They will be much newer. The letters stand for the month and year. Y will be pretty recent, but I don’t have the date codes in front of me. I will get back on that.
I just looked through the Panasonic data sheets and such on these cells. They have all kinds of warnings, but not one mention of taking cells to low voltage being dangerous. The closes thing I could find was the following:
“Overdischarge can damage the performance of the battery. Equip the unit with a mechanism to
prevent overdischarge, especially in situations where the user may forget to turn the equipment off.”
I’m assuming that discharge protection would have been in the Fujitsu battery pack circuitry?
I don’t think these have individual protection circuits. The wrappers on the negative end don’t go “around” to the flat part of the negative end, but only down the side, to within a couple of mm’s of the bottom, so I’m pretty sure about that.
Yes the pack's circuitry handles the protection function, and also does the balancing for charging - that's all the crazy little wires going every which way inside.
Looks like I was wrong about the letters being the month and year. That must be for Sanyos or some other maker. The four numbers are the date. Looks like yours were made in September 2009. Check out post #66 here:
I don't know if I'll buy any of those batteries, but I might buy some other Fujitsu stuff. Maybe another tablet to add to my pair of Fujitsu tablet pc's. :)
I bought some unused versions of these cells a while back. They have a “2525” code and C9V (the 9 is above the V). The 99xx code is most likely a date code, I don’t think that 99xx can be assumed to be 1999 or 2009.
Charging new li-ion batteries is a completely different animal than charging li-ion batteries that have been repeatedly discharged too much. I believe 1.9v is the optimal voltage for factory fresh batts before their first charge. There is a white paper pdf floating around on the net about this. From Moli corp or panasonic or someone similar.
As I understand it (from the nasa white paper i believe), the danger of crystal formation occurs after REPEATED overdischarge below 2.5 volts and then recharging. If the batteries are indeed new (and that’s a big “if”), then there is NO danger of crystal formation because there has NOT been repeated OVERdischarge cycling. Crystal formation needs mutiple cycles to form. And as we know, the crystals form, rip the interior catalyst bag and then the dreaded venting with flames occurs. So if there has NOT been repeated overdischarge, you SHOULD THEORETICALLY be safe and fine. Whether the cells are capable of a full charge is another story.
In fact, NASA found that overdischarging SINGLE cells and then recharging did not produce venting. Venting occurred with PACKS containing multiple cells.
I am NOT a battery engineer, so this info should not be considered completely accurate. I could have misread or misunderstood something I read.
I’ve taken a couple of batteries through charge-discharge-charge-discharge-charge cycles. At the end of the 3rd charge, the batteries were at 4.15 - 4.20V.
I then did another discharge test @ 1A discharge on both batteries. I don’t know if I’m doing something wrong (I’ve only had the Accuccel for a couple of weeks now), but when I did those batteries, I got 633 mA, and 849 mA.
That doesn’t seem right? Too little, since these are supposedly 2900 mAh batteries?
Jim
P.S. The 2 batteries that I charged last night/this morning (losing track of days and nights here :laughing: have been holding their voltage. Both of them are about the same voltage as after the final charge that I did last night/this morning.
Thanks again ohaya for the hard work you are doing testing and reporting. I’m pretty weak in this area of knowledge. It seems like the 633 - 849 mA is not right due the the amount of time you stated these cells took to charge. Hopefully, one of the folks with deep knowledge in this area can help out.
I think I should get mine tomorrow. I don’t have any test equipment beyond DMM’s and an used oscilloscope I just got. I can do a crude run time test using the same flashlight against a fairly new NCR18650A (3100mah) so see what that indicates.
No problem, as I’m kind of curious about this kind of stuff :), but it is puzzling, and a bit frustrating so far.
One other/new thing that I’ve found, that I didn’t mention earlier, is that I’ve been testing trying to charge a couple of these on a “normal”, non-hobby charger, a TrustFire TR-003p4, that I have. The strange thing (to me) is that it seems like that appears to work “better” than the Accucel, in the sense that, for the first set I tried in that, it actually brought those batteries up to 4.20V, without all of the discharge-charge rigamarole that I’ve been doing with the Accucel. One thing with that is that the TR-003p4 won’t charge the batteries in their initial state, at 1.9V. The lights stay green, i.e., the charger either doesn’t “see” the batteries, or thinks that they’re already charged.
So, what I did was put each of them into ANOTHER 1-battery charger I have, for a few minutes, which brought the voltage up a bit, to 2.5V+, and then put it into the TR-003p4, which then “saw” the batteries (red light). I did that with 4 of the batteries already once, and they all got charged to 4.20-4.22V.
I haven’t had a chance to try a discharge test with any of those on the Accucel yet, because it’s tied up with the other stuff :(…
I started another thread, because I’ve been seeing a “VOL SELECT ERR” on the Accucel, which stops the charging. I don’t understand what’s causing that :(…
BTW, I do have a “theory” about why the TR-003p4 appears to be working better than the Accucel: I think that whatever is causing the Accucel to get that “VOL SELECT ERROR”, it’s causing the Accucel to stop charging the battery, basically stopping the Accucel from fully charging the battery.
On the other hand, the TR-003p4 doesn’t seem to have any problems that cause it to stop charging the batteries prematurely, so it keeps charging them until its termination voltage, ~4.20V.
I really need to try a discharge test on the Accucel with one of the batteries that I charged on the TR-003p4, I guess :)…
I think that I’ve figured out why I was getting those low results from the discharge tests. Basically, it looks like the Accucel will, for some unexplained reason, stop the discharge test, even though the battery is showing something like 3.7+ volts.
So, I’ve been re-running a discharge test on one of the NCR18650 batteries, and when I stopped at 3.72V, I noted the discharge, and then started the Accucel discharging again.
