Review: Magnetic control diving light (Cree XM-L T6 | 1 x 18650)
Great info gcbryan, and interestng read :slight_smile:
Why dont you get some cheap diving lights for testing (there are several of them now wich look serious, in price range cca 20-30$ ) :smiley: (I think primarily on this one, and there is Yezl Q2 for example on cnqualitygoods…
Maybe manafacturers can send them to you for reviewing (hmmm, if they dont think that wouldnt be in their interest :o)
I just dont understand the issue about body of the flashlight being part of the electrical circuit.
Im aware that this is so in practically all “surface” flashlights I own.
But I dont understand what happens with diving flashlight in that regard:
DO all budget diving flashlight have that design flaw? (XTAR lights for example? D06? YOur MC-E flashlight, gcbryan?
And what happens, why is this a flaw? (I think there are two things: Ive read for example that dinged XTAR D06 will shine in salt water even in off position, and will shock you if you touch iit with bear hands - thats one thing. And new sturdy Trustfire diving light doesnt want to change modes in the water, thats the other thing I think is connected with that flaw…)
Where the current flaws in better diving flashlights? Not through the body? Or they have thicker annodization?? Many things I dont understand :slight_smile:
I’ll respond to your second question first. I don’t know anything about this issue or even if it’s a real issue. Without knowing the details I tend to think this isn’t really an issue.
I have metal dive lights as well as those with a hard plastic body. I’ve had no issues in that regard.
Regardlng testing dive lights…I’m not interested in most of the ones that I see. They’re either too small (don’t have enough burn time) or they’re too floody or (the big issue) they’re just too likely to flood since it’s just luck for a Chinese manufacturer to end up with a robust design since they don’t seem to actually know anything about the issues that relate to the diving environment.
I also don’t need any more dive lights at the moment. What I have do the job and even if more “modern” lights come out what I have do the job and don’t leak so what’s the point? :slight_smile:
The only light that would interest me would be one that 1) works and 2) doesn’t have all the crenelations and heat fins that my current one has while 3) still using two 18650’s.
However, money is tight and I’m really not interested is spending $100 right now even if such a light did come up.
The big advantage of the light I posted about (main dive light) is that hundreds of people bought that when it first came out (since there was nothing close to it in price at the time) and many of those people (myself included) were in contact with each other regarding reviews, failures and fixes.
So that light is fully vetted in a way that most of these others aren’t at the moment. On the other hand if someone is just looking for a small floody light for a shallow clear water night dive on a tropical vacation…most any dive light will do that.
But you say u prefer to use your light only to 30 meters, I think? (because of little too thin front glass?)
And no o rings need to be replaced on it?
Regarding other lights issues: Loading...
Look this one is interesting. Its 1Y18650 but it can be at least spare light. Yezl is known as quality budget manafacturer, and I have read one positive comment about some Yez flashlight on scubaboard.
It doesnt have any crenelations nor “attack head” :o
It even has nice big whole fror attaching diving lanyard.
And it looks like really nice, beefy (like many Yezl designs :slight_smile: ), also like serious flashlight…
But I understand your point, you already have what you need and you are not inclined to risk and experiment.
Maybe a con is to thick bezel, or better to say to small reflector. HEad is 53mm, but reflector diammeter s maybe less than 40mm (less than C8 reflector diammeter). And it doesnt look very deep, so you want get to focused beam with XML…
And if its moderately driven you should easily get more than 1 hour runtime with one good 18650
Following your recommendation Im closest to buy this one http://fancyflashlights.com/goods.php?id=193 (same as yours, but ffrom other website - because of cheaper price)
PS: Flashligt from this topic also doesnt look bad, but because of small reflector its surelly more floody than throwy with XML (XPG or XRE would be different thing)
The first one you link to looks interesting in that it’s attractive as you say. For me it would be a bit too big for a backup light given the manner that I attach and use the backup light.
I use this as a backup light…
W200
Bryan thanx for sharing all this info, I hope more people will benefit from them.
Your backup light, based on dx reviews, has some problems and needs to be checked obefore any use.
Regarding MC-E light, do you think I need to buy some spare O-rings and where to buy them?
PS: And look at this cute diving headlamp :smiley: ) Loading...
This is a subject matter (diving and lights of course) that I do find interesting and do have a decent amount of experience with since I’m into diving and fortunate to live where deeper ocean diving is possible on a daily basis if I so chose (and I so chose for quite a while) :slight_smile:
Ecig, I don’t personally regard the W200 as being anything but rock solid. Some people have had a few problems which is the case with anything from DX and probably with anything in general.
Some of the people who had problems with the W200 did so after taking it apart. It’s not designed for that. The way the front is put together works well but if you pop the o-ring out and scratch it and then put everything back together it could leak.
That’s not a problem with the design of the light. I have two of them and did take one apart to play around with (modifying).
Although it’s possible that someone could have gotten a bad one. Most of the issues of that light leaking only came after everyone starting buying that light to modify. I think most of the issues were caused by trying to modify it. The o-ring in question in that case is a press fit from the front on top of the front glass lens. It’s what keeps it in. It’s a different design from most lights.
Foy, that looks like a good light. There are several designs out there that look like a good light and they may be. They only way that I consider them to be good for diving is if a lot of divers bought them and went diving with them over a period of time and there was no major problem with leaking.
