Hello O-L, nice looking light. Please count me in and thanks for the giveaway!
sweet! i’m in
I’d want the light just to take it apart and see how you do it, haha. I’m in.
I’m definitely in on an Old-Lumens giveaway!
Count me in, thanks!
Great (as usual) giveaway OL…. I”M IN !!!
Please count me in. Thank you O-L
I’m in. I was wondering when you were going to cut one down to 1x AA size. Did you use your new threader on it?
Count me in too, Old-Lumens.
I have a 14500 sitting right here.
Thanks.
Man thats a super sweet light!!!
IM IN IT TO WIN IT
Count me in! Thanks for another one Justin!
Really Cool, I’m in! Great mod O-L!
In, please. And thanks!
Thanks for the great giveaway! I'm in!
I am in. Thanks
thanks for doing this!
please i am in!
Love It! … Count Me In
Count me in
In for the win. Thanks!
At the risk of messing up this giveaway thread, I will try to answer a little about this cut down.
JohnnyMac is the cut down go to guy here, when it comes to Mini-Mags. He has perfected it.
I did buy one of the taps for tapping the threads. I did not however buy a drill as I am cheap and besides, what fun is it using a drill for a tap hole? I cut 50mm off the end of the body, with my tubing cutter. I measured the original depth of the threaded end of the body and went down the same depth. I opened it up with an small end mill bit using the bit in the drill press and turning the body around against the bit, to open the inside. I did that slowly and in several small steps, so I could get "about" the right ID for the tap. Then I cut the step on the very end, where the tail cap seal goes, with my 115 Dremel bit, in the drill press. After that, I tapped the hole for the threads. It was that simple, LOL.
I do not plan to do many of these 1AA lights. I just wanted to see if I could and thought the giveaway was the best way to go, since JohnnyMac does a great job on them already... Of course, I have thought of doing one using a couple watch batteries, so that the whole light is no longer than the head plus a couple mm to be able to grab at the tail.
