I was just sorting through a new batch of drivers I got in the mail. Those chips seem to be getting smaller since relic posted this thread.
I have a disadvantage that gives me an advantage when soldering. I’m nearsighted, and if I take off my glasses I can see things close enough to not need the magnifying glass. I use it after the job to inspect the joints.
I’m also quite nearsighted and do the same thing, who needs a magnifying glass when you can see close-up from several inches away!
But, while I haven’t tried this yet (am about to which is how I found this thread) I still see problems like MRsDNF described…soldering iron is like getting a tire iron in a pin hole! Perhaps I need to look at getting a smaller iron tip for this type of stuff. I only recently discovered the small soldering wire that makes a huge difference, had always tried the big stuff with lead in it from days of old and always made a sloppy joint. So now that I have learned to reflow an emitter and have been making nicer solder joints I have a new driver coming in at 3.04A and wish to add a few 7135’s to bring it up to around 4-4.5A for my HD2010 with it’s new copper star and XM-L2 emitter.
Thanks for showing these pics, makes it less scary and I’m ready to attempt adding 4 of these. Where do you recommend I purchase em? The new driver is already on the way and I’d hate to wait 2 weeks for some of these tiny things!
I have experienced flickering but seemed random. Once it starts flickering I could not seem to find any pattern to the flickering. All the connections where good. This could possible explain why the flickering occurs. My flickering only seems to occur in low mode. It doesn’t happen that often but I have experienced it in a couple of mods. I always thought maybe one amc7135 got to hot so I would replace the added chips. Sometimes the flickering went away sometimes it didn’t. If it didn’t I just started all over again with a new board.
Has anyone else here experienced flickering when they bent the pins down before soldering? Relic38, have you experienced the flickering personally with bent pins?
I have not bent the pins before. My issues with flickering were mostly clicky or driver contact issues.
I can see how a weakened bond wire could produce flickering in different modes. Heat in a high mode could provide reasonable contact due to expansion. Once you switch to low, the contact could spread and weaken the contact. I suppose it could work in the opposite manner too. Stressing a tiny thing like what is inside the 7135 chip (picture a grainor two of sand) is why I avoid bending pins.
That seems to be when the flickering I noticed starts after I have used high for good amount of time. After that it may only take seconds for it to start flickering even after the light has been off for some time. The flickering did not start until the extended run in high mode. I may go back to soldering without bending the pins for awhile and see if the problem goes away.
I figured I better get prepared. I only have the tip that came with my Weller WESD51, so I ordered something a little slimmer. It may be of no use at all, but maybe it will help.
I have narrow and wide tips; I prefer the widest tip that I can fit for the job. Thin tips have a heat transfer issue and do not work well on pins and pads that conduct a lot of heat away. For that reason, I almost always use a ‘stumpy’ 1mm x 0.5mm tip (I forget the exact dimensions). I solder 20 pin surface mount chips with 0.030 pin spacing with it. I have more trouble doing the same with a smaller tip.
Does the fatter tip help pull the “blob” up to the top pin easier?
What jobs would the finer tip be best for?
Awesome guide!
I’m thinking of giving it a try.
I just built my first multi-emitter might. It’s a modded Sipik 58 running on 1x14500 IMR with triple Nichia 219 and 3.04 amp Nanjg 105c driver.
There’s room inside to add another row of 7135s on the top of the driver and I have the chips on hand. I could increase the current to 4.5 amps.
Heat and short battery life might be an issue in such a small light though. I added a copper heatsink behind the star, but it’s not very big. I’m also not sure if raising the current to 4.5 amps is really worth it. Doing so would increase the theoretical output before optics from 266 lumens per emitter to 336. Assuming 30% loss due to optics and other inefficiency and output would rise from around 560 lumens to 700… at the cost of drawing 50% more power.
Ah, shame you didn’t get the 219’s binned for 475 lumen output at 1.5A. They you’d have some serious output on that triple if you stacked the chips, be worth the effort for sure!
I have one of those reflowed to a copper star and side by side it outputs very similar to an XP-G2 (which is claimed 520 lumens @ 1.5A) the 219 has a visbily smaller hot spot due to a slightly narrower angle so it might give a better throw with a triple configuration.
Just ordered 20 of the AMC7135’s binned at 380mA to match the ones on the 3.04A driver I’ll be modding. Each step is exciting as I learn new things, hope I can pull this one off!
Interesting.
Actually, I don’t really know what the output is on my 219s. I looked up a table in a Google search that showed 266 lumens at 1 amp and 336 at 1.5 amps. I purchased my 219s at Illumination Supply.
Any idea where to buy 475 lumen 219s? I assume they’re still high CRI.