There aren’t many reviews of most lights since the model that I have. Since there aren’t many (in some cases any) reviews when there are leaks it’s hard to know if it’s a common problem or just an isolated one.
If these lights were being made by the usual dive light manufacturers I’d assume a good looking design was probably a good dive light.
That’s not the case however. The people making these lights aren’t divers and don’t really know anything about diving.
The guy who originally designed the light that you have is a diver however he didn’t manufacture that light so …who knows?
There are several models of that light however in various configurations. For my purposes it’s not a backup light (too bulky) and unless it can take two 18650 it doesn’t have enough power for two consecutive dives (which is common).
I don’t know why he designed it with all those cooling fins with their sharp edges. He was more interested in cave diving and may have also wanted them to burn brightly while out of the water as well (I don’t know for sure).
Ecig, regarding diving headlamps…ugh! :slight_smile:
I absolutely hate it when a dive buddy wears any kind of light on his head to the point of just not preferring to dive with people like that.
Every time someone like that looks my way that means his light is shining in my face! The same goes from people who decide to wear a flashing strobe on their tank or somewhere on their body to supposedly help someone locate them!
It’s annoying! :slight_smile:
Oh, regarding extra o-rings for the Magicshine light…it comes with several extras. Some people were talking about getting something harder than the silicone ones that come with it.
I don’t think that’s necessary. If you want to do it fine but I have hundreds of dives on mine with no problem.
You know how this goes…people like to mess with/change whatever it is that they buy. Sometime/often they cause the problem that they are complaining about. :slight_smile:
I think there are plenty of examples of that right here at BLF. :slight_smile:
I’m not immune either. :slight_smile:
Hi, this diving flashlight what a gift to a friend of mine. One day, he did sth stupid with the batteries and as s result, he destroyed the driver.
As you can see in the pics, the driver has the magnetic sensor of the switch.
I tried to fine a replacement with no result. Do you have any idea where can I find this type of driver? Is it possible to repair the fried driver?
Maybe to ask Ric at cnqualitygoods?
And what you think about these. ?page=1#comment-221088
Same Magicshine flashlight (same body) but with XML
Lightmalls has incredibly good price, but its maybe some cheap low-qualitxy clone with all different internals (o-rings etc) than real magicshine.
Magicshine is it appears seriously in this busyness and they have even one new, I think, mode, SST50, with flat bezel, 2X26650, but little out of my budget currently.
It would be great if lightmalls flashlight is any good because the price is great (but I described everything in that other topic
maybe you can use any driver, adding the magnetic sensor
magnetic sensor (italian)
Your link doesn't work.
In this quoted text? It works for me…
It doesn’t work for me either. If seen pictures of the light that you refer to however I have no idea how it works as I don’t know of any dive reviews for it. If they didn’t change anything other than the emitter it should work.
A XM-L would be too floody for my uses however (I think).
I dont know, its probably some forum glitch… (I see the post fine). But I’ll copy it here than, its from “Dubious and miscallenous deals topic” in deals section)
Regarding MCE versus XML, I though MCE is floodier. I dont know much about MC-E and dont own any, so Im easily in the wrong…
In conclusion to quoted text - I dont think lightmalls has good version. First of all its suspiciously cheap, secondlym reflector is different, it can be seen from the pictures, and if reflector is different (even when compared with XML version on other two webstores), easily more parts are different - and probably not to the better side :slight_smile: Im not prone to pull the trigger, although price is really tempting… Maybe it would be good surfface light who nows, but its probably underdriven… Too much unknown and Im not prepared to gamble with 40$, even if gain would be 80-90$ :slight_smile:
Oh that thread. :p Mr. Admin probably closed it but since you started it you can still view it.
SOmeone not very smart probably got carried away with clicking spam button.
just thought I’d add a couple notes for anyone considering this light
I purchased the sky ray branded version from manafont, for a dollar and change more than the generic - just out of curiousity
1. I agree w/ pretty much all the had to say.
2. there is a little bit of ramping action when you slide the button. What I mean is, it ramps to the level you select within <0.5s. Not a big con, but I would prefer instantaneous because selecting the desired brightness would be easier. I’m sure after some use I won’t notice.
I own the xtar d06. This is about the closest thing to a budget version I’ve seen.
magnetic dimming vs d06
Cons
-fewer levels (~5 vs ~22)
-much lower current on high ( ?1.5A vs 2.45A)
-much higher current on lowest level (a bit painful to look at vs fraction of a lumen)
-anodizing (not bad at all vs super tough)
Pros
-lighter (adequate vs very heavy build)
-knurling (good but not aggressive vs none)
-price ($20-$25 vs $60 to $80)
summary: You get what you pay for with these two. My ideal version would be ‘magnetic dimming’ body with D06 circuit and anodizing.
At some point I’ll test current, and report here, which was the main reason for trying sky ray version. I also plan to test adding some resistance fixes - even though I tested that on the d06 and it doesn’t make a difference.
I like the flashlight and the review is very complete 8)
I just found the same one on aliexpress, Is the same ?
link
Hi, I saw your comment and got really surprised about it, I have this flashlight, I bought it in Aliexpress but is the same one, and when I saw the thin lens I thought it was not going to be suitable for diving….
I would like to know if you have use it more times at this deep, I use to dive at no more than 25m and if you confirm that the lens is strong enough I’ll seal it and give it a try.
Thanks advance for your help.
Best regards form Zaragoza.
