Review: The P60 budget host trio from MF
ULTRAFIRE P60 TRIO
THE STORY OF THE 3 CLONES WHO TRAVELED FROM CHINA TO EU
It's a story that begun when Surefire designed a 6P flashlight which was a great success. Apparently that sprung a ton of clones around the world. The most notable are The sloarforces who started with the L2. What about the others?
Can others make nice flashlight hosts for less? Yes, pretty much so. Even with variety!
The three P60 hosts are these:
The black one Ultrafire WF-504B - Black
The space one Sky Ray S-R5
The silver one Ultrafire WF-504B - Silver
Machining is good not exceptional but good. Still reasonably well made and for what you pay are quite nice. Actually i don't have any complaints.
It's worth to mention that MF takes time to package these to resist and survive scratch/ding free even the most harsh enviroments. Also known as HK post.
These feature a recessed tailcap button and can even tailstand stock. Even the skyray one althrough not prefectly. Switching the tailcap silicone cover would be probably enough. Why the orange one? Who knows... since they manufacture the orange ones they must find a host to greet it with from time to time. The SKYRAY was the "lucky" one...
Most of the time there is some arguing which P60 are compatible with each other or better will it blend? Pretty much so!
I really doubt anyone would like those that way. If you order all three together thank MF packing policy to not recieve them that way by HK post handling/leg-ling?.
Lego test passed!
How bout the threads? Worth a look? Yep!
Pretty decent long threading on all samples. Notably longer on the black sample. Smooth enough, and all came generously lubed as a surprise. Perhaps someone at MF instructed the manufacturer to do the lube job properly. These were by far the most properly lubed P60 hosts i ever had. It's not a big deal but it is nice nonetheless.
Internals and bezels?
With the exception of the SKYRAY body the internals are the usual deal. You can drop a 16850 battery through the tube easily. The SKYRAY will not allow that. I Like that. Inner diameter is about the same in all and can vary a bit from sample to sample i realized in the last half year. For everyone that like FoyzelsTM (Foy made bezels) these come with non agressive bezels with the exception of the SKYRAY which features a slight crenellation. I guess it sticks with the designs pretty nicely to not bother grinding it down.
For heatsinking these are all about equal... Perhaps the SKYRAY would be the winner since it has more total surface (regardless of mass). The better your dropin is made and the better you wrap it to snug fit in there the better the thermals. Variation from these hosts should be minimal.
These lonely three will soon have their shiny new custom built dropin. Untill then they will shine on my desk to remind me to do the dropins for them. :)
They can be had for much less solarforce asks for their L2. Cheaper and stock deweaponized. You decide if thats enough to buy. I did. :)
I may have to get a Skyray someday. Those are 3 nice hosts.
Of that bunch I have the sky ray and like it. The bezel is pretty nice but won’t fit into a solarforce L2i head. It is too small. Everyone who plays with that flashlight likes it best. $8 you can’t go wrong.
I have the black 504 and the SkyRay. No issues with either one, except the SkyRay's o-ring on the head is so tight you keep twisting it thinking you are still working the threads, when all you have to do is pull at that point to get the head off. For 8 bucks each, I thought they were quite a good deal.
I can dismantle my skyray switch. Not press fit. o.O Use some pointy tweezers to unscrew the plastic switch retainer. Would be better if they bade it from aluminium but i guess you can't have all.
I could take the switch out (and did since the were some flicker problems with it). Didn't find a suitable replacement and put it back, now it seems to have stopped flickering...
There are at least 2 Skyray versions out there with fascinating differences.... there are a lot. One of them is completely different tailcaps. Will do pics to show them....
DX Version ordered 02/26/2010
LT Version ordered 03/03/2011 replacement for switch issues shipped 04/30/2011
Sky Ray S-R5 Above LT 2011 Below DX 2010
Differences: Length of grooves in tailcaps, colour of the bodies, rubber rings position modified for bike light purposes (by me).
Sky Ray S-R5 Left DX 2010 Right LT 2011
Differences: Height of bezel rings
Differences: internals of tailcap completely different, wall thickness of aluminium alloy (LT very thin)...different lanyard holes.... completely different tailcaps except for the orange rubber switch-cap.
Update: Mine is the one from LT .... had also flickering problems... took it apart and they seem gone most of the time (very irritating)....but I didn't change anything... 2 retainer rings ... outer one white plastic with brass metal cap for contact... inner retainer ring aluminium which holds switch (with traditional spring)... light functions well without plastic retainer and brass contact cap. The DX one isn't mine, but it seems to be unscrew-able also, but it didn't have no contact issues in over a year. Most fascinating are the different wall thicknesses on the tailcaps, this fact makes me believe that they are produced in different factories.
That both have the same SkyRay print on them? A cheaper copy of the cheap copy of the SP-6? Amazing.
I have the original batch (With the drop-in that says FIVE MODEL and works fine with 2xCR123A). So the ones sold now are of even worse quality with a pressed in switch? Good luck I didn't order any more then.
EDIT: From the pictures it seems that both your versions have switches that can be taken out?
I know why. It's a cheap copy of the Lumensfactory SP-6 and the original tailcap was orange so of course the imitation has to have one too.
There is also the identical Uniquefire R5 (Which came with an R4 dropin just to confuse people). Mine has the plastic removable switch retaining ring.
I updated the post above.
I always wondered why the Skyray didn't get more praises from BLF members, when it came to build quality. I would rate the old DX ones (host only) very good and the LT one only mediocre, because of the thin walls on the tailcap and the contact problems. On the other hand, the dropin which came with the DX one only lasted less than a month, due to a burned driver. The imprints on the lights are the same Sky-Ray....Hot surface... The only way to tell them apart from the outside is the length of the grooves on the tailcaps.
There are quite a few copies of the Sereph out there ..[ Same factory ? different printing ? ] Which is best ?
I can vouch for the Sky Ray , so far so good .
I have the same tailcap grooves as your DX 2010 one, but the switch internals seems to be as your LT 2011 verson (black cap), unless you mixed up left and right the the lower pictures.
What drop-in did you have in your DX version?
The one I got from Manafont is the same as the LT one. I've never had any issues with it. Mine tailstand perfectly, the button does not protrude although it is as close as it can be. I can see that there could certainly be variables there. It has a nice snappy button too. It seems to scratch very easily also.
So mfm , you are right, I did the old switcheroo in the description on the lower pics ... now corrected.. sorry for the confusion.
LT 2011: Long tailcap grooves, white plastic internals, brass contact cap, thin walls on tailcap.
DX 2010: Short tailcap grooves, black plastic internals, silver steel contact cap, much much thicker walls on tailcap.
So Manafont is selling the better version, which is like the old DX ones?
And Lightake the not-so-good one?
Damn should have ordered at Manafont , they seem to be better and cheaper.
This was the DX Version ordered on 02/26/2010 ... advertised as XP-E R4, but came as an XP-G ..probably R5 .... man DX hasn't updated this mistake in over a year.... overall still the best 1*18650 host body for a bike light together with this bike mount, when the first rubber ring is removed.
My DX driver lasted less than a minute. They said it would work with 2xRCR123.
It wouldn't.
The DX one didn't even survive a 18650 battery. Host very good - dropin very bad ... at least back in 2010.
This pic is from MF shows short grooves and a hint of a brass conctact I believe... so it's all a big lottery:
To add more confusion, This is one ordered from MF a few months ago. almost a hybrid of the two.
Strange, no 1st plastic retainer ring... looks like alu ... it gets stranger by the minute.
Is the switch looking like this, held by a second retainer ring made of alu?:
This one came from MF one month ago
