I'm talking about the SC600 MarkII. I think even the original 600 looks a bit nicer... and frankly I would have gone for deeper reflector in design, but oh well.
I know EXACTLY what you mean about the SC52. I was on the lookout for a good AA/14500 for a while, and tried several. The SC52 always looked a bit odd to me, and I couldn't stomach the price. Until one day I decided I already spent more on AA lights I don't like, so might as well try it.
I got it, and I... I LOVED IT! The size, seeing it for the first time, was a bit of a shock to me. The UI took a bit to get used to, but feels well thought out. On an eneloop it's brighter than any other AA light I have ever seen. On 14500 it's a match to any other 14500 light. And it won't overheat, and steps down when battery is running low!
The SC52 definitely won me over big time... unlike most lights that I would scrap if I wanted to design/upgrade one, on the sc52 only three improvements I would really love to see, and none of them are even a big deal.
So basically, as a result of me getting the SC52, zerbralight is now solidly on my radar, and the SC600II is a must have... ugly or not. Even if I end up hating it (doubtful) I'll consider it a win to try it out, and resell for a few bucks less.
I feel exactly the same, it may not be pretty, but at only 20mm longer than the SC52 and 900 lumens, that’s pretty insane. Flood is more useful to me than throw, so I’m happy with the reflector and the way it outputs its lumens.
I’m glad I’m not the only one who thinks so. I love my two Zebralights, but they sure are ugly. It would help a lot to offer colors other than military drab. However, the functionality is so nice that I consider them my best lights despite how they look. (the RRT01 is a strong contender though — nicer UI for dim modes, and is pretty too)
The SC600 mkII seems to be roughly the same size as a fully-extended SK-68, only with a wider head and no narrow section on the body. I’ve EDC’d a SK-68 before, but I don’t think I’ll be getting a SC600. It’s a bit large for my EDC taste, I don’t like the clip-on clip, I already have other lights for biking (Convoy S3), it’s ugly, it takes way too many clicks to switch between sublevels (like, 14 to 18 clicks to switch between 9 and 27 lumens, or between 0.6 and 0.1), and it seems a bit redundant for me since I already have a SC52 (the SC600 only goes one step brighter, so its main appeal is run time… which the SC52 is already very good at).
However, if they ever fix the UI to allow easier access to all levels, I still might consider getting one. (use 4 level groups (high/med/low/firefly), eliminate the 12 clicks to enter programming mode, eliminate distinction between primary level and sublevel)
I forgot to mention we have the Veleno Designs Quantum D2 on sale for only a week. These are the lowest you will be seeing these prices for a long time.
The Quantum D2 is the successor to the wildly popular Quantum DD, arguably one of the best EDC lights of all time. Powered by a tiny 10180 li-ion battery, the Quantum D2 has a sapphire crystal window with a Cree XP-G2 cool white emitter at its heart. The D2 has an improved light engine and redesigned QTC assembly and magnet placement. The D2 is infinitely variable from 0 to ~150 lumens with a minimum run time of 8 minutes of the highest level. For modders, we also sell a quantum pill package which comes with the pcb board, retaining ring, and magnet.
For everyone waiting on the SC600MKII, we finally got an update from Zebralight after several emails. They told us that we would be a getting some of our inventory the coming week. Again I apologize for the delay as getting more information from them is like extracting teeth.
That was the exact wording in Zebralight's email, I wish I knew what quantity "some" meant. As usual, all pre-orders will be fulfilled in the order they were received.
If you think that’s fun, try getting them to consider a new idea.
(I’ve been trying to convince them to get rid of the 12 clicks required to enter programming mode, and instead just rotate through all sublevels with double clicks… at least on med and low modes, so it’d actually be feasible to switch from 9 to 27 lumens on the new SC600, or switch between 0.6 and 0.1 lumens… among other, less-important changes)
Received my Quantum D2 yesterday - wow!! love this tiny pocket rocket!! i thought the DQG AAA was small - but this is even smaller and MUCH brighter. So tiny and light - goes on my keychain and hardly know it’s there. With the discount Illumination Supply is offering i had to get one. Thanks Calvin! Comes complete with charger and battery (10180). Hurry - I believe the sale is ending very soon.
LED: Cree XM-L Cool White (Norminal CCT 6300K)
User Selectable Levels: 3 main level (High, Medium and Low). Each main level can be configured to one of its two sub-levels.
Light Output
High
H1 900Lm for the first 5 min and then step down to 500Lm (tbd) or
H2 500Lm (tbd) / 270Lm (tbd) / 4Hz Strobe
Medium
M1 90Lm (tbd) or M2 27Lm (tbd) / 9Lm (tbd)
Low
L1 3Lm (tbd) or
L2 0.6Lm (tbd) / 0.1Lm (tbd) / 0.02Lm (tbd)
Runtimes will be tested using ZebraLight ZL631 batteries. Light output are ANSI out the front (OTF) values. All levels are current regulated.
Operating Voltage Range: 2.7V - 4.2V
Battery: One 18650 size (up to 68mm long) 3.6/3.7V Li-ion rechargeable battery. Batteries are not included in the package.
Parasitic Drain: Negligible (much less than the self discharging of batteries)
Beam Type
80 degree spill
10 degree hot spot
Dimensions
Head Diameter: 30 mm
Body Diameter: 25mm
Length: 101.6 mm
Weight
tbd
Features
Battery capacity indicator (LED flashes 1-4 times, 4 short clicks to start)
Lanyard ring
Automatically stepping down from High to Medium, and from Medium to Low when battery capacity is low
Builtin over-discharging protection with 2.7V cutoff
Electronic soft-touch switch
Smart user interface provides fast and easy access to all brightness levels
Precision machined unibody casing from premium grade aluminum
Durable natural hard anodized finish (Type III Class I)
Ultra clear lens with anti-reflection coatings on both sides
Orange peel textured reflector
Battery reverse polarity protection
Pocket clip
Waterproof to IPX7 (2 meters, 30 minutes)
Don’t hold your breath. They haven’t even updated the page for the S6330 yet, and they’ve had three months to get data from production samples.
I’d really like it if Zebralight would pay more attention to their public interfaces, like their web site and their facebook page. Or, basically, be more like IlluminationSupply (and spend the effort to interact with the community). I wonder if their hermit tendencies are a matter of company priorities or if they’re just understaffed.
That's the same as what I posted earlier on Thursday.
[quote=calvinis]
[/quote]
