I recieved my new skyray King today, and wow its a real Retinaburner for its size. I will be doing a test comparison to my other big lights and beam shots as soon as the snow melts and it gets a bit warmer outside. :bigsmile:
The SRK has got to be the illumination bargain of the century for a flood light. With the 3 terroid driver version pulling 6.5A from the batteries, its driven hard enough to give 10 min of whitewall hunting, or 30 min of sustained outdoor use before becoming to hot to hold. Mounted as a bike light, it stays cool enough to run constantly in high mode for well over an hour before it starts to dim.
I have bought quite a few Skyray Kings for family and friends over a long period of time and kept six for my own use around the farm, some Gold some Black, some older XM-L ones and some XM-L U2 ones as well as the cheap and nasty lookalikes that I have thrown into the bin quite a while back.
When you get the good ones they are just fantastic and the best ones I have had so far are the ones from Ric at CNQ. I was wondering if the King will ever go to the U3 LED. The XM-L U2 updated models have a noticable increase in the lumen output and it is a bit better in throw without loosing any real spill. More lumens and throw for the same old low price are always welcome in my collection. Another mode so that the light levels could be spread out a bit more would be handy to have. Has anyone tried modding the King with U3 LEDs?
I am thinking of building the ultimate SRK that would give any torch a run for its money. Starting with 3 Luminus SST-90 big emitters, then a custom machined 4-26650 cell body or a longer 8-18650 body mod. J)
Just got my first SRK from Fasttech for $36 delivered 7 days from placing the order. I got the C3PO gold version. It came in a sturdy white box very similar to the one pictured from the OP except it had an extra sticker that had the “SKY RAY” logo. Same foam insert in the box. Spare O-ring, slightly darker lanyard. It is definitely brighter and more floody than my Shadow SL3, although it might not be a fair test since the battery in my SL3 was not topped off before the rough comparison. Also, I was running the SRK on only two cells. But if it holds, it is the brightest in my collection so far.
Anyway, the only real complaint I have so far is that the edges on the bezel are a bit sharp. Instant turn-off for my wife as she is sensitive to things like that. If you put it in a coat pocket it could snag. Anyone try smoothing down the edges? At least I won’t have to worry about the wife claiming this as her own!
Hi guys. I’ve just pulled the trigger on one of these lights, and not wanting to sound stupid, but would it be best to run it on protected cells or would it be ok on unprotected?
I don’t own a king (yet) but i smooth down the edges on some of my lights.
Especially ss/aluminum (single alloy) bezels smooth down, almost without any visible difference still having a HUGE difference on how sharp they feel.
The original king has a stainless steel bezel, i have heard of coated bezels on mimics but i’m not sure if that would reveal a different color metal beneath (if i had to guess, i would say it wouldn’t).
What I would do is find a piece of fine sandpaper 1000 grit or so, wrap if around my finger and work on the sharp edges, with increasing pressure, checking every few passes.
Try not to touch anything but the edge when working with the sandpaper.
If you want even smoother edges you have to start with lower grit sandpaper first.
I have yet to regret sanding down something sharp on my flashlights, even painted portions, as this makes me use them more. (i guess i hate sharp edges as well)
