Review: Convoy C8 XM-L U2 1B 1x18650 8x7135 Flashlight
212 posts / 0 new
relic38
relic38's picture
Last seen: 4 years 4 weeks ago
Convoy C8 (1x18650, XM-L U2)
Reviewer's Overall Rating: ★★★★★
Reviewer's Mod Host Rating: ★★★★★
C8 Profile
Summary:
Battery: 1x18650
Switch: Tail, Reverse-Clicky
Modes:
G1: H 100%, M 30%, L 5%, Strobe, SOS, with memory
G2: H 100%, M 30%, L 5%, with memory
LED Type: Cree XM-L U2 flux bin, 1B tint bin
Lens: Standard Glass
Tailstands: Yes
Price Paid: $15.68
Date Ordered:
 Mar 4, 2013, , shipped mar 7, 2013, received Mar 14 2013.
Pros:
  • Compact format, comfortable to hold, good grip
  • Excellent finish, immaculate
  • Excellent machining, great threads
  • Excellent workmanship, attention to detail
  • Good heatsinking
  • Nice pill, great retention ring for driver
  • Excellent reflector, aluminum OP
  • Perfectly centered emitter
  • Works with flat-top, raised top, and protected cells
  • Excellent mod host, not that it needs any real changes
Cons:
  • Head is a bit bulky for a pocket EDC, jacket pocket OK
Features / Value: ★★★★★
Design / Build Quality: ★★★★
Battery Life: ★★★
Light Output: ★★★
Overview
Fasttech introduced the Convoy line of lights and gave us flashaholics tons of options to choose from.  Essentially you can pick your host, emitter, and driver current.  It's up to you; even a host only if you like.  Everything from the familiar tubular EDC right up to a 2x26650 thrower.  I introduced myself to Convoy with one of the lowest priced models; the trusty C8.  I have owned three of these before, with mixed quality.  This gives me a good basis to evaluate them.  Hands-down, this is the best built C8 I have ever seen. (Note: I haven't seen the famous XinTD C8, which is reported to have excellent build quality too; at almost twice the price).
The machining and finish on the entire light is immaculate.  I could not find a ding, scratch, sharp edge, or machine mark anywhere.  The anodize is great, it may be HA-III; it looks as good as my EA4W's finish.
C8 standing
This review is mostly pictures; there's not much to say really.  It speaks for itself.
side
front
tail
As a 1x18650 side-by-side light, the handling is fine.  It fits in the hand well, maybe a bit thin for larger hands.  There is enough of a groove near the tailcap to provide for an OK cigar grip.  The knurling is light and provide a little bit of extra grip.
in hand
The light comes apart at the tailcap, and between the body and head.
parts
Unlike many of the other models in the COnvoy line, this does not include brass inserts on the body tube ends.  Understandable, as the lowest priced model in the line-up.
inner ends
The laser etching is even and sharp.
etching
The threads are nicely cut, smooth, were adequately lubed (I didn't need to add more), not anodized (no lockout), trapezoidal, and large enough to stand up to lots of battery changing.
threads
The tailcap has a large plunger with lots of travel. Protected and unprotected cells should work fine.
tailcap
Digging into the tailcap, we find a nice aluminum retaining ring and the usual items; plunger gasket, switch with a long but heavy spring, switch holder, and a GITD switch boot.
tail bits
Moving on to the head, I found something new to me; a C8 pill with a driver retaining ring.  And a very nice one at that (more in a bit).
head end
In here, we find the head components.  This is the typical C8 head design, and it is well executed.  The pill is removed through the reflector end.  The reflector seats onto the star with a plastic emitter centering gasket.  The lens O-ring is slightly smaller than is needed, so when reinstalling, I had to stretch it slightly to get it to stay in the bezel groove.  other than that it works well, as do all of the O-rings on this light.
head bits
The pill itself was not easy to open.  The driver retaining ring was fixed with thermal adhesive.  I needed to use a rubber glove, needle-nose pliers, and a lot of force to break the bond.  What I like about this design is how the driver is firmly pressed into the pill and makes very good electrical contact.
driver
On the other end of the pill sits the emitter which is attached with thermal adhesive.  The workmanship and attention to detail in this area is quite nice.
emitter
Beamshots
Smooth as butter.  Coming Soon.
