Lang - Like Tas said, it has mode memory and it's a nice, tight interface similar to the Ultra Fire driver. No lengthy waits for mode retention and because it is so well programmed (for lack of a better description) the blinkies really are not a bother with this drop-in.
Full disclosure however: I'm not part of a SWAT team and I simply do not care for strobe functions. I respect others' need for this annoying feature but I hate it. What would bring this and the Ultra Fire drop-in closer to perfection is an ultra low, low with no noticeable PWM. My 4Sevens Quark AA2 Tactical has an awesome 0.2 lumen low that I absolutely love.
Unfortunately, I've been told my DMM will not measure amps high enough for these drop-ins so, I don't know if the performance difference is emitter or driver. I know I love the tint.
I'll be reporting more on this drop-in after some use at work. Today it seemed to have some UI issues if I screwed the reflector down all the way. As I write this I remember that I'm using a Solarforce SMO so, maybe the underside is different. We'll see when I get home.
I have the same problem with different drop-in. What could be the reason? If I screw the reflector more than half way down, there's only the high mode. It does not change no matter what. If I just barely tighten the reflector all 3 modes are accessible. It's a home-made drop-in using Nanjg 101-AK and XP-G R4.
I just ordered the Manafont 3-mode XM-L the the other day. It sounds like it's proven, although the U2 does look slightly brighter in your excellent pictures.
It's not just you Sash - it's even more noticeable on a white wall indoors. My unscientific analysis is that it might have something to do white its whiteness.
I ordered the manafont XML reflector for this drop in and was questioning whether I really needed it. I’m glad I did now. Do you think the reflector on that drop in is shorting it out or damaging the solder connections?
I haven't damaged anything yet. Because it looked off-center right out of the package, I disassembled and took pictures in case I needed documentation. Then, while at work I took the drop-in out, removed the reflector and reinstalled. The light would not power up and I immediately suspected the reflector. Sure enough; after I loosened it maybe 10%, the light worked. That night, after again pulling it apart/putting it together the light powered up but when I entered the lower modes it became only slightly less bright. Sort of in between the modes I suppose you could say and the strobe was real fast, like way bad PWM. As before, loosened slightly and all was well. I happen to have an extra SMO (from where?) that seems to have fixed the problem.
None of this should deter anyone from purchasing this awesome drop-in. The more I use it the more I love it. The UI is so well executed that the flashys simply are not an issue for those (me) that don't care for them. It is far and away the best of the three XM-L drop-ins I have.
This is one instance when my hyperbole is well justified - this drop-in will make any flashlight a celebrity.
Okay, just to confirm; my Amprobe 5XP-A cannot measure amps that high? When I try to do it I get whack numbers that mean nothing or it says eRRoR. I'm still having a hard time believing this DMM cannot do something so simple.
I know doing these reviews without basic hard data is green-pea/wannabe . . . I will solve this during this next week. Gonna go to Fry's and see what's on sale.
And it seems to be more purplish than the MF dropin. I really like warm (or slightly green) hotspot tint on mine, but that purple spill is awful. Don't know you, guys, but I really use spill a lot, and that tint just "killing" this great dropin :( Yeah, the hotspot on this (KD) one looks better, but until I found good, white spill, will not buy any dropins more :~ I prefer dimmer one, but with nice tint.
Looks like 200 mA is the highest it can go so look for 10A on the dial or anything over what youll be measuring should be ok. If you also notice the hole where leads go says 200mA max, so if you get 10a will say 10a max
I have the same issue with an old Fluke I have ....2A max for amperage. Instead of buying a new cheap multimeter with unknown accuracy, consider making a shunt.
Here's some directions, among many others doing a google. Cost probably a buck for the banana plugs, you probably have the right guage wire laying around. Accuracy will be better than any cheap DVM cause you're now measuring the voltage drop across the shunt.
