We don't charge for window browsing/bandwidth so feel free to drool over your keyboard all you want. However, we will not be responsible for water damage caused by excessive drool. Perhaps a friend of yours needs to be brought into the light ;)
I canāt get the SC600 MKII to go as low as my SC600w, but it could be a level/programming issue.
Iām using a long press to turn on into low mode, double click to cycle between low and super retarded low. Same on both flash lights, the MKII is a lot brighter on itās lowest mode. Iām not sure if itās cause my other SC600 is a w/warm one or not.
Itās the same on my SC600 MKii vs. SC52. The SC52 low-low is like almost invisible. More of a āglowā. Hereās a pic I just took, from right above both lights. SC52 on the right, obviously:
Yikes, thatās as low as itāll go? Youāre long pressing to turn on into low mode, then double clicking for the low low?
If that still doesnāt do it try this:
Long press to turn on into low mode.
Hold the button down and it will cycle between three modes, release the button when it gets to the dimmest setting.
Try double clicking and see if it goes dimmer. If double clicking goes brighter you were already in the lowest mode.
The UIās are similar, and yes, I tried what you said (which was what I did before), and the SC600 MKii low-low is definitely not as low as the SC52s. Actually, to me, itās more usable, but I know that some love the almost invisible SC52 low-low :).
BTW, I kind of blinded myself checking this out (always happens :laughing:!
Me too, Iām seeing spots when I blink, I didnāt think holding it down in low mode would cycle to a mode that bright! Whops
Iāll do some ādonāt wake the girlfriend bathroom walksā tonight with my SC600 MKII and see if it passes her āhas to put electrical tape over the alarm clock display because it wakes her up when the numbers changeā test
The SC52 and SC600 Mk II have programmable M2 and L2 (previous models only had programmable H2). Set the light to low (either L1 or L2) and perform 6 double-clicks (12 clicks total). That will put you into programming mode for L2. Double-click to cycle through the available L2 levels. You should be able to get ridiculously low; maybe not quite as low as SC52, but it should be close. Turn the light off to finish programming L2.
Is the default H2 the brightest? Or can you program the H2 to be brighter than the out-of-box H2? Obviously from my questions, Iām more interested in the high than I am in the low-low :)ā¦