Measurements
Dimensions:
  • Overall Length: 150mm
  • Bezel Diameter: 44.5mm
  • Neck Heat Sink Diameter: 33.5mm
  • Body Diameter: 25.3mm
  • Tail Diameter: 29.5mm
  • Reflector Inner Diameter: 37.6mm
  • Reflector Outer Diameter: 41.5mm
  • Reflector Depth: 31.7mm
  • Reflector Emitter hole Diameter: 7mm
  • Lens Diameter: 41.7mm
  • Lens Thickness: 1.9mm
  • Emitter star diameter: 16mm
  • Driver diameter: 17mm
Weights (without battery):
  • Overall: 148g
  • Head: 84g
  • Body Tube: 32g
  • Tailcap: 32g
Performance (stock, 4.2V supply, uncalibrated measurement equipment):
  • Light Output: ~725 lumens
  • Beam Intensity: ~21.2kcd
Power Source Options: 1x18650, unprotected or protected cells, flat or raised positive caps.
Switch type: tailcap, reverse-clicky
Modes: High (2.8A), Medium (1.39A), Low (0.16A), Strobe*, SOS* (* in group 2 only)
Mode Memory: Yes
Conclusions
The Convoy C8 is an excellent example of the classic pocket light.  I like just about everything about it.  The only mods I did; add copper braid to the tailcap spring and thermal compound on the pill threads.  Both of these are entirely optional; it's just part of my standard routine.
Relic Recommended, for anyone looking for a well built light at an excellent price.
Thanks for reading! searchID8934
Welcome the night.
My Reviews   My Mods    http://budgetlightforum.com/search?
Edited by: sb56637 on 08/26/2014 - 17:19
relic38
relic38's picture
Reserved
Welcome the night.
RaceR86
RaceR86's picture
Last seen: 5 years 11 months ago
Great work! Nice review!
You may want to take a quick look at the first words in the headline and edit them.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
18sixfifty
18sixfifty's picture
Last seen: 2 years 2 months ago
Nice review and great pictures. That is a great light for the price. Seriously, it should be the one that everyone gets first.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
FlashPilot
FlashPilot's picture
Last seen: 12 hours 22 min ago
It looks like youve found yet another fine example of the venerable C8 at a great price. The driver retaining ring is a great touch and should make those fancy 4A boost drivers a breeze to install. :bigsmile:
Thanks for the great review. I’ll grab one on my next order.
What do you think of this light with the OP reflector as apposed to one with a SMO?
relic38
relic38's picture
Thanks RaceR86, missed that Smile
18sixfifty, agreed. This is the C8 to get. Plus, you have options when you order. Cheap C8s on eBay are $11 or so… for four more the quality goes waay up.
FlashPilot, I like the OP better. It throws less, but I prefer more flood anyway.
Welcome the night.
That Ninja Guy
That Ninja Guy's picture
Last seen: 10 months 4 weeks ago
Thank you for the great review relic38!
jacktheclipper
jacktheclipper's picture
Last seen: 13 hours 56 min ago
I like the Convoy product line .
Cool
What I do
JohnnyMac
JohnnyMac's picture
Last seen: 4 days 1 hour ago
Nice review, Relic. Looks like the entire Convoy line is the bomb!
relic38
relic38's picture
That’s right JohnnyMac, so far every model that’s been reviewed has done well.
Welcome the night.
relic38
relic38's picture
Minor addition to review: This model does not have the brass inserts on the body tube ends. As the lowest price model in the line-up, it’s understandable.
Welcome the night.
zeremefico
zeremefico's picture
Last seen: 1 hour 5 min ago
Convoy C8 vs KD C8?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
relic38
relic38's picture
zeremefico wrote:
Convoy C8 vs KD C8?
