Alex - this is a sick mod! Since this is designed for throw pretty much, would be great to measure it. If you don't have a light meter, bunch of BLF'ers in Tx that do. Q's:
- What is Flitz? Probably been mentioned, but not familiar with it or where to get it
- you dremel'ed out the PCB dielectric layer, but not clear what you did with the hole? Maybe I'm confused...
Yea it was kind of dumb to leave a plastic tape between the copper and the heatsink, it is much better now
I do not have a light meter and most of my lights are not stock I will post a comparison beamshot against a 35W HID I think the modded TN-31 can hold its own against that monster.
I did not drill a hole with the dremel, I just scraped the dielectric layer off until I got to the copper
Very good step by step instructions. I think that anybody who feels confident enough to fellow your procedure will and up with a awesome light. These TN31’s can be really beastly when modded. Heck, they are very impressive bone stock.
I'm suspecting they want electrical isolation, which is what you lose when you have a direct copper thermal path, like in a SinkPAD. Interesting, I've asked this before about the SinkPAD's but guess no one seems to know. Original MCPCB's has the substrate layers to electrical isolate the middle pad of the LED, but with a SinkPAD type of MCPCB, you lose that isolation.
Then why the substrate layers in standard stars? Thought it was mentioned they were there to electrically isolate the middle pad for the battery negative running through the body. Maybe something left over from older design LED's?
"The pad is electrically isolated from the anode and cathode of the LED and can be soldered or attached directly to grounded elements on the board or heat sink system."
Not sure though if the housing could be considered grounded.
but I wouldn’t be surprised if it’s simply cheaper to produce MCPCBs with a dielectric layer under the thermal pad than without. I imagine that in common designs, the dielectric that isolates positive and negative traces is the same as that which ends up beneath the thermal pad. Thus, eliminating/removing the dielectric in the thermal path would necessitate an extra step. Just a guess, and I could very well be wrong.
Slim - could very well be, but makes you wonder why ThruNite engineers designed it with that kapton tape there... Electrical isolation is the typical use of it, but maybe they were just playing it safe and being overly cautious, thinking it wouldn't impact the heat transfer much. You would think they would do thermal testing, but who knows what really goes on in the design/prototype phases with these manufacturers.
Ok, I was offbase here... Wow, this sounds like a ThruFire brand . Maybe this is some of the quality problems people have been experiencing with ThruNites lately.
What I suspect is that it was some sort of surface protection for the copper PCB and it was supposed to be peeled off prior to instalation, it is like the very thin kind of tape the factory puts on the back of new watches and the user has to peel it off before use.
When I first removed the led PCB the copper back looked the same color as the copper wire used in transformers, that is what gave it away, then when cleaning it to remove the white thermal grease, it started to peel off.
I was able to source an extra stock TN-31 copper PCB from another member who moded his light, when it arrives will check the back for the presence of the tape and post pics if its there.
wow thanks for the how-to! just wondering which SMD resistor that one is. unfortunately i don’t have a pic of the tn31 so i just stole turbobb’s k40 pic, i hope he doesn’t mind. is this the one? i hope tn31 has a similar pcb
Yes that is exactly the one, you just solder another smd resistor over it and the current will increase, BTW while you are soldering an extra resistor you can also upgrade the base of that spring with more solder.
