The star the LED is currently mounted on is a standard 20mm star. If you were to go for a higher current through the LED, you'd be better off with a copper star or one of those SinkPads which would do wonders with the heat generated.
I can't seem to get the brass driver-retaining ring out with my tweezers, but measuring the diameter thread-to-thread of the housing around that ring, I get 22.36mm. So a 21mm driver should fit just fine.
Crappy. I can tell you exactly what park you were in your shots are so good. Thanks for the shots and strangely I can relate to nearly all your torches (flashlights to half off the world).
I’d just like to back up ramblings here, this light is awesome, I am hellish impressed with mine, infact I’m waiting on it going dark so I can go out for another play test session.
Its also a really easy build, I would though suggest people go with the ld-29 driver from fasttech and xp-g2 if they want to keep things a little more sane, on this build, that would mean three simple solder connections in total and stupid amounts of throw J)
The model of the XinTD C8 was noted briefly but I'll restate it here, it's the U3 bin with the 1C tint.
I got it from intl-outdoor here. It's the 3-mode non flashy one but that doesn't really matter.
the xin td c8 is very impressive throw considering the reflector diameter…it’s not left too far by L2.…
I guess maybe my X9 can be out throw by the xintd u3
