Twelve NEW 2400mAh 18650s, under $30?
Hi,
Oh, ok….
No, I don’t resell lights :).
It’s just that I’ve just gotten interested in lights fairly recently, and there’s a TON of stuff to learn about (for me).
I have a technical background, but it’s been all work, while this is actually FUN, so it’s like “a kid in a candy shop”… and, BTW, I think I’ve mentioned on other threads, my wife is already starting to hate it, because of the pile of lights, batteries, chargers, and rigamarole that I’ve accumulated in the last 1.5 months.
Jim
Haha, yep, same creative spelling in the ebay listing.
Is there good evidence that any cells made in China are automatically 'retreads'? That's not a leading question, I'm truly asking. I know about some of the quality issues, like everybody else I got burned years ago by the Chinese capacitor scandal, but capacitors and batteries are different animals. Lots of circuits still work passably well even when some or all of the capacitors are completely ineffective... for a while, until they vent. Can they really use river water and ox dung in a LiIon cell and have it still work?
I would dearly love to have a tackle box packed full of fifty Panasonic 3400's or Samsung INRs, but not so much I'd be willing to give up food to get them.
These aren't HP packs, they're aftermarket replacements. The genuine HP-branded OEM packs use LG - at least based on the one sample I opened.
edit: The OEM 12-cell pack for the HP DV4 used LG cells... they may use something else for other and/or newer models.
Nearest Home Depot is ~90 miles away... :(
Fenix 18650 has also BAK cell.
http://lygte-info.dk/review/batteries2012/Fenix%2018650%20ARB-L2%202600mAh%20(Black)%20UK.html
They’re $89 now:
but not available in any stores near me :)…
Jim
Crude but interesting results...
Solarforce S1100, 3x18650 in series, w/low batt warning that trips at 3.3v/cell. Tailcap draw is 1.22A, current delivered to the emitter is 3.3A.
All cells fresh off the charger, start voltage of 4.21V.
Samsung INR18650 15Q, runtime on HIGH: 1h08m
BAK/CJ 6K00112, runtime on HIGH: 1h30m
comfy,
I’m losing track of this thread. Are the “BAK/CJ” ones you mention above the ones from the $30 laptop battery (the one I just bought :)!)?
Jim
P.S. Are we sure that the BAK/CJ ones are actually manufactured by BAK?
YES.
Hi,
I wanted to keep you all up-to-date. The one I ordered is now in Secaucus, NJ, on its way to me in VA. That’s the same place the orders I had from Tmart.com came through before.
The unfortunate part is that in the 2-3 orders I got from Tmart in the past, the shipments seemed to sit in Secaucus for a couple of days. Hopefully, that won’t be the case since this was purchased through Ebay, but we shall see I guess :)…
Later,
Jim
I got mine in 6 days, including a weekend, from NJ to MS. USPS is weird like that sometimes.
Comfy, are these good readings? I’m not familiar with this light. Also are you saying these are good cells or not? The reason I ask is because I actually want one for my HP, so it’s probably a better deal for me than anyone.
I will have to get the one in Reduk’s link of course, but I presume they are the same.
Marc.
Still in Secaucus, NJ today (Tuesday)…
It's just a runtime comparison between an unknown cell and a known cell in fairly new and excellent condition, the INR 15Q (1500mAh).
I have a Turnigy MAX80W on the way, maybe I can figure it out well enough to get some real data finally.
Ok, good stuff. Discharge test would be excellent. Looking forward to them.
Thanks,
Marc.
comfy,
Got this pack in, but having a hard time finding somewhere to get “into” the pack. The one I have is sealed pretty tight all around? Where did you go in initially?
I was expecting that the connector would be the easiest place to start, but even that seems to be sealed up pretty good :(…
Jim
I think I had to chisel a starting point with the screwdriver, for sure it was one of the corners around the connector opening (doesn't really matter if you poke the circuit board, as long as you don't short anything). Don't remember to which side, though. I've already thrown out the plastics so I can't go back and reverse engineer it for you. Wasn't that tough, but I was using the magic pliers on them.
Hi,
Ok, got the case separated.
What I did was use a pocket knife I have (a whetstone) and run it down the seams several time, to cut some of the glue or material down in the seams. The “back” seam, the one on the opposite side from the connector was actually pretty weak, so after I had done that a couple of times, I then took a flat head screwdriver, with about a 1/4” head, stuck it into the seam and twisted. That started spreading the seam. I did that across the back seam a couple of times, then the seam kind of popped open at a corner. I separated the sides my grabbing and pulling them apart (it wasn’t easy!).
I thought that once I had the two halves of the pack apart that it’d be downhill from there…. wrong :(!! The darn batteries are in quintuples, each with the + ends all tied together with metal bands/strips and the - ends all tied together with metal bands/strips, and each quintuple is GLUED with some white stuff, really hard, to the casing.
So there are 3 quintuples in the case, end-to-end.
Struggled with getting them up. I didn’t want to stick anything in, for fear of damaging the wrappers, so I kept trying to twist the casing, and, amazingly one of the quintuples, the middle one, kind of popped out of the casing. Then, one of the quintuples on the end I was able to pull out, but the last one (isn’t that always the case?) was a heck of a time getting it out, again, just kind of twisting the casing and pulling on the batteries.
Again, I thought I was on easy street… wrong!!
Now I had 3 quintuples of batteries with each battery in each quintuple bound to other batteries with metal strips, and these metal strips were kind of wide, and I was trying to figure out how to separate the batteries.
So I did what I did previously. I took a knife and carefully going in between the batteries, tried to cut the strips.
Then, SPARKS!! And, one of the batteries started feeling a little warm.
Ran outside, carefully dumped the quintuple into a ceramic container on our driveway (kind of reminded me of a couple of other thread on BLF the last couple of weeks). Thank goodness it wasn’t raining today!
Waited awhile then took a look. It turns out, I think, that the problem was that I had nicked the wrapper on one of the batteries, near the top corner on the positive end, and the metal connector that I was cutting on the + end must’ve touched that exposed area, probably causing a short:
I eventually got all 12 batteries separated, and the metal strip things removed… but wasn’t easy, and some of the batteries still have that white stuff stuck to them.
The main things were:
1) The glue holding the battery quintuples to the case
2) The metal strips/tabs connecting batteries within the quintuples was very wide, so it hard to get in there without possibility of shorting something or damaging the wrapper at the + end of the batteries.
3) My wife is kind of ticked off at me now for this little “adventure”, so this may be the last pack for me :(. Besides, I have like 25+ 18560s now :)… And that was not counting these 12.
comfy,
How did you remove that white stuff from the batteries. I think you mentioned some chemical, but is there any “normal” chemical, something that I’d have around the house, like alcohol, that can be used to remove it?
Thanks,
Jim
