Does the “DRY 3xCREE XM-L T6 3x18650 Torch Flashlight Host Kit” and the “DRY 3xCREE XM-L T6 Cool White / Warm Tint 3000-Lumen 3x18650 Hi power Flashlight” have the same quality as the SPK?
I have also been trying to decide which SRK I want…or if do I really want one. Love the size,looks and output. So so quality and lack of medium mode are my biggest complaints.
I know the driver could be changed to fix the mode issues but I don’t know what size it takes and I’ve never modded anything.
I’ve almost talked myself into a DRY about 50 times but its ugly and doesn’t have side switch.
Wonder if the DRY driver would fit a king?
I’m trying to do this on a tight budget so I tend to over research things to the point I almost loose interest lol. Wish I could decide soon I want a new light!
Comfychair or someone should give the Aleto SRK lookalike with a handle a go… A nice looking black alternative. If there is a lottery on the typical black SRK kings in that price range one could just gamble on the Aleto…
Just because It have a handle I dont see how it compares to that light. The Apex 5T6 have 5 small reflectors and a much larger head and a reverse clicky. Generally different size.
The Aleto have similar triple reflector like the king and similar size, similar electronic button and for many, a much desired medium mode.
I think it looks nicer and cleaner than a SRK. Despite the handle, which might be annoying on such a small light. Would only take 1 minute to remove it, and not too much work/modding would be needed to make it nice and flat on the back so that it could tail stand.
When all that is said, cant wait to get my Gold 32$ SRK from Wallbuys. But if I could have bought the 40$ Aleto withouth import taxes, I would have gambled on that just to try a different light. If the driver was crap, I could always do a complete rebuild and use the light as a host…
I bought the black XMLU2 cheaper version from Fasttech. First one was DOA and I have just received it’s replacement 2 days ago. Seems to be pretty bright but I have never had one before to compare it with. The threads were fine (needed to be oiled) and switch is tight but the machining on the aluminium bezel is bad ( sharp edges and machining marks) and the lense is very thin, it may not even be glass as advsertised. Definately a lucky dip.
You sure the threads are OK? Unscrew the head about one turn, then lift/push/pull/wiggle the head. Does it flop all around and feel like you could almost pull the head off over the threads if you wiggled it in just the right way?
No, it seems tight. No wiggling at all.
I actually like the light but I havent had it for long so we will see. I am more worried about the lens. It will not last.
I been looking to aquire a black SRK, but with Warm white XM-Ls, Im not having much luck finding any for less than $ 55 bucks. any links or knowledge of where to find one ?
With BLF coupon code it’s even a little cheaper. I got this one, mine is of good quality, only output is probably lower than (good) CW versions, but i definitely prefer a warmer tint so for me it’s worth it, only the lanyard is a cheaper one than in the pictures. recommended
Yeah and all you need to do is build a time machine and go back to a few weeks ago and buy one from before their supplier switched to the cheaper version that looks like it was machined by a drunk 12 year old!
