IS Promotions: Rayus C01 / PT10 Series Intro [8/28]
711 posts / 0 new
ohaya
toysareforboys wrote:
lionheart_2281 wrote:
What’s the silver ring on the SK68? Mine doesn’t have that, maybe why I missed it
The silver ring usually denotes the three mode version (high, low, strobe, memory but starts in next mode :(). I’ve seen a 5 mode one with a blue ring as well.
LICK FOR HIGH RES!
LICK FOR HIGH RES!
LICK FOR HIGH RES!
-Jamie M.
Hi,
I think that the SK68 was originally made by “Sipik”, and all others that make “SK68” are actually “SK68” clones, and that I guess that they can make all kinds of “design” adjustments. For example, I have a silver/gray “Uinfire Sk68” (from FT, and yes, that’s actually the spelling) that looks like a “Fordex” (bought via Amazon). I’ve seen blue ones, green ones, etc., so I guess some manufacturers put that silver band around their version.
lionheart_2281
lionheart_2281's picture
Last seen: 16 hours 47 min ago
Thanks very much for the photo’s and explanation mate
CalvinIS
CalvinIS's picture
Last seen: 2 years 4 months ago
Nitecore SRT 7 pre-order
Estimated arrival, second week of May.
Nitecore's first ring-operated flashlight in a long time, the SRT-7 sports the new XM-L2 Emitter, RGB LEDs, and infinite variability from 0-1000 lumens.
USA based seller of flashlights, batteries, and chargers.
Illumn Webstore
 /// Instagram /// BLF DEAL THREAD
toysareforboys
toysareforboys's picture
Last seen: 2 years 7 months ago
Nitecore’s first ring-operated flashlight in a long time, the SRT-7 sports the new XM-L2 Emitter, RGB LEDs, and infinite variability from 0-1000 lumens.
Maybe I’m totally blind, but nowhere in the description or on the text in the pictures does it say what battery or batteries it takes?
And do you know if the Turbo/960 lumens mode would hold for the full 1hr45mins, or does it step down after a few?
Thanks for all the crazy deals Big Smile
-Jamie M.
picrthis
picrthis's picture
Is this in Black or Military Gray? a discount code Silly
Fenix TK12, TK15, TK21-U2, TK61, TK75 Olight M20S, M21<span style="color: #0000ff;"
picrthis
picrthis's picture
-Jamie M.
Here this should help :bigsmile:
Nitecore SRT7 “Revenger “ LED Flashlight
SRT7 – Revenger , Designed in 40 mm big head style, as well as high output and long throw. Adopted the Generation III magnet ring technology and built-in RGB 3 color outputs, integrating law enforcement warning Signal, strobe, and beacon functions, it is the unique product in the market which is especially suitable for professional users like the military, law enforcement, hunters and flashaholics as well.
Power source: 1 × 18650 battery or 2 x CR123 LED: Cree ML-L U2 Update! The Revenger SRT7 comes with the brand new
Cree XM-L L2, and achieve the 1000 ANSI lumens ! measurements : Head diameter 40 mm Body 25.4 mm length 158 mm Weight 173 grams Activated, the lamp is on one end cap, the selection of the light is achieved using the rotary ring on the lamp head.
There are also built three other LED that can emit red, green, and blue light ! The rotary ring on it, the following lighting levels from left to right ( ie, clockwise ) : Locator Beacons ( short flash as a position light ) Red / blue light ( changing, strobe effect ) blue light green light Red light standby Turning range of 0.01 to around 1000 lumens, infinitely variable turbo strobe
toysareforboys
picrthis wrote:
Power source: 1 × 18650 battery or 2 x CR123 length 158 mm
Thanks Smile
Now, just to find out how/if there is step down, by time or thermal, etc. I’ve found nitecore is very misleading with their advertising when they say things like 960lumens for 1hr45mins Wink
-Jamie M.
InfinitusEquitas
InfinitusEquitas's picture
Last seen: 5 years 10 months ago
BLFUSER doesn't work for the pre-order?
On the one hand, I'm rather excited by this light, on the other hand, given the price point, I'm hesitant to pull the trigger.  Would be the most expensive single 18650 light to date.
Any news on the SC600II Zebralights?
CalvinIS
CalvinIS's picture
picrthis wrote:
Power source: 1 x 18650 battery or 2 x CR123 length 158 mm
Thanks Smile Now, just to find out how/if there is step down, by time or thermal, etc. I've found nitecore is very misleading with their advertising when they say things like 960lumens for 1hr45mins Wink -Jamie M.
Thanks for the help picrthis, information is still very scarce on this model even to us. We'll be updating the listing as we know more. The SRT 7 has an automatic stepdown after 3 minutes on Turbo, but you can reactivate it like previous models.
Sorry, for some reason the BLFUSER code expired yesterday. I have extended the code again sitewide. Currently there are no promotions on this light due to how new it is. We've had an issue doing an intro promo with the TM26 previously.
Our order status shows a second batch of SC600MKIIs shipped but with no tracking number, we're attempting to contact Zebralight again about the status of this package.
