I have a 18650 out on my drive that is bubbling, what should I do with it!???
Actually, the electrolyte solution in the cells isn’t that nasty. It is a flammable solvent, though. Once a cell is discharged to near zero, the chances of it having enough energy left in it to ignite the electrolyte is rather small. The salt-water douche is a good way to discharge the cell fairly slowly and safely. I prefer a, uhhh, more direct method. J)
@Texaspyro, I may be mistaken but I read somewhere that they can vent hydroflouric acid, or was that only for lithium primaries?
If there was HF in there, the shell and copper and aluminum electrodes would be dissolved. You might get some HF if the electrolyte torched off… would depend on the electrolyte.
I have a friend that tortures batteries for a living. He would be long dead by now if there was something really nasty going on.
Well of course it is not actually in the battery, but I know there were a few HF incidents on CPF due to vents.
Scaru, I believe it was a CR123 primary cell in the thread at CPF.
Here’s the thread: Inhaled vapors from battery!!! | Candle Power Flashlight Forum!!!
Edit: More info about HF:
HF is produced at burning. No flames/smoke, no HF
Call the fire brigade.
They have specialist hazchem units who will let you know if it’s actually dangerous,
and how to safely dispose of it.
How the hell can a cell start to bubble? Are we sure its venting or just getting really hot?
I'd let it sit outside for a few days (dont throw it onto the lawn and run over it with a lawnmower though) and then try the saltwater method. If you have something like this, you should be really safe:
Pressure differences pushing electrolyte out of a tiny leak in the seal/can.
Could be expensive if emergency services later sends you a $1,000 bill for their visit. However, I suppose just calling them to ask for info should be free.
Will try and resist doing that….
Thanks for the suggestions, both dodgy cells are currently now sitting under a 20kg solid conrete plant pot, will dump them into salt water in a few days time.
Good idea I might call the fire brigade and ask them where to dispose of them.
Off to the snickers wrapper they go then :stuck_out_tongue:
You could send it to the guy who posted on here yesterday about how to disassemble a li ion cell, he already cut the top off one, he is a graduate student or something.
+1 Very well Said.
Send it to me :P
I think if you tested it at zero voltage it's a door stop why does anyone freak out about a dead cell .unless he went back and edited his post .
It says he tested it at zero volts ..That doesn't scare me ..Should it ? check voltage and if it's dead or very dang dead ..Wrap them separately in little plastic tape them up and recycle them . killer gases comes from the batteries on fire not sitting there doa with no voltage . i ain't scared
If i saw a battery bubbling ... it might get my attention
if I'm wrong ....i'd like to know
Tell me Cat eyes, you use “LSD” Cells to keep you going, don’t you. Just curious, do you insert them Nasally, Intravenously or Rectally. :slight_smile:
just because theres no voltage doesn’t mean everything inside is in its lowest energy state, it just means the chemical reaction isn’t producing electricity, i don’t know much about lithium battery construction, but if there are chemicals that are reactive then you could have a problem, say acids, hydrogen, pure oxygen, materials incompatible with water, air, calcium, magnesium etc.
Hydrofluoric acid is a good example, i’m not getting into the debate of if its in batteries or not, but its an example of something that may not produce electricity, but is still harmful no matter if its sourced from batteries or aluminium etching solutions.
Plutonium is also a good example, I’m not getting into the debate of if it’s in batteries or not, but it’s an example of something that may not produce electricity, but is still harmful ….
CPF meh, they’re drama queens any way…
Awww, now where’s the fun in doing it safely… just boldly go! J)
