sweet! i’m in
I’d want the light just to take it apart and see how you do it, haha. I’m in.
I’m definitely in on an Old-Lumens giveaway!
Count me in, thanks!
Great (as usual) giveaway OL…. I”M IN !!!
Please count me in. Thank you O-L
I’m in. I was wondering when you were going to cut one down to 1x AA size. Did you use your new threader on it?
Count me in too, Old-Lumens.
I have a 14500 sitting right here.
Thanks.
Man thats a super sweet light!!!
IM IN IT TO WIN IT
Count me in! Thanks for another one Justin!
Really Cool, I’m in! Great mod O-L!
In, please. And thanks!
Thanks for the great giveaway! I'm in!
I am in. Thanks
thanks for doing this!
please i am in!
Love It! … Count Me In
Count me in
In for the win. Thanks!
At the risk of messing up this giveaway thread, I will try to answer a little about this cut down.
JohnnyMac is the cut down go to guy here, when it comes to Mini-Mags. He has perfected it.
I did buy one of the taps for tapping the threads. I did not however buy a drill as I am cheap and besides, what fun is it using a drill for a tap hole? I cut 50mm off the end of the body, with my tubing cutter. I measured the original depth of the threaded end of the body and went down the same depth. I opened it up with an small end mill bit using the bit in the drill press and turning the body around against the bit, to open the inside. I did that slowly and in several small steps, so I could get "about" the right ID for the tap. Then I cut the step on the very end, where the tail cap seal goes, with my 115 Dremel bit, in the drill press. After that, I tapped the hole for the threads. It was that simple, LOL.
I do not plan to do many of these 1AA lights. I just wanted to see if I could and thought the giveaway was the best way to go, since JohnnyMac does a great job on them already... Of course, I have thought of doing one using a couple watch batteries, so that the whole light is no longer than the head plus a couple mm to be able to grab at the tail.
Nice, count me in
