oh btw don’t use Flitz on any thermal interface. it gets into the pores of the metal and inhibits thermal transfer. instead use thermal grease to polish the surfaces. doing this impregnates the metal with conductive particles
i learned that the hard way when i was working on a watercooled 172-Watt thermoelectric cooler
The resistor mod does not alter the other levels as far as I can tell, only the highest level is what gets boosted.
The digikey part number for the 1206 0.082 ohm SMD resistor I used is P.082AVCT-ND,
Thanks for the tip OC, I did clean both parts with alcohol before using AS5, and I know the results are better than what came from the manufacturer, I can tell right away the led module heating up fast when in use, so the thermal transfer must be working as planned.
Alex,this is a great tutorial thanks for sharing.I will eventually do this mod when I have time.Can a 20mm sinkpad be used instead of the factory board?I assume it's smaller than the factory board but would it be a disadvantage to do so?
I have done these mods to my supbeam but now it has problems.
It only lights up on mode 1 & 2, all levels past just stay at m2.
even the strobe. standby turns the light off. But wen it is all together the
Tailswitch does nothing. The light just stays on. I hope this makes sense
And that someone knows how to fix this prob.
I wasn't worried at all of damaging the light because the thick rubber strap lies between the flashlight body and the aluminum frame of the wrench.
Update: I was desperate to crack open the 7G9 a while back, and went to HD or Lowes and bought a nylon strap wrench for about $30, it's solid too but the wrench itself did some damage, and was difficult to secure the nylon strap with a one hand operation. I find these aluminum/rubber ones much easier - really had not much of a problem opening the TN31, didn't need to use hot water or a heat gun either, and it seemed to have just as much caked up LockTite as the 7G9 did.
Thanks for the great recommendation Tom E. I just ordered a pair of Boa’s. I wonder if they would be enough to crack open the large bezel of a TK70? :bigsmile:
I also have a nylon strap wrench. It looks more like a cast iron pipe wrench handle with a strap at the end. Its great for holding rough metal but not so good with delicate aluminum.
I did the resistor mod and got a nice bump in lumens and throw, and am now finally getting around to the LED mod. I found the same kapton tape on the bottom of the star, as Alex described. here's a pic showing it after I partially tore it off:
Also, I did a continuity test after removing the U2 LED, and found that there is a direct thermal path to the bottom of the star. It even looks like it's direct path by how the tracing shows through as the raised portion on the top of the star in this pic:
I don't know, I could be wrong, but I don't think there's a reason to dremel off a layer, or use a SinkPAD, at least on this one (mine). Maybe this changed? This copper star is 2mm thick compared to the 1.5mm of the SinkPAD, so if it could be kept as is, it would be an advantage, specially since you can screw it down and have more clearance for the wires. The wire clearance is even more important since I'm upgrading from 26 gauge to 22 gauge.
Here's a view of the machined pattern on the top of the pill, along with the piece of kapton I tore off. Also, that copper on the bottom of the star had a lot of ridge lines on it too. All this will be sanded to 2500 grit paper.
Here's a pic of the new silicone 22 gauge wire (from Hank at IOS), and the original 26 gauge wire laying in front:
Got an XM-L2 U2 1A (supposedly) soaking now in gas for the de-doming . I'm thinking/hoping of getting 320+ kcd out of this.
Edit - oh, realized I didn't answer your question directly - yes, the pic is after cleaning up the thermal grease. They used white colored grease, not gray, so it couldn't be AS5, could be Fujik, or could be another Arctice grease though, couldn't tell.
I sanded the heat sink (alum pill top) and star at 8 levels, up to 2500 grit, that's all, then I used AS5.
Oh! The gas de-doming only took like 2 hours, finished and tested. No battery carrier mods at all (yet), but using Pana PD's (not even fresh):
lumens: 1,332 at start, 1,275 at 30 secs
throw at best, measured at 4.31 meters: 347 kcd, which is 1,178 meters at 1/4 lux (moonlight)
So, got the results I was hoping for. Actually, the throw should be higher, and I'm thinking will be if measured at a longer distance like 15 meters, but not sure. Wow - it's really an intense beam.
