in my country, all are still gen 1. not to mention gen 3, i’m trying to find XX gen 2, zero results. everything is in accordance of whatever gen that they are distributing in singapore.
You can check my test/review of them, I has a temperature probe on them and discharge with up to 10A. I have also tested the XX, but have not published the result yet.
Much hotter, when testing I only have one cell with air around most of it.
I am using my clamp to hold the battery:
And I do not put NiMH into a LiPo sack.
The battery is probably slightly hotter than I measure, because I stop measuring when I stop discharging, but the maximum temperature will first reach the thermo sensor a bit later.
I didn’t realize until just now, reading this thread, that Panasonic acquired Sanyo, and are phasing them out. So my “Sanyo” eneloops are antiques and will be collector’s items in a hundred million years.
I am looking to buy some Eneloop cells for my Quark QP2A and Nitecore EA4w flashlights I have on the way and was wondering if it is worth spending the extra money to buy the higher capacity XX 2500mAh Eneloops over the standard 1500 cycle/2000mAh ones ?
See if you can find Sanyo Harmolattice for a cheap price, they are the same as Pro/XX but don’t come pre-charged. They are sold in many countries across Asia but find their way in to other countries as well (some local eBay sellers sell them here in Australia). You can save a bit of money off the Pro/XX price for the same cells with a different wrapper.
Personally I would only buy them unless I needed the extra run time, if you are going to use it for more than a hour in 1 go on high for example then they might be worth it but if you dont then you can recharge them more often and get more power from the regular eneloops over their life time.
Either will be fine, if you don’t need the long run times then it just comes down to personal preference.