Illumn Webstore
ToyKeeper
ToyKeeper's picture
Last seen: 3 days 9 hours ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
I want one. I probably won’t get one due to the size and price, but I still want one. Good item for a xmas/bday list.
It seems like it’s roughly the size of a C8 but much cooler with the control ring, colors, random-speed strobe, and police flasher. However, I think what I really want is more along the lines of a rave light than a tactical light. If it had disco/rave modes and a wider beam and the control ring could also control the speed of a true strobe mode (freeze moving objects in place), I’d be buying one right this minute.
CalvinIS
CalvinIS's picture
Hey guys, I've simplified our main post to make it easier to read and find products. You also do not need to log into our website to check coupon codes anymore Smile
We're recently picked up the Nitecore MH25 which just about completes our line of Nitecore Products. The Nitecore MH25 comes with a Nitecore 2300 mAh 18650 and can be had at a special price with the coupon code: MH25
The MH25 is a two mode flashlight with a programmable second mode. It comes with a micro-usb charger for your charging convenience and a Titanium plated Stainless Steel clip because what's more fashionable than a sleek black flashlight hanging off your favorite belt or out of your pocket? (Or you could use the included holster.)
Illumn Webstore
toysareforboys
CalvinIS wrote:
Hey guys, I’ve simplified our main post to make it easier to read and find products. You also do not need to log into our website to check coupon codes anymore Smile
Wow, first post looks WAY WAY better, nice work Wink
-Jamie M.
InfinitusEquitas
Received my Amytek Barracuda, and chargers yesterday.
For the price it's definitely a steal.  It easily holds its own against the Crelant 7G5CS.
My only gripe is it won't tailstand.  Are there any tailcaps/adapters that would allow it to stand?
mkett39
mkett39's picture
Great deals ..just ordered the EA8 and an I2 charger. Thanks for the deals.
CalvinIS
CalvinIS's picture
We just received official word that the Nitecore SRT7 will come in two colors: Military Grey and Law Enforcement Black. Unfortunately the Grey version will arrive one week after the black. We've adjusted our listings to reflect that. Everyone that has already pre-ordered the SRT7 will receive an email from us so you can specify which color you want.
Illumn Webstore
InfinitusEquitas
Beat you to it... Wink
Anything new on the SRT3?  It's supposed to be 16340/14500/AA compatible using an extender and also with different color LEDs.
CalvinIS
CalvinIS's picture
No official news on the rest of the SRT lineup.
Illumn Webstore
CalvinIS
CalvinIS's picture
Status report from Zebralight finally, they will be receiving a new batch of SC600MKII, SC52, and H502 next week, which means our backorders on those items should be coming in very soon. Again I apologize for the long wait.
Illumn Webstore
InfinitusEquitas
Unexpected delays are a part of doing business.
Did they by any chance mention anything about upgrading the emitters on any of their lights?
I'm a little surprised, the S6330 was released almost the same time (or so it seemed) as the XMLU3, and they updated from U2 to U3 fast.  With the SC600II and the SC52 though, the XML2's have been out for a bit, and no update.
CalvinIS
CalvinIS's picture
There has been no talk about upgraded emitters from Zebralight. On a side note Zebralight has never officially released which emitter they use in their flashlights and I don't expect them to anytime soon.
Illumn Webstore
skyrider1
Last seen: 2 years 10 months ago
CalvinIS wrote:
skyrider1 wrote:
Any update on when those XPG-2s 5000k 3d tint are going to be back in stock?
CREE said 7-8 weeks, however we’re looking at a different source and should have it within a week.
Any update on those XPG-2s?
CalvinIS
CalvinIS's picture
skyrider1 wrote:
CalvinIS wrote:
CREE said 7-8 weeks, however we're looking at a different source and should have it within a week.
Expected arrival date for XP-G2 R5 3D restock is Tuesday based on tracking. SRT7s are also inbound to the USA, slight delay estimated arrival Monday.
Illumn Webstore
picrthis
picrthis's picture
I’d really like to get a SRT7 however I just can’t justify paying MAP or MSRP for it :~
CalvinIS
CalvinIS's picture
The Black SRT7 have arrived! We're shipping out pre-orders today. Also we've decided that if a promotion occurs within a 3 weeks of your order date, we will retroactively refund you the difference Smile
Illumn Webstore
CalvinIS
CalvinIS's picture
Nitecore SRT7 first look. I apologize for the bad audio/noise. First video review, let me know if you have any questions or suggestions.
Illumn Webstore
lionheart_2281
CalvinIS wrote:
Nitecore SRT7 first look. I apologize for the bad audio/noise. First video review, let me know if you have any suggestions.
Awesome video, looks like a great torch
picrthis
picrthis's picture
I hope we see a sale on them soon, I wonder why they used a XM-L2 T6 instead of a XM-L2 U2 ?
djozz
djozz's picture
Last seen: 8 hours 23 min ago
nice fast video, thanks. (I was lured a few weeks ago into 45 *!* minutes video of a new Fenix while my bad developed attention span is 3 minutes at the most)
InfinitusEquitas
Nice, short and to the point mini review!
Any updates on the Gray version, or the Zerbralights?
lionheart_2281
Tint perhaps
