Test/Review of UltraFire UF26650 5000mAh (Flame)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 8 hours 14 min ago
DSC_2033
Official specifications:
  • Brand: UltraFire
  • Color :Black + red
  • Type :Lithium Ion
  • Model :26650
  • Mark Capacity :5000mAh
  • Actual Capacity :4000mAh
  • Battery Voltage: 3.7V V
  • Rechargeable: Yes
  • PCB Protected Board :No
  • Application :Power supply
  • Working voltage: 3.7V
  • Charging limited voltage: 4.20+/-0.02V
  • Standard voltage: 4.2V
  • Discharge cut off voltage: 3.00V
  • Charging Current: 0.02 C5A (80mAh)
  • Standard charging: 0.5 C5A (2000mAh)
  • Standard discharge: 0.5 C5A (2000mAh)
  • Quick charging current: 1 C5A (4000mAh)
  • Max continual discharge current: 1 C5A (4000mAh)
  • Operating Temperature: charge: 0°C~45°C; Discharge: -20°C~60°C
UltraFire%20UF26650%205000mAh%20(Flame)-info
These batteries are protected 26650 and the limit is rather low for the size.
DSC_2031 DSC_2032
DSC_2034 DSC_2035
DSC_2036
DSC_2037
DSC_2038
UltraFire%20UF26650%205000mAh%20(Flame)-Capacity
The two batteries tracks very fine.
UltraFire%20UF26650%205000mAh%20(Flame)-CapacityTimeHours
UltraFire%20UF26650%205000mAh%20(Flame)-Energy
It looks like the protection on the B battery trips just before the 5A trace is finished.
The reason the voltage increases, is due to a chain of events: First the protection disconnects the battery, because the voltage now is below the minimum voltage my load disconnects, without any load the protection in the battery reconnects, the voltage is now higher because it is unloaded, I measure the voltage and stops the discharge cycle (All this happens in less than 1 second).
UltraFire%20UF26650%205000mAh%20(Flame)-PowerLoadTime
UltraFire%20UF26650%205000mAh%20(Flame)-TripCurrent
UltraFire%20UF26650%205000mAh%20(Flame)-Charge
Conclusion
These batteries has a good performance for cheap batteries, except for the "low" current limit I do not have anything to complain about.
Notes and links
The batteries was supplied by LightCastle for review.
PyTech
PyTech's picture
Last seen: 2 weeks 1 day ago
Thanks for the review. Seems kinda weird whenever a brand copies another brand’s “trademark” but then again everything is copied in the flashlight world. Seems like it anyway.
-Sean
MRsDNF
MRsDNF's picture
Thanks HKJ. I had 4 Trustfire 26650 turn up yesterday. The wrappers look exactly the same as these from memory. I will have to check the name and make sure there not these.
PyTech
PyTech's picture
That would be kinda weird having Trustfire batts show up with Ultrafire labels. lol
-Sean
