Could you drill a hole instead of a slot? You would need to pre-wire the tube then assemble the tubes with tape and a bead of JB weld to permanently hold the bodies in a bundle.
One other thought, why not use two bodies with four batteries to feed current to a third shortened body that only holds the LEDs and the switch? You could have about three or six volts depending on batteries type and series or parallel connection.
As far as batteries, yes, there are lots of diffeent configurations. It all depends on what one wants. 6xAA, 3x14500 in parallel, All kinds of things could be done.
OP is updated. Thanks to Pinetreebbs I decided to go ahead and make it a 4AA light. That way I don't have to cut tubes and cut new threads for the tail caps. I don't like that chore.
I’m just finishing off what I have “in stock”. Once the stock is gone, the modding will shut down and I wanted to finish off with a couple unique lights.
I'm still waiting on the EA8 though. I might actually keep that light, LOL...
I have not made any custom order lights. It makes me nervous. It’s one thing to mod a light and have it fail, but when you do one for someone else it can’t fail. So I avoid doing orders from people.
Someday that may change, but not in the near future.
Well, to update this, I don't have anything new. I have set this aside and will not touch it for a few days. Other issues have taken the limelight. Hopefully I will finish this mod in the next week or so. Right now I am spending time with my favorite Chiropractor. My "Spring cleaning" just about cleaned my clock, LOL.
I hope Chiropractors are cheaper in the US than Aus. Better yet just take mind expanding pain killers. There cheaper than Chiropractors and you can do a heck of a lot more when under there influence. Just stay away from rotating saw blades. :_(
I threw this project away, in the circular file. The next day I couldn't stand it and got it all back out again. Now it works and it is in the final paint stages. More photos are in the OP.
Justin have done it again!
Its quite a good looking “Frankenstein Mini Maglite” you have made there! I think that is a cool name for it.
It turned out be be a very nice and unique build! Great work!
