I bought a MAHA C9000 and I have been very happy with it. I have also found that after the newness has worn off, I’m more and more interested in just getting the batteries charged. I just want to pop them in a charger and take them out when they are done. MAHA is adjustable for when you want to charge a little faster but I’m liking the simpleness of my inteli4.because it charges my LiOn batteries too. I have not heard that it is important to discharge MiMh batteries all the way down before recharging them. That is important with NiCad batteries because they have a memory.
I really don’t worry about my Enloops and how many times they will recharge anymore. By the time they wear out, I will probably be dead or batteries will have improved to the point that I will want new ones anyway.
I have both, but the algorithm that the maha uses is better. The I4 uses a lower current (more time to charge the battery), and does not use a dt/dt algorithm so i wonder the end of charge detection is good. It seems good because the battery do not heat up, and checking the charge with the maha, it’s almost as good, but still, makes me wonder.
Also, if you charge AA eneloops, you just pop them and after 10 seconds the maha starts a 1Ah charge, perfect for 2100mAh eneloops. No buttons, just pop in the battery in the charger.
About the discharge of NiMH: Is good to do a full recycle every 20-30 cycles. Remember the rates: 2100mAh cell: 1000mAh charge, 500mAh discharge. 2 hours rest after charge and after discharge.
I’ve not had any trouble from either of my Angeleyes. OK, they are less flexible than the Maha C9000 - but around here, the best price for a Maha would buy me three Angeleyes. And leave me enough for a (small) beer.
Mine have never overheated a cell - ever and I’ve had them for years.
I do remember reading somewhere that for 1G Eneloops (I have quite a lot of these) they should not be charged above 950mA. But I’ve never been able to find that again.
On finding them at Fasttech, I’ve got another one on its way to me just now.
Some of the C9000s have been known to have issues too.
But I’ve heard too many horror stories about LaCrosse chargers (mainly the BC-900 but I have heard such stories about the 700 too) to ever touch one. The Other Plaice used to have lots of discussion about these devices - if they haven’t lost it in one or other of their blowups.
Some misinformation i’ve seen on this thread (correct me if i’m wrong with references please)
NiMH don’t have a memory effect (or if they do its negligible) and will last longer if charged as needed, fully discharging before charging has little capacity effect and uses up more cycles (out of the 500-1500 on the eneloops)
Charging above 0.5C also reduces longevity, they can be quick charged, but charging at 500ma or less will give the most charge cycles. (some non eneloop batteries i have won’t take over 200ma, they either terminate early or get too hot to hold even though they are less then 60% charged)
Hi Bort, the info I posted about refresh and break-in were taken from the manual that came with my Angeleyes charger.
What you said about charging non-eneloops is interesting. I have some Philips 750mAh AAA's that the Angeleyes does not want to charge, yet they hold some charge (enough to light a Tank007 TK-703) and can be charged with my old Uniross dumb wall charger, but this charger makes the batteries hot.
Since I have some dead Uniross NiMH¹ that have bubbled wrapping from repeated charging in the Uniross charger I don't believe heat is good for batteries. I was charging them almost every day since I used them with a digital camera.
1. I hope these won't explode or leak. I know I should throw them out but I want to dispose of them properly.
i’m guessing the fully discharge information was recycled from Nicad batteries
i have some duracell 2650 mah that terminate prematurely on charging at 500ma or higher, and a crummy rayovac model that heats up like an incandescent lightbulb if i try 500ma
wow yeah thanks everyone for the info. I got my i4 today and compared to my crappy charger it is night and day already! I think I will stick with this for a while and research a bit more before I make a decision. but for new cells I would say the 375 ma per channel will be fine (and believe it or not, it’s a lot faster than the other charger I was using). as my cells get older i will definitely get a charger with more functions.
also, I was under the impression nimh was best to discharge all of the way before putting them back on the charger…but are you saying that topping the cells off early is better than draining and recharging? this is how I have been charging my li-ions and I from what i understand, 2 half charges on li-ions is about equal to 1 full charging cycle off of the batteries and is easier on them in the long run. plus it’s nice to keep them topped up. so is this okay to do with nimh as well?
