http://fasttech.bluepromocode.com/fasttech-promo-code/latest/
it's work for me.
just get a new charger.
thanks guys for sharing!
it's work for me.
I tried to use BLF when purchasing a Nitecore TM26 from Fastteck……did not work?
thats because its speed with an H :bigsmile:
BLF still worked yesterday, but there are two fields where you can put codes, use the first one, not the 'action coupon' or whatever it was, I can't remember exactly
Crap….could have saved some money. Still….they are selling the TM26 at a “hard to believe” price!
All 3 coupon codes work just fine, tested 10 seconds ago...
Nitecore TM26 -> less: ($12.58)
ARGGGG |(
Maybe you spelled BFL wrong. :bigsmile:
What is LBF*? :P
*Light Budget Forum :D
Just joint and order Nitecore MT1A with “BLF” code, aware of “pricecontrol” code after read this thread, not tested yet.
So thanks to this FBL forum
Do these codes work on all products?
BLF code works and gives 5% off on all battery and flashlight related products.
Only on flashlight and battery related products.
TENOFF gives 5% off all products.
That’s what I said!
I could of swore that you said something different. Oh well!
I thought I heard you say that!
TENOFF gives 5%.
Only in China…
moderator007:TENOFF gives 5%.
Only in China…
It used to be 10% off for real actually…
IndyArcher: moderator007:TENOFF gives 5%.
Only in China…
Yes it did. I found the code searching the web one day. Fasttech reported back to someone, that it was some kind of special code that they had given to someone, that wasn’t suppose to be used by the public. So they kept the code but changed the % amount.
