Theres not going to be any screw on bezel as there is not enough material. From the edge off the lens retaining ring to the end of the housing is just over 1mm and wall thickness in that spot is 1.3mm. I know your trying to tempt me but it’s just is not going to happen.
I should of mentioned, one handed on off is a simple operation. Mode changing is a little harder. The driver somewhere along the line has also decided to come alive and is now delivering 3 amps. To much for this poor little led so i will run it on LiFePo batteries. High measures around 1.2 amps with these. The shortened reflector also works surprisingly well with a nice hotspot and lots off spill.
Ok, you win. Ive missed the start off the F1 race now. As the end of the reflector is flat l’ve machined a groove in it to take an o’ring so its now bath proof. I hope your happy. :heart_eyes:
Thanks ChicagoX but I’ve along way to go to get near your ability. I love your work. Enough said.
A pigs nose? You learn something new everyday. I just have to work out now how to make a pigs nose tailstand.
It’s easy. All you need is a sows ear and some sugru. Or, add threads to the outside with a knurled sleeve. (I just want to drool over more threads and knurling)
Nice work MRsDNF!!! I did that... Brain OFF while working.... this last week. I did just the opposite of you. I now have an extra tube ready for the next light! Ha! Glad to know I'm not alone.
The knurling looks fabulous! Good threads are a blessing, however obtained. If it works smoothly one handed then you’ve obtained success. Really like the size and style.
Hmmmm, I’ve seen that “pigs nose” somewhere before……
It looks really nice. It's a great idea to built in a key chains loop. It looks really cute against his giant brother. Has the big flashlight a name like Monster, Tower, Brave (I give special flashlights nicknames).
You have quickly become one of my heroes! Awesome job! I've watched your knurling skills improve over time and now you do some of the best I've seen. Kudos!
I’d really like to see the knurling being done, it’s always puzzled me how that’s accomplished. Beautiful when done like MRsDNF doing it, not so much when done wrong!
Truly professional work there MRsDNF for sure! You do know, don’t you, that anodizing is the next step? When you pull off a deep purple anodize on that little light you’ll be crowing like a Sunrise rooster with 50 hens!
Thanks again guys. I do have access to a sandblaster which I have used on another light. Which part would you sandblast?
The dodgy driver died last night. It went into a direct short somewhere. There is no burning on the housing but one off the chips looks a little sad. I need a driver that will handle voltages from .9 to 4.2 volts. Theres one at FT but its a little big in depth.
