With Noctigon XM16, XP16, XM20 and XP20 you will get:
-Direct thermal path, no dielectric layer under the thermal path pad
-Flat base (the boards are not bent up towards the edges and the copper has been sanded to eliminate grooves)
–2Oz copper weight (opposed to common 1Oz), lower resistance
-Wide traces, lower resistance
-Lager solder pads for leads (compared to 16mm Chinese boards especially)
-Pads clearance to fit most centering gaskets on the market
-Gold plated copper for long shelf life, easy degreasing, oxidation protection and high resistance against corrosive environment.
Noctigon is a brand fully designed by us which proposes to bring innovative hardworks to the market.
Here’s a photo with the quality control: (Those markers with black have not passed QC.)
Please please PLEASE look into getting something similar made for the monster Cree MT-G2 (and stocking the MT-G2 itself)! There's not even a copper SinkPAD for the MT-G2 (they only have an aluminum version), and currently Cutter in Australia is the only source for the LEDs. Hey, it never hurts to ask, right? :p
