the driver works with AA nimh, but with less output. in the high level a little bit more then the low level with Li Battery
the outer diameter is 17mm and 15,5 mm
fleibaka
fleibaka
One NW for me. Thanks!
Edit: Please add 2 x TF 16340
1 x NW
4 x TF
Thank you, Rey!
hi!
is there any way to get the pics up here? I saw the english review but canāt seem to see any of the imagesā¦ iād try to sign up on TLF, but canāt read Germanā¦.
thanks!
Dear BLF members,
sorry for my english
I hope the pictures linked from TLF are visible
now I will try to the promised review.
I compare the BLF Mini with Mini-02 (ReyLight)
Here, the two minis with their nearest relatives. Are just a little bit shy, the little ones
my first impression was:
1st
chic, much fancier than on any picture that I have ever seen. In paintings, she looks plump, and they appear less elegant than the BLF Mini.
Which is not so.
2nd
in thickness, it has increased strongly. Now it is a heavy piece of precious metal in your hand.
The wall thickness of the head is easy to detect. Also be seen in direct comparison: The drivers are 100% compatible
3rd
the weight has increased
4th
in length was allowed to stretch a bit, thus it is also easier to handle.
5th
The build quality is much better, a picture of the key ring holder as an example
6th
In the area of the lens and the corresponding O-ring of the head has been significantly increased.
The increased head and visibly slimmer refector
In this picture you can see well, the depth of the reflector.
What I did not like: (easily correctable things)
1st
The thread is too tight
More on that later!
2nd
hmmm
3rd
hmmmmm
4th
nothing more found
the dimensions and weights:
BLF Mini:
Length: 63 mm including the ring holder
Diameter: 20.5 mm
Weight without battery: 41 gr
Weight with battery: 59 gr
TLF āLittle Bonnyā
Length: 68 mm including the ring holder
Diameter: 20.5 mm
Weight without battery: 47 gr
Weight with battery: 66 gr
Thatās more than 10% weight gain, which can see and feel to each component.
size comparison
The intrinsic values āā(compared to the BLF-mini):
1st The wall thickness was more than doubled
2nd the inner diameter has been reduced. The diameter is 16.8 mm.
The TrustFire TF16340 protected fits in well, without jamming.
The battery does not come out alone. The battery is measured via the protective conductor: 16.6 mm
Goliath ā¦ the little one is stronger than the force of gravity
And now we come to operate the lamp:
As already mentioned, the thread has trouble.
to change that only silicone grease is needed.
Lovingly greased the thread performs its work smoothly.
To operate with a battery-protected, the bias of the spring should be reduced.
The thread then works much better
Here is a picture of the springs.
The inscription on the lamp is wrong, that will be changed in the labeling as described by Rey.
The lettering of the other side
Conclusion:
a great little lamp that has exceeded all my expectations.
The quality is significantly better than the Mini-01
The driver pulls nearly 1.7A with full battery on high, that should be something around 500lm.
The modes can be switched neatly
there is a short flash when switching from high for lo.
The quality is really good
The Mini-02 machining is executed really clean
In this picture you can see the rings. Because Iām having trouble recognizing colors, here is neither a white balance has been made, nor have I tried to capture the color of light.
In real terms, there is a white light but not painful
the light with the smooth reflector and reduced outlet opening, floodiger than expected, which really surprised me.
To see which light image is made, I have briefly illuminated the garden. The setting of the camera is identical in both pictures.
I hope that the quality is sufficient for comparison.
Freehand Beam Shot on High with the āLittle Bonnyā with cw LED. Battery has 3.8 volts
Freehand Beam Shot on high with the BLF-Mini with nw LED. Battery has 4.0 volts
some outdoor beamshots in better quality
my car with H4 headlights (out of competition)
Solarforce L2n, XML T6 1A, driver with 2.8 A (out of competition)
BLF Mini, XML T6 3C
ReyLight, XML T6 1A
my car with low beam
Solarforce L2n
BLF Mini
ReyLight
BLF Mini
ReyLight
I hope this review helps you
a fantastic lamp for a good price
you will not be disappointed: D
best regards
fleibaka
thanks for the link/post guys! on the radarā¦!!
2 X NW
6 X TF
Thanks Rey!
<body><p>paypal address:rey.gosea@gmail.com.<br>å¦é å¶<br><br>pls leave message when you send payment. such as 1pc CW+ 1pc NW, ļ¼19+20-1$ļ¼or 1pc NW+1pc driver(20+3$). so I can make a good records. Pls also make sure paypal will show your address. (don't use phone app.)<br><br>BTY,i want to say,final order depends on the payments.i will produce the same according to the paid number.it means posting order on the forums does not count.<br><br>hope you understand.thank you.<br><br>Best Regards<br>Rey
1 CW
2 cells
EDIT: Iāll take 1xNW and two cells. $24 PayPal sent.
Thanks,
Paul
PP sent for one NW.
Thanks Rey.
Iāll take 1xNW and 2xtrustfire 16340ās.
BTW it looks like the first post got screwed up, it looked fine earlier so something must have changed.
I was looking at the trustfire mini 02ās anyways, loosing that strobe mode and some better spacing would be nice.
is there a difference between the BLF driver and the regular driver?
iām very sorry, i wrote wrong.
price is 20/19$ for NW/CW,there is no 19/18$ option (without tracking)
No strobe - only high, mid, low :)
PP sent for 1 x NW @ $20
PM sent with transaction ID
ahā¦ okā¦ i thought i had caught that earlier somewhereā¦ thanks for confirming!
Paypal sent
1 light nw
2 cells
2 drivers
$30
Thanks rey.