As I didn’t want the 4500K versions and preferred a bit cooler tint, I went with the 5000K version with more output. I found them here: http://www.ledrise.com/product_info.php?info=p1499_Nichia-LED-Series-219-NVSW219A-475lm-Emitter-White.html.
Mistakes I see that are quite good help when doing this:
- flux, use the damn flux!
- bend the legs of the 7135s
- do solder all pins the middle one as well
- most people do not have holding hands
I place the driver in big pliers that have a rubber band over them. Holds the board.
Bend all 3 legs down.
Flux all connections.
Hold with something, like a clothes pin or glue, the new 7135 in place.
Solder one by one, probably do the tab first.
A very thin soldering tip proved bad for me, it just did not have the power as it was too long. That is with a 50W temperature regulated soldering iron, even boosted the damn thing up +30°C but it’s still pain in the neck to solder with the longer tip.
Just use a normal soldering tip, works for everything for me.
Yes, a blunt (not necessarily fatter) tip does help pull solder around. The main advantage of a fatter tip is more heat delivery, but more surface area to pull solder is a plus as well. In some jobs, you do not want to pull solder so a sharp tip is better,
Example: A fine tip is good for soldering this to a PCB. Each pin is 0.015” wide and they have a 0.031” pitch. I’ve soldered a few. Fun times, good practice.
Question, would solder paste work any easier? I’m not very experienced at all with soldering, seems it might be easier to use solder paste on top of the existing legs, stack the chip and then apply heat. Wish I had a heat gun but I don’t.
Solder paste requires contact between the two parts being soldered. It works great for soldering new chips to a new PCB. For everything else, solder usually works better.
Some 7135 chips arrived from fastTech today, and I decided to give it a go. I knew it wouldn't be as smooth going as in relics easy as 123 tutorial, so I was mentally prepared. First problems encountered:
#1- I can't see.
#2- looking through a magnifying glass really messes up your coordination.- no go
#3- I still can't see
#4- holding chip in place with left hand and tweezers is hard.
#5- I still can't see.
I finally did a little fluxing, got the chip in place, and basically took a blind stab at the rear tab with a glob of solder...hoping that when I blinked the chip wouldn't end up all wee-waw. The blob grabbed, and the chip is now attached, and lined up pretty good. I went for the "no bend" method. Besides not being able to see, and hoping for the best, I lined up the solder, lowered the tip, shoved the solder at it, and pulled the tip up...blindly. Well, after squinting and scrutinizing and magnifying, it seemed to have worked. I repeated the process on the other leg, and decided that if I also went for the middle leg, I would screw it all up. I was thinking of doing another chip, but I couldn't figure out how, without screwing up the chip beside it. Anyway, I did it. I'm sure next time might be easier.
Now to clean up the aftermath. I couldn't have done this without my Sunwayman Torpedo shining some light on the subject.
Next Question. If I wanted to add two chips to a board, could I stack both on top of the same chip? It seems to me it would be easier to solder two together first, and then solder them onto the one on the board.
Thanks relic, and everyone who threw in. It wasn't pretty, but, I did it.
Nice job there, thank you for scaring me through and through! Now I know what not to do because if I try it freehand I’ll blow the board or fry it or something for sure. So it occured to me, if holding it in place to solder is one of the biggest challenges, could you just use some thermal adhesive and glue it on first? Then come back and make the connections? Is there a team of Electrical Engineer Army Ants that can go in there and build a joint like trusses under a bridge? I’ll pay em, or give em cake, whatever they prefer!
If it’d work to stack 2 then solder it on, would the solder that holds the first 2 together melt when you tried to tie it to the one on the board?
Could a guy set up a macro lens on an HD camera and send the video to a monitor and use the live feed on a large monitor as the eyes, like a doctor, and maneuver through a larger playing field? No sneezes or coughing allowed. Probably best to lock the kid out, huh? When you’re in there up-close-and-personal, how do you keep from breathing the solder smoke, which I presume comes from the flux? Need to set up a fan first?
Ouchyfoot, feels good doesn’t it! How many are you going to put on? Shooting for the legendary 40? Is 4 actually reasonable for a first timer? Or is that biting off a big chunk?
What if I bought a new Weller station, one of the cheap ones…like $35 with a screwdriver style blade tip? I think 30 watt or 50 watt, would that work? My pencil iron is very old and I don’t think it’s EVER been cleaned, or properly tinned for that matter. I just knocked off a bunch of black scale from the shaft the other day, what’s that all about?
Maybe I should just give my redneck neighbor a couple of beers to weld them on with his torch….
That picture… COOL. its like you have small little workers at job there. I picture them as live toys from a Pixar movie or something.
Nice job on the 7135 chip!