I keep my nimh fully charged, there is no data i know of that say this reduces their life
li ion on the other hand age faster when kept at full charge, 40% is supposed to be best for longevity, but from what i am told up to 80% is fine too
If you keep the thermals down, charging at 1c does not harm at all. Check the engineering papers from Sanyo. Charging from 0.5c to 1c is the best way, if thermal is controlled and charge is terminated correctly. A 1c charge gives a very good termination voltage for end of charge detection.
If you charge at a lower rate (0.5c is the minimum!), the end of charge is harder to detect by the charger, and easier for the cell to be overcharged and damaged.
You could charge at 0.1c in a timed way from 16hs, but LSD cells like the eneloops are VERY sensitive to overcharge, so you must be very sure to play your cards there, ir you will damage the cells. If you want to do that way, charge them less than 16 hours. 14 hours for example.
BatteryUniversity.com page on nickel based batteries
about 3/4 down that page under
” It is difficult, if not impossible, to slow-charge a nickel-metal-hydride. At a C rate of 0.1-0.3C, the voltage and temperature profiles fail to exhibit defined characteristics to measure the full charge state accurately and the charger must rely on a timer. Harmful overcharge can occur if a partially or fully charged battery is charged with a fixed timer. The same occurs if the battery has aged and can only hold 50 instead of 100% charge. Overcharge could occur even though the battery feels cool to the touch. ”
If you have 750mAh AAA, the maximum charge current for them is 375mAh. Higher, and you risk overheating and also damage the cells.
Heat is the CANCER for NIMH batteries. And for LSD batteries, is even worse.
From what iv’e read, nimh’s can be kept fully charged.
Li-Ions should be kept at 40-80%. Every 1 month is recommended to do a little discharge and charge to keep the cell healthy. Do not store in a place where the cells are exposed to heat. Also remember that li-ion cells age from the time they exit the manufacturing process. A never used 2 year old cell will have worse performance that a newer cell.
At 500ma charge my charger hasn’t failed to detect an eneloop charge end point. I gave 2 examples of batteries that can’t even take 0.25C. Most dumb chargers overcharge the batteries making them very hot, even many of the cheap eneloop chargers are not smart chargers yet are sold with the eneloops and when i had looked into them most were 500ma.
The bc700 does miss end points sometimes, but interestingly not on eneloops or duracell lsd, but on other lower quality batteries.
How do you control the temperature, fans, liquid cooling, dry ice? Is it worth it to charge faster and reduce life expectancy?
The eneloops chargers that came with the batteries are the perfect example of marketing over engineering. They are crappy chargers.
Most chargers that are being sold just use maxV+timer to end the charge. Very BAD.
To avoid overcharge and overheat is better to use a charger that uses all termination methods: dv/dt, maxV, thermal and timer.
To control temperature, my MH-C9000 has a temperature cut off, but i always put a little computer fan, just in case. Y preffer the maha over the lacrosse, but both are very good.
I found out about maya about the same time as I was transitioning from nicad to nimh. The maya 204x series that require pairs of cells were good at the time but cooked the batteries. I bought a maya 9000 last year and love it.
I, like Chidwack2, rarely use the special features any more. It is a whole bunch of buttons to push. I usually just drop the battery in the charger and let her rip. I could probably do the same with the i4 sitting next to it except I move the 12v plug from one to the other depending on what I am charging and charge nimh a lot more than lithium-ion. I will go through the [down][enter][enter][enter] after I insert each cell to discharge/recharge the batteries when I think of it and am recharging overnight, but it is a pain. I do feel confident that it is doing a decent job on my enloops. Plus the display at the end is reassuring. All I get out of the i4 is 3 LED’s not a blinking to tell me it is done.
Honestly, if all you want to do is shove batteries in a charger and come back to have them charged, the i4 is a good choice. The i2 is probably a better choice if you own any low capacity lithium-ion’s so you don’t have do do them in pairs and know what slots to use. But, if you are charging a lot of nimh’s, the maya 9000 is a great choice, as are the maya 800 and 801’s. The 9000 having all the bells and whistles and the other two doing a great job of recharging lots and lots of nimh’s along with the ability to discharge/recharge them.
So, back to the original topic. Are the extra features “necessary”? No. Are they worth having? That is a judgement call. They are to me.
Hi fractal! What info is displayed at the end of charging? Oh, and welcome to BLF! :party:
I like the info my Angeleyes gives me at the end of charging. The backlight also turns off, so it’s easy to tell if it has finished. The simplicity of the i4 was quite appealing.
