USUALLY goes TN31 XM-L2, TN31 XML~BTU CW, TK70, K40, BTU NW, TK75, and so on.
Of course those are typical examples.
I’m assuming he means the TK70 simply over powers the TN31 XM-L2. It does have twice the output and just a bit shy of the throw.
Ahh - no way a stock TK70 can out throw a TN31 XM-L2 like you have unless your batteries are almost dead. Maybe a weaker TN31 with XML, but I doubt that even. And a BTU easily out throws a TK75. By 100m. The BTU and TK70 are very comparable lights in throw, with a slight edge to the BTU due to its extra 6-700 lumens with almost identical reflector.
Not TK70 bashing, its got great output and throw. But not THAT good. The new TN31 XM-L2’s should be a match for my 142K SR90 when it was stock.
I apologize for the misinformation. I am wrong about the BTU vs TK70 vs TK75 vs TN31. I'm waiting for an XM-L2 BTU Shocker to become available, then I will have one of those for my own comparison. Still though, as an owner of the TK70 and the TN31 XM-L2, I would definitely recommend the TK70 as a far throwing search light over the TN31.
Ok, I fully understand your point about the TK70. It does offer awesome throw and at the same time floods a huge area vs the TN31. I agree with you about using something like that for a searchlight. I know some think a flooder/thrower like the TK70 or BTU will wash out the area in front of you too much and prevent you from see far down range. And some think that a smaller spot type light like a TN31 is better for that chore. I tend to disagree with that line of thinking, like I think you do too. I personally would rather light up a football field wide path for hundreds of meters vs just a small spot 600m away. You might not truly see as far with the TK70 or BTU because your eyes adjusting to the brightness up close, but I still think the odds of you finding a missing person, animal, or whatever is higher with the combo of high lumens throwing a long distance and flooding everything on its way is higher than it would be with a dedicated thrower. Though a TN31 does over reasonable flood for its true throwing design.
If u don’t want MAJOR THROWER I understand, HD-2010 is good bang for the buck around 30. But if you really want to strap 4 TK-70/TN31 together to equal a ebay HID I understand also. If the TK-70 is 2200 lumens on turbo, the ebay HID is over 9000!!!
My advice: know the real reason why you want what you want. What tasks will you be using it for? Is it a toy or a tool? It’s gotta be one more than the other. I’ve come to see that going budget is the way to go since you have to factor in what happens when you might lose or break something. STL-V2 highly recommended, as is Small Sun T16/T08, whichever, and HD2010 (though I keep having quality issues). All will wow you.
My thrower is more of a toy/chalenge. I’m trying to get the most lux possible at the lowest price possible. I think I had around 117k cd on my zy-t13. $25 for the zy-t13, $30 for the collimator head, and an xre ez900 stollen from a $5 eBay flood to zoom.
Tool? Possibly. Toy?… Most definately
