ARGGGG |(
Maybe you spelled BFL wrong. :bigsmile:
What is LBF*? :P
*Light Budget Forum :D
Just joint and order Nitecore MT1A with “BLF” code, aware of “pricecontrol” code after read this thread, not tested yet.
So thanks to this FBL forum
Do these codes work on all products?
BLF code works and gives 5% off on all battery and flashlight related products.
Only on flashlight and battery related products.
TENOFF gives 5% off all products.
That’s what I said!
I could of swore that you said something different. Oh well!
I thought I heard you say that!
TENOFF gives 5%.
Only in China…
moderator007:TENOFF gives 5%.
Only in China…
It used to be 10% off for real actually…
IndyArcher: moderator007:TENOFF gives 5%.
Only in China…
Yes it did. I found the code searching the web one day. Fasttech reported back to someone, that it was some kind of special code that they had given to someone, that wasn’t suppose to be used by the public. So they kept the code but changed the % amount.
TENOFF worked for my whole order including a couple knives and non flashlight related items
TENOFF can be used instead of BLF.
5% OFF on all products! :)
TENOFF did not work but this did
CPASTE13SPRING
CPASTE13SPRING
Thanks for this! TENOFF is now an invalid code.
arrgghh the tenoff is invalid now…i think sharing a not flashlight related coupon code extensively in public catch FT attention
I wish they would just gives us a 5% off on all products. Some items might not register for BLF but would be used in a flashlight way anyways.
