Nice to see a flashlight equipped with an MTG2 finally making it to market. The current is slightly less than my MTG2 Torchlite, but this Crelant has a larger reflector. I do like the side switch, but would have preferred it flush mounted, but having a hidden strobe/SOS makes up for it. I also wish they hadn’t used a battery carrier, but from the photos, it does appear very heavy duty.
If the price is reasonable, I’ll have to decide if 1,800+ lumens will be enough for me. Considering most of my lights are about 2200-6000 lumens, I doubt this Crelant will de-thrown my Skyray King, which is a more compact powerhouse of a light.
I’ll keep an eye on this thread and wait for more details.
OP reflector, interesting... 550 meters? Dunno - Crelant streched those numbers before. Agree it's good to see an MT-G2 on the market, glad it's from Crelant. The UI is interesting, been waiting for a 7G9 upgrade like this but the 7G10 is a different animal.
From the size of the emitter and size ratio with reflector, I would imagine it has a decent hotspot not overly large but definitely not a thrower, and that spill will be substantial. Am I wrong?
madecov will be stocking them soon, he also shared with me the msrp, map, and what he might sell them for depending on his costs/shipping etc - his price seems very fair - if you are interested you should pm him
Yes guys I have them on order and they should ship via air early next week. I also have coming the new V01A (AAA-10440)
It comes in 5 colors, has two output levels (3 lumen and 108 lumen) and I think it is a twisty with a pocket clip. It will be UNDER $20.00 and not by a penny
The 7G10 has a high MSRP & MAP but, I think I may do a coupon just for it to get it down to a reasonable level. I know this is the wrong forum but thought I would post a teaser.
I'm in the midst of run time testing but the answer is no. At very initial turn on, it hit 1900 briefly before dropping after a few minutes to a semi-regulated state of ~1600lms. It'll then run in this state for ~45min before starting a gradual decline.
I noticed that first "high" mode, preset by manufacturer, is actually not highest that it can do! I don't know if it's 80-85-90% but it is not 100% and you can notice the difference if you ramp up second, so called "low" mode, until it blinks 3 times (signaling it's on max), then, when changing modes you can notice the difference...
7G10 is very nice light but Crelant, please, add one more mode also add mode memory for a god sake, or make it programmable by user :P
@Sirius9 - On my sample, even after a program cycle to High (max released after it blinks) it's only as bright as the preset High. It may very briefly hit 2K lms (on my PVC LMD) but in a matter of seconds will be back down around 1700lms range (tested on freshly charged cells). I also tested this on the "Low" mode as well and couldn't get it any higher than the factory "High" mode. As a matter of fact, after programming the Low to max output and then shutting off the light and turning it back on, there is absolutely no change in output when switching between High to Low.
interesting, maybe they done something differently with 7G10 (it is a totally new emitter so the driver had to be designed from scratch) but 7G5CS, UF-C20 (rebranded 7G3CS) and UF-T80 (rebranded V6CS) all have this behaviour...