I do not have the KD C8 either. I’ve been tempted to go for the XM-L2 version they have listed. I already have three C8s though…
Welcome the night.
rikr
rikr's picture
Last seen: 5 months 1 day ago
zeremefico wrote:
Convoy C8 vs KD C8?
I would say the Convoy C8.. Great review. I know I really like mine.
 New Collection / Old Collection
zeremefico
If it is better than the KD, it is one of the best, after XD.
What do we know about Convoy, I cannot find something about them on net.
My YouTube channel
K40M F16
Spasmod
Spasmod's picture
Great review relic, thank you.
For some reason I was under the impression that the C8 was quite a bit larger than it is. After reading your review, it seems that it’s actually quite small.
That’s a really nice light for the price too, value for money wise, this even beats the A60 ? looks like it.
relic38
relic38's picture
Thanks Spasmod, I appreciate it.
The Jacob A60 will outthrow the C8, even an XR-E based C8. I prefer the C8 because of the size and a little more flood. Having the OP reflector balances it perfectly for me. Probably not for everybody though.
Welcome the night.
blueb8llz
Last seen: 5 hours 42 min ago
zeremefico wrote:
Convoy C8 vs KD C8?
i have the convoy and kd, both are almost identical besides reflector.
i prefer the kd, it throws further and have a nicer warm tint. flood/spill equally the same.
if you dont mind paying about $5 more, id go kd, but if your on a tight budget, the convoy is super nice. one of the better lights out there for that price.
bibihang
bibihang's picture
Last seen: 3 hours 12 min ago
Finally! A review of Convoy C8! Thank you Smile
My Lightmalls C8 with U3 emitter has been arrived and I am very satisfied with it. Before I ordered Lightmalls C8 I was doubting whether I should went for Convoy, but at last I prefered the smooth reflector more.
Next, I am hoping someone will order the KD XM-L2 C8 and post a review about it Silly
relic38
relic38's picture
In Hand shot added to the review:
BTW, there is one Convoy C8 SMO; with a T6 3C (5000K) emitter.
Welcome the night.
relic38
relic38's picture
You’re welcome.
I’ll probably pass on another C8, so it will not be me. I have a host that’s waiting for an XM-L2 U2 on copper. Wink
Welcome the night.
relic38
relic38's picture
I found another error; I calculated the throw wrong by shortening the distance by one meter when calculating it. It went from 11.2kcd to 21.2kcd. Much more typical for a C8.
Welcome the night.
JonnyC
JonnyC's picture
Last seen: 9 months 1 day ago
Thanks for the review! Absolute steal at the price.
light junkie
light junkie's picture
Nice review, pictures can hardly wait for some beam shots, the Lightmalls C-8 was my first budget light thanks to reviews like yours it fit size fit my needs perfectly and the C-8 s exceeded my expectations of out put I agree the C-8 is a must for 1st time flashaholics looks like I missed out on a better price from fasttech. Get those beamshots up
Lj
eebowler
eebowler's picture
Last seen: 2 weeks 1 day ago
relic38: THANK YOU!!!!! :bigsmile:
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
Ouchyfoot
Ouchyfoot's picture
Last seen: 10 months 3 weeks ago
Thanks for the review relic. I’ve never had a C8, and I may pick up the host for this Convoy.
eebowler
eebowler's picture
BTW, I have 6 of these coming in some time in the next month. Two Neutrals Big Smile and two cool.
relic38
relic38's picture
Error. Does not compute… :~
Welcome the night.
eebowler
eebowler's picture
LOLOLOL!!!! hahahahah!! Oops! :Sp That was after working a night shift. 3 neutral white and 3 cool white.
shooderz
Last seen: 1 year 1 month ago
Love my Convoy 3c T6 C8, best C8 by far I’ve got out of four of them. Definitely worth a punt.
sb56637
sb56637's picture
Last seen: 22 min 32 sec ago
Thanks very much for the review! Frontpage’d and Sticky’d.
