Well. Now I'm certainly regretting not having placed my order earlier.
I'm extremely curious about the SRT7. Will be interesting of it mimics a surefire I saw not so long ago, that also had multiple color LEDs. Hopefully these aren't super cheap and just an add on novelty, but actually bright enough to be useful.
Is there something wrong with me if I go to your store and drool over things I already have? Seriously, you’re making me want to re-buy things instead of just using the items sitting right next to me.
We don't charge for window browsing/bandwidth so feel free to drool over your keyboard all you want. However, we will not be responsible for water damage caused by excessive drool. Perhaps a friend of yours needs to be brought into the light ;)
I can’t get the SC600 MKII to go as low as my SC600w, but it could be a level/programming issue.
I’m using a long press to turn on into low mode, double click to cycle between low and super retarded low. Same on both flash lights, the MKII is a lot brighter on it’s lowest mode. I’m not sure if it’s cause my other SC600 is a w/warm one or not.
It’s the same on my SC600 MKii vs. SC52. The SC52 low-low is like almost invisible. More of a “glow”. Here’s a pic I just took, from right above both lights. SC52 on the right, obviously:
Yikes, that’s as low as it’ll go? You’re long pressing to turn on into low mode, then double clicking for the low low?
If that still doesn’t do it try this:
Long press to turn on into low mode.
Hold the button down and it will cycle between three modes, release the button when it gets to the dimmest setting.
Try double clicking and see if it goes dimmer. If double clicking goes brighter you were already in the lowest mode.
The UI’s are similar, and yes, I tried what you said (which was what I did before), and the SC600 MKii low-low is definitely not as low as the SC52s. Actually, to me, it’s more usable, but I know that some love the almost invisible SC52 low-low :).
BTW, I kind of blinded myself checking this out (always happens :laughing:!
