I second that, because I think you’re capable, but also for my own curiosity and the good of the forum
There’s a very easy way to reflow that mtg2 onto the pedestal - turn an aluminum ring w/ ID of the diagonal length of the MTG2 and OD that matches the ID of the pill recess. Set everything in place. heat it up. done.
If you want a potted 9A driver I’m happy to do it for you and I already have one ready to go - just tell me the dimension of the driver recess.
Really? I figured the heat to reflow would unsolder the wires if they were done first. On the MT-G2 I of course cleaned off and re-tinned the pads before mounting it, it was still a pain (and ugly, I like nice smoothly flowed solder, which this most definitely was not). :p
you have to be careful to put the emitter in place right before the heatsink goes below the solder melt temp, then cool it right away…so it can be tricky
but if you used a solder w/ higher melting point for the leads, it should be much easier….
also, w/ the mtg2, there’s enough room to get my 240W soldering gun at those solder points J) , so it might not even be necessary - especially if you do it before the heatsink has completely cooled
What about drilling the center pad for 5-6mm Dia solid copper. If centered in the heat sink, that could be drilled and soldered too. Or mill the heat sink with a 1.6mm high x 5mm Dia post as part of the sink and drop the pcb over that.
I tried to drill one of the Cutter PCBs to do the copper rod riveting thing and failed miserably. There's a layer of something under the pad that ate every drill bit that even got near it. I dissected it with a diamond file (regular file wouldn't touch it) and it seemed like a layer of ceramic. If so, heat transfer on those things has to be abysmal and just about anything else would be a huge improvement.
WOW. Talk about put the pressure on. I have a friendly banter going on with OL to push each other that may sound rude to others. But this? I feel humbled by the expectations off members here. This is really pushing my abilities. Thanks to members here my soldering has improved 10,000 percent but in others eyes is still horrible. The offer off nine amp drivers potted that I marvel at is very generous (I cant think off the right words). Thanks. Rufusbduck I like your thinking as I dont have access to a mill but could possibly do what you have suggested. If you all knew my reputation for wrecking electrical components you would understand my hesitation. I have the led and it cost 20 bucks. Do I risk trashing it with my none electrical abilities and drive it at nine amps? I have a five amp driver ready to go. The host is on its way from the good old USA. Decisions.
Thanks for all the input guys. I have just taken a couple off Bex and heading off for a Nanna nap.
Thanks for talking Chinese to me. I think what your saying that if a 5 amp driver was for a 3 to 4 volt led that delivering 6 volts to a led would drop the current of the driver at the led? Yes I do need help here. Thanks.
I don’t know much about how they work…I just can relay what I’ve tested
It seems some buck drivers still deliver the same current, even with the higher Vf…but others don’t quite make it.
Some drivers, like that 3-18V 5A and the manafont 3T6 driver that we’re discussing in a current page 1 thread, are also designed for use with multiple LEDs in series…so maybe that’s why?
It’s a good idea if your reflector doesn’t interfere. If you are satisfied with having reflector rest on the emitter’s pcb, you should have adequate clearance for your wires. If you decide like I have that the emitter needs to be higher into the reflector, you will probably not have enough clearance because the star’s wire contact pads are almost touching the emitter. The Super Thrower’s reflector is much thinner than my spotlight’s reflector. So you might be lucky.
Thank you MRsDNF. I’m currently working on version 2. No pill will be in it. 3/8” copper post for emitter. The post goes perpendicularly through a 1/2” copper pipe. The 1/2” copper pipe extends out both sides of the spotlight to heat sinks. Very fancy top view diagram below (the “D” is the emitter:
EDIT: Diagram didn’t work. Anyway, the post idea is what I was recommending to you if you have wire clearance issues.
