Tools Recommendations? Need Soldering iron, Multi-meter, etc....
I’ll add to the list some long needle nose pliers for removing pills and switch’s.
http://www.harborfreight.com/5-3-4-quarter-inch-needle-nose-pliers-40696.html
While you are there might as well get this to.
http://www.harborfreight.com/12-piece-precision-needle-file-set-4614.html
and this
http://www.harborfreight.com/helping-hands-319.html
I know most of the items have already been mentioned but they have a lot of useful tools in one store if you have one near you. They also have 20% off one item coupons online, this is the place where I find mine.
If you want to go cheap they have this also, although I would recommend the hobbyking hakko 936 clone mentioned above.
http://www.harborfreight.com/30-watt-lightweight-soldering-iron-69060.html
One more: Shining Beam has a fairly inexpensive tweezer… used to unscrew various things using the prongs, plus you actually use them as tweezers to pick things up :)…
Jim
Wow, you guys are awesome! So many things I never would of thought of (the helper, magnifying glass, braid/suction, flux).
Here’s what I’m about to order from Amazon: (going to get that multimeter and some 18650’s from fasttech as well)
Iron: Elenco Soldering Station (40W Iron) comes with extra tips!
Helper: TEKTON 7521 Helping Hand with Magnifier
Desoldering Braid
Rectorseal 74026 3-Ounce C-Flux
How does that sound thus far?
Here’s a reasonably priced soldering iron…
http://www.sciplus.com/p/540-WATT-VARIABLE-SOLDERING-STATION_48254
…you can get files and all sorts of useful gadgets/tools from this place (American Science and Surplus)
I do not know about that Elenco iron, but it looks like it has temperature control which is important. Question to ask is, can I buy new tips for it easily? Good thing about the Hakko clones is you can buy replacement parts for it, e.g. heating element, new pen (should you need to replace it), etc.
My only suggestion would be an auto-ranging multimeter rather than a manual-ranging one as suggested above. Though it’s much more expensive, but the convenience is superb.
I’ll piggyback off this thread… any better soldering stations than the 936 clone for under $50 shipped? Or is that the best you’re gonna get? I have a few other hobbies that require a soldering iron and I’m tired of the shitty 30w radioshacks lifting traces on vintage electronics. That could be a combination of OE and bad tips though.
The 937d, I think it’s the same station but with an LCD showing temp… So can’t really say its better I guess…
Sounds like they aren’t temperature controlled either.
But they’re the finest that 9.98 can buy! Say it ain’t so!
Step up to a better DMM if you want reliable tailcap currents. Use a 20% off coupon and get this Mastech 8229 clone from Harbor Freight for +/- $36 (or wait forever for it to go on sale and get 20% off the sale price). Amazon link to the Mastech 8229. PilotPTK recommended!
-Garry
Try the UT-61E, just make your own leads, short and thick, those they come with are not good as you measure in series of course you get a lot of resistance. At least the physical build quality of the DMM is top notch.
Hi,
It’s been a long while since I’ve bought a new meter, but back then, I had generally been avoiding auto-ranging, because I use to hate that the readings on the meter would usually fluctuate for awhile before the auto-ranging kicked in and settled down.
Is that still the case with the newer meters?
Just curious…
Jim
I only have one auto-ranging multimeter (the one I linked) and the auto-range when measuring batteries voltage takes less than a second. I didn’t feel there was a “delay” at all. I’m not sure about other multimeters or higher-ends ones (I think there are higher-ends one like Fluke that would take some time to settle.)
I’ll link some Youtube to show the speed of the auto-range I get on that multimeter.
http://www.youtube.com/watch?v=Ln59xlYvaaM (watch 10:20)
http://www.youtube.com/watch?v=ZBbgiBU96mM (watch 16:20, 17:40)
Is the Mastech MS8268 available in another shape? someone that re-branded it but changed the external appearance?
As mentioned above, no need to spend big bucks and Harbor Freight is your friend if you have a store nearby:
I don't have any expensive tools. I have a very old/cheap Sperry Multimeter that I have used for ~20 years (?) similar to this one:
http://www.amazon.com/Gb-Electrical-Digital-Multmeter-DM4100A/dp/B000NNKDMO/ref=sr_1_8?ie=UTF8&qid=1364997416&sr=8-8&keywords=sperry+multimeter
...and a cheap 25W soldering iron I bought at Wal Mart many years ago.
From Harbor Freight, I would definitely buy the following items:
Helping Hands - $2.99: http://www.harborfreight.com/helping-hands-319.html
Needle Files - $3.49: http://www.harborfreight.com/12-piece-needle-file-set-468.html
Needle Nose pliers - good for unthreading retaining rings - $2.19: http://www.harborfreight.com/5-3-4-quarter-inch-needle-nose-pliers-40696.html
Strap wrench set - for unthreading tight flashlight bodies - $4.99: http://www.harborfreight.com/2-piece-rubber-strap-wrench-set-94119.html
Dental Pick set - $3.99: http://www.harborfreight.com/6-piece-pick-set-93514.html
Hobby Knife - $3.99: http://www.harborfreight.com/hobby-knife-with-five-fine-point-carving-blades-96739.html
Survival Knife - Just because it's cool - $8.59: http://www.harborfreight.com/8-inch-hunting-survival-knife-90714.html
Other good items (listing Fasttech because they are currently my favorite):
Desoldering pump - $2.59: http://www.fasttech.com/products/0/10002629/1195701-aluminum-alloy-desoldering-pump
Desoldering braid - $1.75: http://www.fasttech.com/products/0/10002730/1202500-goot-wick-soldering-remover-20mm-x-15m
Soldering paste - Makes tinning wires/contacts and general soldering very easy - $3.28: http://www.fasttech.com/products/0/10003546/1261003-chips-repair-tool-soldering-paste-grease
Fujik Heatsink Adhesive - $6.15: http://www.fasttech.com/products/0/10000468/1049304-fujik-heatsink-silicone-thermal-glue-50ml
Flux - for cleaning/helping solder adhere - $1.15: http://www.fasttech.com/products/0/10002129/1153800-amt-amtech-professional-soldering-flux-10ml
This is awesome. Thank you for putting in the time to compile this.
I had a very long response ready but I navigated out of the page and lost everything :frowning:
Chloe: It comes with extra tips. To buy more it would be ~13$
I ordered the Equus 3320 because the price was right, reviews were good, and I don’t need all the fancy extras at this point.
Had I known Harbor freight was so close to my house, I would have just gone there! I’m in IL near Chicago, I should have known.
You guys have been great. Everything has been ordered, the only thing I’m missing are tweezers, a desoldering pump, and a hunting knife :slight_smile:
yup, when working at your dining room table, you need a rather large hunting knife stabbed into the table beside you. keeps people from bothering you while your hard at work :wink:
Added... Emery boards! Cheap, come in a 10-12 pack from Wal-Mart; very handy for sanding the edges of drivers to fit...
I just received these tweezers from FastTech. They feel very nice and solid. No bending them while cranking on a tailcap retaining ring. I also ordered these plastic tweezers (so as not to short any connections), but I haven't used them yet.
-Garry
