Pre-order now ReyLight (TrustFire MINI-02)
120 posts / 0 new
ReyLight
ReyLight's picture
Last seen: 1 day 19 hours ago
payment intro in 19# post.Brother of BLF MINI.TLF Little Bonny, ReyLight, Review here
Pls pre-order,+1,+2,+3,etc. I will count the numbers together with TLF.after 2 days,I will ask factory to make the production.then I will post my paypal here. There will be No spare lights for this order.so pls confirm asap.
SPEC: L/M/H---2/30/100%. starts at LOW,no memory. NW/CW LED, OP Reflector. 1K Hz PWM.
Printing: TLF, Little Bonny(Under it) ReyLight(other side).
Price: NW costs 20$ by HK Post with tracking.CW costs 19$. 2pcs order,1$ discount. 3pcs order,2$ discount,etc. TF 16340 protected battery 2$/pc. driver 3$/pc
 Have a nice weekend. Rey
Edited by: sb56637 on 10/20/2015 - 12:24
Boro
Last seen: 3 hours 48 min ago
2 X NW
4 X TF
Thanks Rey!
zeremefico
zeremefico's picture
Last seen: 6 hours 5 min ago
Rey is back!
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Don
Don's picture
Last seen: 1 year 1 day ago
I’ll take one NW.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Ouchyfoot
Ouchyfoot's picture
TLF?
ohaya
Last seen: 3 years 6 months ago
Ouchyfoot wrote:
TLF?
It’s a (the?) German flashlight forum (http://www.taschenlampen-forum.de/).
Jim
JohnnyMac
JohnnyMac's picture
Last seen: 3 weeks 1 day ago
1 x NW
Thanks, Rey!!
gords1001
gords1001's picture
Last seen: 3 years 4 months ago
1 nw
2 cells
What size/voltage is the driver?
3 drivers
fleibaka
Last seen: 8 years 5 months ago
the same as BLF-Mini
CR123 and 16340 are suitable
no problems with Trustfire TF16340 protected!
fleibaka
fleibaka
I hope my English is good enough for a review.
I translated my german review, and hope you can understand what i have written.
http://www.taschenlampen-forum.de/flashlight-forum/24384-english-review-...
conclusion
a fantastic lamp for a good price
you will not be disappointed Big Smile
fleibaka
gords1001
gords1001's picture
More interested in driver diameter and minimum voltage obviously it can run 2 x aa/aaa cells, but what about 1aa? Thinkng about potential hosts the driver may be useful in.
fleibaka
the driver works with AA nimh, but with less output. in the high level a little bit more then the low level with Li Battery
the outer diameter is 17mm and 15,5 mm
fleibaka
_the_
_the_'s picture
Last seen: 20 hours 38 min ago
One NW for me. Thanks!
Edit: Please add 2 x TF 16340
=the=
raccoon city
raccoon city's picture
Last seen: 21 min 36 sec ago
1 x NW
4 x TF
Thank you, Rey!
tolight
Last seen: 7 years 6 months ago
hi!
is there any way to get the pics up here? I saw the english review but can’t seem to see any of the images… i’d try to sign up on TLF, but can’t read German….
thanks!
Smile
Boro
tolight wrote:
hi!
thanks!
Smile
http://budgetlightforum.com/node/19671
fleibaka
Dear BLF members,
sorry for my english
I hope the pictures linked from TLF are visible
now I will try to the promised review.
I compare the BLF Mini with Mini-02 (ReyLight)
Here, the two minis with their nearest relatives. Are just a little bit shy, the little ones Big Smile
my first impression was:
1st
chic, much fancier than on any picture that I have ever seen. In paintings, she looks plump, and they appear less elegant than the BLF Mini.
Which is not so.
2nd
in thickness, it has increased strongly. Now it is a heavy piece of precious metal in your hand.
The wall thickness of the head is easy to detect. Also be seen in direct comparison: The drivers are 100% compatible
3rd
the weight has increased
4th
in length was allowed to stretch a bit, thus it is also easier to handle.
5th
The build quality is much better, a picture of the key ring holder as an example
6th
In the area of the lens and the corresponding O-ring of the head has been significantly increased.
The increased head and visibly slimmer refector
In this picture you can see well, the depth of the reflector.
What I did not like: (easily correctable things)
1st
The thread is too tight
More on that later!
2nd
hmmm
3rd
hmmmmm
4th
nothing more found
the dimensions and weights:
BLF Mini:
Length: 63 mm including the ring holder
Diameter: 20.5 mm
Weight without battery: 41 gr
Weight with battery: 59 gr
TLF “Little Bonny”
Length: 68 mm including the ring holder
Diameter: 20.5 mm
Weight without battery: 47 gr
Weight with battery: 66 gr
That’s more than 10% weight gain, which can see and feel to each component.
size comparison
The intrinsic values ​​(compared to the BLF-mini):
1st The wall thickness was more than doubled
2nd the inner diameter has been reduced. The diameter is 16.8 mm.
