I’ll be posting a build thread as there’s a couple of configurations I want to try for others interested, there’s not been an l2 build thread yet.
That driver definitely needs to be tested for fit for someone wanting to push an xm-l2.
That said the driver in alexgt’s thread appeals to me more as its shallower, easier to fit and can have the sense resistor “adjusted”, plus I already have one and it has no stobe, thats putting me off the 5a driver, that and its already killed an xm-l u2, it might be over 5a….
The MT-G2 would be an interesting flooder with A large throwish spot. I have a similar project in the works, different host
To give a little teaser, the beam is near perfect for a flooder, and the host seems to handle the heat OK. Oh, and I’ll be doing an MT-G2 copper sinkpad How-To with this mod. Should be fun!
I love my mtg-2 build, as I said at the time, its subtle how much light its throwing out, for this oneI want to do something different, I do however wish to confirm it’ll fit, as I know there are a few showing interest in the mtg-2, s good host would be a nice find.
Cant wait for your build relic, oh, I pointed a new member at you and tom e, hope you dont mind, he might be after a couple of gun lights.
XM-L2 on copper. Copper pill, 3-18 volt 3 mode IOS 5 amp driver. I cant see anywhere where it says what batteries it uses. Looks like 26650. If its not convert it to take 26650's. Have fun with what ever you end up doing.
Too wide. And if the one I linked to is too long… Well, I remember correctly, the one from intl-outdoor is longer…
The light uses 2x26650
EDIT: Checked a review the L2 (Fasttech site).
“This torch takes a 20mm driver with ~11mm of space available behind the driver for components.”
The one from intl-outdoor would certainly not fit. And now I see why the one I mentioned would be too long (could probably be possible to make it fit though)
An XP-G2 on Sinkpad at 2.8amps (stock driver) netted ~70K lux @ 1m for me. I was not able to get the de-domed XP-G2 to focus: the reflector would not sit far enough down to remove the big hole in the center of the beam without shorting… I used quite a bit of solder on the pads so may be able to focus it by removing some and the screws.
The one from intl-outdoor is a nice driver. Personally Im not a fan of the loud PWM noise on the one from intl-outdoor (its quiet on high), and the mode changing is slow.
I believe its the same LCK-LED store sells for a higher price here.
(press picture to see the one they sell, thumbnail is wrong picture). They have size specs on it. I assume that is for the correct driver.
To those with experience. How is the noise on the 5A drivers from LCK-LED store? Are they quiet? I cant see anything about PWM. Option 1 Option 2
Well… another quick play with the XP-G2 de-domed: I did manage to get the reflector lower down… the result to eye (just sent the lux meter back to its owner an hour ago) is between 100-130k lux. The hotspot does have a sort of corona around it (although weak)…. my guess is the reflector really needs an XM-L/ XM-L2 to achieve the best results.
I would not be at all surprised if you could manage >160K lux with a de-domed XM-L2 at ~4amps (on copper) in the host… better yet would be 6 amps.
My guess is you will end up with a corona / secondary stage in the hotspot if using XPE.
For $40 you get 1/2 a Kg of well machined aluminium which is begging for an LED pushing 20W. Considering the alternatives for that $40 the L2 I think offers very good value for money.
My only concern is the anti-reflective coating does not seem to be very durable.
Without trying to derail this thread.
The IOS driver has a very slight hum on med and low. I can only hear it if its very close to my ear. Yes it does take its time changing modes. About half a second which to me is ok. The temp regulation works perfectly unlike other drivers I have used. Voltage range works with one to four 3.7 volt batteries which was one of the attractions to this driver for me. I have no experiences with the drivers linked to. I can tell you about this driver though as its still going strong in one of my lights. http://www.lck-led.com/constant-current-circuit-board-modes-p-935.html?cPath=135
Extremely noisy on low and med. High on a single led is 6 amps, med is 5 amps. High temp protection does not work on my driver. I can report that 6 amps to an XM-L2 led even on a huge copper pill is a waste. 5 amps is brighter. This will eventually be modded with a copper star for a direct comparison with the ally star.
Thanks for info…
BTW… you said you have no experience with the drivers linked to, but the one you linked to and said you had experience with was the “option 2” driver I linked to.
Anyway, Ill stay away from that.
Gords, do you have experience with the “option1” driver ? The driver you have…
right, I did see this before, but couldn’t give the answer the response it deserves.
option 1 :-
I have this driver, but its only been powered up long enough to fry an xm-l u2 so I couldn’t do any in deapth testing.
option 2:- the link is not working, I’m wondering if its this one that you linked lower down?
In my case its hooked up to an mtg-2, seems to be giving 6a on high, but I forget the other readings roughly polite low useful medium omfg you have a sun in your belt high :bigsmile:
Having just rechecked, with the light held to my ear I can just about detect a slight ring on medium, I’ve never noticed it before but its far from obtrusive. That said, there’s a hell of a lot of mass in the cd-v7 host its in.
I did just notice this 9a driver but it wont fit, the pill deapth is the killer on this l2, I honestly thnk the answer is the driver I linked in post 12, then do the resistor mod, if I can squeeze one of my pots in there, even better :bigsmile:
