I got a couple of these chargers with the hope that they can help me weed out some of the bad batteries as they come, and so far some of them has indeed triggered the “FAILED” message on this charger. Does anyone know how the charger determines if a battery has failed?
I’ve been using mine using a USB charger that is capable of supplying 1.3A (because I didn’t like the ripples that come after end of charge when you use the 12V power supply) and it takes seriously long to charge up a cell.
It is my understanding that the intelicharger is safe and does charge AAA batteries, but you have to charge 2 or 4 of them at once to reduce the charge imput to a safe level for AAA batteries. Says so in the instructions. Or charge them along with other batteries in the charger. You will need a battery in #1 and# 3 or # 2 and #4, or one battery in all 4 slots if charging AAA batteries. I have charged some with no problems that I can tell. I am happy with my Intelicharger so far.
Thanks HKJ for your very fast response! :bigsmile: Two quick questions (sorry for hijacking the thread). Which charger would you look at if you are charging CR2? Also I have the TR-001 and planning to charge those CR2 using magnet spacers in TR-001 at the 3.0V option, would you recommend it?
Thanks very much for your professional advice once again. Probably would try it.
By the way just a compliment. I really enjoyed your reviews (though I don’t know much how to really interpret the diagrams) of chargers, batteries and also flashlights. Amazed by your extensive collection of batteries, and small flashlights
Just received this charger from Fast tech and the included wall charger states the output to be 12.0V - 0.5A. Should the output not be 1A? Soshine packaged Huawei switching power adapter model HF-120050U3.
Good review and discussion. I ordered one on AliExpress.
I plan to use USB power to charge my Li Co non-IMR 14500s, the peak power is low enough and I don’t think starting at 0.8A average will hurt them.
It appears to me to be very well designed and maybe better than the Xtar WP2 II, if the quality is as good. The pulsing after charge is complete to maintain voltage seems a good feature, in case one wants to leave a cell in the charger to have it ready at maximum charge. The reduced charge rate as the voltage rises with USB appears to be to avoid overloading the USB port. The only thing I miss is an option to charge to 3.9 or 4.1 V, which may extend batter life. (At least some hybrid cars don’t fully charge or fully discharge their batteries, in order to extend battery life.) As it is I can only do this by watching the voltage LCD display and taking it out.
Thanks! Ordered one of these, as I was looking for a USB powered single channel NiMH AA charger for a bit. Seemed to fit the bill. Have also wanted to get a rough capacity measure on my 18650 laptop pulls, so seems to be a win win.
