Zebralight restocks have taken anywhere from a week to 2 months at the worst. Our best prediction right now is leaning towards earlier.
Our first promotion of the Spring Cleaning sale is expiring soon. EC25/EC25W coupon code "EC25"
Any new sweet deals for us
Got any suggestions?
Mine arrive today! OMFG it’s so much brighter than my SC600w
LICK FOR HIGH RES!
(sorry for the mess, have a track day tomorrow so had to charge my cams and junk)
Love love love this light. I’ll give it a try EDC’ing it but it’s quite a bit bigger than my current edc, the SK68
-Jamie M.
LICK FOR HIGH RES!
(sorry for the mess, have a track day tomorrow so had to charge my cams and junk)Love love love this light. I’ll give it a try EDC’ing it but it’s quite a bit bigger than my current edc, the SK68
-Jamie M.
Can we see a comparison between the SK68, SC600 MkII and a SC52 (if you have one)
Thanks
You mean physical size, or beam shots?
I don’t own SC52, just SK68, SC600w and SC600 MKII
-Jamie M.
lionheart_2281:Can we see a comparison between the SK68, SC600 MkII and a SC52 (if you have one)
-Jamie M.
Size comparison would be good thanks. I see the SK68 in the background, kinda hard to compare though
Is this what you had in mind?
-Jamie M.
How low are the low modes? On the SC52 they are just ridiculous (by that I mean great :D).
I can’t get the SC600 MKII to go as low as my SC600w, but it could be a level/programming issue.
I’m using a long press to turn on into low mode, double click to cycle between low and super retarded low. Same on both flash lights, the MKII is a lot brighter on it’s lowest mode. I’m not sure if it’s cause my other SC600 is a w/warm one or not.
-Jamie M.
infinitusequitas:How low are the low modes? On the SC52 they are just ridiculous (by that I mean great :D).
-Jamie M.
It’s the same on my SC600 MKii vs. SC52. The SC52 low-low is like almost invisible. More of a “glow”. Here’s a pic I just took, from right above both lights. SC52 on the right, obviously:
Yikes, that’s as low as it’ll go? You’re long pressing to turn on into low mode, then double clicking for the low low?
If that still doesn’t do it try this:
Long press to turn on into low mode.
Hold the button down and it will cycle between three modes, release the button when it gets to the dimmest setting.
Try double clicking and see if it goes dimmer. If double clicking goes brighter you were already in the lowest mode.
-Jamie M.
ohaya:It’s the same on my SC600 MKii vs. SC52. The SC52 low-low is like almost invisible. More of a “glow”. Here’s a pic I just took, from right above both lights. SC52 on the right, obviously:
Yikes, that’s as low as it’ll go? Your long pressing to turn on into low mode, then double clicking for the low low?
Try double clicking and see if it goes dimmer. If double clicking goes brighter you were already in the lowest mode.-Jamie M.
Jamie,
The UI’s are similar, and yes, I tried what you said (which was what I did before), and the SC600 MKii low-low is definitely not as low as the SC52s. Actually, to me, it’s more usable, but I know that some love the almost invisible SC52 low-low :).
BTW, I kind of blinded myself checking this out (always happens :laughing:!
Me too, I’m seeing spots when I blink, I didn’t think holding it down in low mode would cycle to a mode that bright! Whops
I’ll do some “don’t wake the girlfriend bathroom walks” tonight with my SC600 MKII and see if it passes her “has to put electrical tape over the alarm clock display because it wakes her up when the numbers change” test
-Jamie M.
ohaya:BTW, I kind of blinded myself checking this out (always happens :laughing:!
-Jamie M.
Well. Just remind yourself that you DID want a BRIGHT light :)…
toysareforboys: ohaya:It’s the same on my SC600 MKii vs. SC52. The SC52 low-low is like almost invisible. More of a “glow”. Here’s a pic I just took, from right above both lights. SC52 on the right, obviously:
Jamie,
The SC52 and SC600 Mk II have programmable M2 and L2 (previous models only had programmable H2). Set the light to low (either L1 or L2) and perform 6 double-clicks (12 clicks total). That will put you into programming mode for L2. Double-click to cycle through the available L2 levels. You should be able to get ridiculously low; maybe not quite as low as SC52, but it should be close. Turn the light off to finish programming L2.
Follow the same procedure to program H2 and M2.
ohaya: toysareforboys: ohaya:It’s the same on my SC600 MKii vs. SC52. The SC52 low-low is like almost invisible. More of a “glow”. Here’s a pic I just took, from right above both lights. SC52 on the right, obviously:
Jamie,
Oh. Just tried it, and there are 3 lows… one lower than the default one and one higher.
Hi,
Is the default H2 the brightest? Or can you program the H2 to be brighter than the out-of-box H2? Obviously from my questions, I’m more interested in the high than I am in the low-low :)…
milkfat:The SC52 and SC600 Mk II have programmable M2 and L2 (previous models only had programmable H2). Set the light to low (either L1 or L2) and perform 6 double-clicks (12 clicks total). That will put you into programming mode for L2. Double-click to cycle through the available L2 levels. You should be able to get ridiculously low; maybe not quite as low as SC52, but it should be close. Turn the light off to finish programming L2.
Hi,
H1 is always the brightest, it puts the light into turbo. H2 is second brightest. I’m not sure about the factory setting. Try it.
OMG you’re awesome! Worked FLAWLESSLY!!!
LICK FOR HIGH RES! (camera make them look brighter than they are, the MKII is super dim, to the human eye looks just slightly brighter than ohaya’s SC52 pic above).
Amazing!!! Loving the MKII now!!! They just need it in a high CRI or at least warm version and I’m done
-Jamie M.
