Oh, ok. Reflow is soldering the LED onto the star board, but using solder paste, and applying heat to melt the solder paste, then the emitter gently sits down in the proper position with a bonded (soldered) connection on the pads of the star board.
So a DRY is a different 3 LED light? I know the DRY driver is an option for a Shocker. Ok - think I understand now, yes, for a repair U3's maybe a good cost effective option then.
My method for removing a star on a heat sink.
Use a strong pair of short needle-nose pliers.
Insert the tips into the u-grooves of the star.
Twist while pushing down just enough to hold the tips in the groves. After a few seconds, the star will let go.
Usually the star is undamaged and can be reused.
Sometimes you may get a small scratch on the pill. Since I sand/lap the pill anyway, this isn’t a big deal for me.
Here are a couple shots of my refector. Best I can do with my iphone. There are a few little ripples, especially close to the LEDS, but obviously not enough to hurt my throw much.
This light is equal to 3 super charged and focused C8's! I love it! The reflectors are a little bigger and deeper than the TK75. Also, if you compare the two, you'll see the TK75's reflectors are missing more of the sides in the middle, where the Shocker's comes towards the top more, more of a complete reflector per LED. Main reason is of course because the diameter of the head is bigger, so the TK75 does great for what it has to work with.
Think if I had a Shocker, I'd be really tempted to take a drill and dremel to the reflector to eliminate some weight, however, it's a great heat sink, and I'm thinking if the center screw was bronze/brass (or alum or copper), it would xfer some heat there. Actually better would be to build up copper or aluminum in the dead center of the pill top, around the screw so you make contact to the reflector - if you get get some serious amount of metal to metal contact to that reflector, you can take advantage of that hugh heat sink.
Did you do any mods to the battery carrier? What batts? Well U3's on SinkPAD's do pretty good, usually little less than XM-L2 U2's from what I've seen/done. I'm regretting not modding the battery carrier..... HHmm, next time. Like Pana PD's in there but they are a little loose, so used magnets, gains maybe 150-200 lumens.
yes . i found the springs had rather weak tension in them so replaced all springs with thick gold plated springs i had purchased a while back from Ric .I use 3 KEEP-POWER 3400 battries. to make them all nice and tight i used a 0.35mm thick heat shrink on them .the texture of the heat shrink is "rubbery" so it seats all 3 battries nicely with zero rattle . The other problem the battrey carrier most likely has is the switch!! I suspect thats what reponsible for the fluctuation in output. i opened the switch up and from what saw this switch is struggling to carry the massive amps this light pulls .
It should be in series, and yes, it is a lot of power. I do not recommend running down to close to cell depletion. Reverse charging could occur quickly.
Thanks for the pics of the reflector, rdrfronty. I think our reflectors are similar. Did you say you tested throw at 13m? I’ll have to try that. I have to find where my lumens are going…
I tested it 15m. I don’t think it needs done quite that far, but I know its a safe range for 99% of all lights, and I have a location in the house that size, so it works well for me.
Yeah I find your results strange. You did get some lumen increase, though not enough. But 3000 lumens in a BTU should be getting you in the 120k’s minimum, and likely into the 130k’s. Weird. So yeah try testing at a few more distances and see what you get. Your reflector might have a few more ripples than mine, but not much more and not enoughI think to create your issue.
