I’d use the same Carclo triple TIR that is used in the XP-G versions. Should work just as well since most of the Carclo Cree optics are made for either XM/XP emitters or for XR emitters. XR optics look like crap on an XM-L but the XP-G optics look great on an XM-L.
I think scaru has a p60 dropin with 3 dedomed xml and the carclo optics…
What will happen we would use a single aspheric? three hotspots? that would be fun…
Thats what I said. He have put it on the page (the one you link to).
But he forgot to add it on the new products page along with the other ones.
At the moment, customers who only check “new products” will not see it…
Do you use soldering paste to reflow leds on the pads? or regular soldering wire will work also!
Last time I did this it was just a led swop (xml2 -> TF X9 emitter) so neither the led or pads was clean, already had solder on them...
I always add just a touch of solder from rosen-core solder wire for electrical components (some brand from Home Depot). Not sure if it is the correct thing to do, but it always works for me. I push down the emitter to push out excess solder
