Hi
Anyone help with a driver to run 3 x Cree XM-L’s off 14.4v Li-Ion pack!
looking for any of these options,
1 100,75,50,20-35, strobe
2 100,50, 25-35%, strobe
Cheers
Hi
Cheers
Thanks but this has low modes, need say 2500mAh-3000mAh (100), 1500-1200mAh (50) 1000-600 (35%) Strobe
PWM may be a power saving technique any thought here?
I mean no pwm in the sense that you won't see and hear it like those with pwm, which usually are with very low frequencies and can annoy the user because of that. Anyway, just on option.
Thanks
Below 600mA a triple XM-L struggles on light output! so low modes tend to be useless on most drivers I have seen.
> This is an option, no pwm. (above) is a dead link
Any other suggestions? Distinguish between serial and parallel triples?
One li-ion, preferably. I find I can buy both serial and parallel triple boards, but not sure what drivers to look for.
Sign me — vague on the concept, at the moment
taskled h3flex
der witchel 2.8 buck is also available, http://www.candlepowerforums.com/vb/showthread.php?201981-SSC-P7-Buck-Converter