The TrustFire TF16340 protected fits in well, without jamming.
The battery does not come out alone. The battery is measured via the protective conductor: 16.6 mm
Goliath … the little one is stronger than the force of gravity
And now we come to operate the lamp:
As already mentioned, the thread has trouble.
to change that only silicone grease is needed.
Lovingly greased the thread performs its work smoothly.
To operate with a battery-protected, the bias of the spring should be reduced.
The thread then works much better
Here is a picture of the springs.
The inscription on the lamp is wrong, that will be changed in the labeling as described by Rey.
The lettering of the other side
Conclusion:
a great little lamp that has exceeded all my expectations.
The quality is significantly better than the Mini-01
The driver pulls nearly 1.7A with full battery on high, that should be something around 500lm.
The modes can be switched neatly
there is a short flash when switching from high for lo.
The quality is really good
The Mini-02 machining is executed really clean
In this picture you can see the rings. Because I’m having trouble recognizing colors, here is neither a white balance has been made, nor have I tried to capture the color of light.
In real terms, there is a white light but not painful
the light with the smooth reflector and reduced outlet opening, floodiger than expected, which really surprised me.
To see which light image is made, I have briefly illuminated the garden. The setting of the camera is identical in both pictures.
I hope that the quality is sufficient for comparison.
Freehand Beam Shot on High with the “Little Bonny” with cw LED. Battery has 3.8 volts
Freehand Beam Shot on high with the BLF-Mini with nw LED. Battery has 4.0 volts
some outdoor beamshots in better quality
my car with H4 headlights (out of competition)
Solarforce L2n, XML T6 1A, driver with 2.8 A (out of competition)
BLF Mini, XML T6 3C
ReyLight, XML T6 1A
my car with low beam
Solarforce L2n
BLF Mini
ReyLight
BLF Mini
ReyLight
I hope this review helps you
you will not be disappointed: D
best regards
fleibaka
tolight
thanks for the link/post guys! on the radar…!! Smile
Pinetreebbs
Pinetreebbs's picture
Last seen: 5 months 4 weeks ago
2 X NW
6 X TF
Thanks Rey!
ReyLight
ReyLight's picture
<body><p>paypal address:rey.gosea@gmail.com.<br>学锐 叶<br><br>pls leave message when you send payment. such as 1pc CW+ 1pc NW, (19+20-1$)or 1pc NW+1pc driver(20+3$). so I can make a good records. Pls also make sure paypal will show your address. (don't use phone app.)<br><br>BTY,i want to say,final order depends on the payments.i will produce the same according to the paid number.it means posting order on the forums does not count.<br><br>hope you understand.thank you.<br><br>Best Regards<br>Rey
Mulie
Last seen: 2 years 9 months ago
1 CW
2 cells
dusty99
Last seen: 3 weeks 5 days ago
EDIT: I’ll take 1xNW and two cells. $24 PayPal sent.
Thanks,
Paul
Don
Don's picture
PP sent for one NW.
Thanks Rey.
fleibaka
dusty99 wrote:
I’ll take a NW.
A question about the cells: What’s the actual mAh? Are these the gray cells that are rated @ 880mAh? Aren’t those actually running closer to 600mAh? Is there anyone here who has tested one of these?
Rey: I’ll Paypal you as soon as I know a little more about the cells.
Thanks,
Paul
Hello,
http://www.aliexpress.com/store/product/20-pcs-lot-Free-shipping-TrustFi...
Dobanodnao
Last seen: 7 years 9 months ago
I’ll take 1xNW and 2xtrustfire 16340’s.
BTW it looks like the first post got screwed up, it looked fine earlier so something must have changed.
I was looking at the trustfire mini 02’s anyways, loosing that strobe mode and some better spacing would be nice.
tolight
is there a difference between the BLF driver and the regular driver?
ReyLight
ReyLight's picture
i'm very sorry, i wrote wrong. price is 20/19$ for NW/CW,there is no 19/18$ option (without tracking)
Buwuve
Buwuve's picture
Last seen: 4 years 5 months ago
No strobe - only high, mid, low Smile
Light up the darkness.
JohnnyMac
JohnnyMac's picture
PP sent for 1 x NW @ $20
PM sent with transaction ID
tolight
Buwuve wrote:
No strobe – only high, mid, low Smile
ah… ok.. i thought i had caught that earlier somewhere… thanks for confirming!
gords1001
gords1001's picture
Paypal sent
1 light nw
2 cells
2 drivers
$30
Thanks rey.
