So the total mAh/Ah rating of the pack is determined by the number of cells in parallel, right? I thought I had it figured out, then got confused somewhere, trying to get back to where I was before... :Sp
Yes, you are correct. The volts add in series and the amps add in parallel. 2P (2,900 x 2 = 5,800) and 3S (3.6 x 3 = 10.8).
EDIT: Not sure why a smiley is showing at the end above.
Sorry, I was so flustered by the voltage thing, that I didn’t bother to note the discharge results :(… I know you all are probably getting tired of hearing that, but trying to be candid here.
If you google the NCR18650 and MH12210, it looks like it comes up with a Panasonic 2900 mAh battery, with same wrapping style, so I think that that’s what these batteries are.
I have the next set going now, I’ll try to remember to check the discharge.
Jim
One last question ohaya. Sorry for all the questions. I’m wondering if the “C 9907” is date code. Usually the date codes are in faint characters that are formed by perforations going lengthwise on the side of the cell. Usually the last part is a date code. Do you see anything like that on the side of the cells?
Hi,
I may’ve mixed batteries from the 2 packs I have, but just pulled one battery, and it has:
Large “C” smaller “Y”, and under that
9926
another one has:
9907
That lettering goes around the battery, near the - end of the battery.
So what do those date codes signify? Sounds like both are from 1999?
Jim
BTW, all the batteries have “Made in Japan” on the gray wrappers.
Jim
They will be much newer. The letters stand for the month and year. Y will be pretty recent, but I don’t have the date codes in front of me. I will get back on that.
I just looked through the Panasonic data sheets and such on these cells. They have all kinds of warnings, but not one mention of taking cells to low voltage being dangerous. The closes thing I could find was the following:
“Overdischarge can damage the performance of the battery. Equip the unit with a mechanism to
prevent overdischarge, especially in situations where the user may forget to turn the equipment off.”
Voltage falling due to long term storage should have much less negative impact than overdischarging it through an actual load, right?
Much better that the cells sit unused for 3 years than sit in a laptop that stays on the charger constantly for 3 years, too.
I’m assuming that discharge protection would have been in the Fujitsu battery pack circuitry?
I don’t think these have individual protection circuits. The wrappers on the negative end don’t go “around” to the flat part of the negative end, but only down the side, to within a couple of mm’s of the bottom, so I’m pretty sure about that.
Jim
Yes the pack's circuitry handles the protection function, and also does the balancing for charging - that's all the crazy little wires going every which way inside.
Looks like I was wrong about the letters being the month and year. That must be for Sanyos or some other maker. The four numbers are the date. Looks like yours were made in September 2009. Check out post #66 here:
Ok, thanks. Here’s a shot of 2 of the different pack batteries:
2009 is not so bad?
Jim
Just noticed the “12…” numbers in the picture. That’s not on all of the batteries though. The “4.12V” is my own notes.
I don't know if I'll buy any of those batteries, but I might buy some other Fujitsu stuff. Maybe another tablet to add to my pair of Fujitsu tablet pc's. :)
I don’t know if I’ll buy any of those batteries, but I might buy some other Fujitsu stuff. Maybe another tablet to add to my pair of Fujitsu tablet pc’s.
Hi,
I think that these are all gone already anyway… Last time I looked, that seller didn’t have the “new” ones anymore.
Jim
I bought some unused versions of these cells a while back. They have a “2525” code and C9V (the 9 is above the V). The 99xx code is most likely a date code, I don’t think that 99xx can be assumed to be 1999 or 2009.
Charging new li-ion batteries is a completely different animal than charging li-ion batteries that have been repeatedly discharged too much. I believe 1.9v is the optimal voltage for factory fresh batts before their first charge. There is a white paper pdf floating around on the net about this. From Moli corp or panasonic or someone similar.
As I understand it (from the nasa white paper i believe), the danger of crystal formation occurs after REPEATED overdischarge below 2.5 volts and then recharging. If the batteries are indeed new (and that’s a big “if”), then there is NO danger of crystal formation because there has NOT been repeated OVERdischarge cycling. Crystal formation needs mutiple cycles to form. And as we know, the crystals form, rip the interior catalyst bag and then the dreaded venting with flames occurs. So if there has NOT been repeated overdischarge, you SHOULD THEORETICALLY be safe and fine. Whether the cells are capable of a full charge is another story.
In fact, NASA found that overdischarging SINGLE cells and then recharging did not produce venting. Venting occurred with PACKS containing multiple cells.
I am NOT a battery engineer, so this info should not be considered completely accurate. I could have misread or misunderstood something I read.
Hope this helps!
Hope this helps!
Ubehehe,
That seems about what I’m experiencing… the initial 1.9V, etc. If you ever find that paper, please post a link!
Thanks,
Jim
Hi,
I’ve taken a couple of batteries through charge-discharge-charge-discharge-charge cycles. At the end of the 3rd charge, the batteries were at 4.15 - 4.20V.
I then did another discharge test @ 1A discharge on both batteries. I don’t know if I’m doing something wrong (I’ve only had the Accuccel for a couple of weeks now), but when I did those batteries, I got 633 mA, and 849 mA.
That doesn’t seem right? Too little, since these are supposedly 2900 mAh batteries?
Jim
P.S. The 2 batteries that I charged last night/this morning (losing track of days and nights here :laughing: have been holding their voltage. Both of them are about the same voltage as after the final charge that I did last night/this morning.
Thanks again ohaya for the hard work you are doing testing and reporting. I’m pretty weak in this area of knowledge. It seems like the 633 - 849 mA is not right due the the amount of time you stated these cells took to charge. Hopefully, one of the folks with deep knowledge in this area can help out.
I think I should get mine tomorrow. I don’t have any test equipment beyond DMM’s and an used oscilloscope I just got. I can do a crude run time test using the same flashlight against a fairly new NCR18650A (3100mah) so see what that indicates.
