The star is actually the driver (like in it's smaller brothers). It's fujiked between a retaining ring and body => good for thermal transfer => body gets hot as it should.
Inner diameter: 18.7-19.0mm (from my initial impressions post)
The values above are precise measurements for both of my lights: Black is 19.0mm and the other is 18.7mm.
Yes. It's plastic. But we kind of knew that, because there aren't many glass TIR optics around, especially not in flashlights (as mentioned by djozz here).
I can also confirm the very nice quality of the optics.
Inside diameter of my Ti coloured is also 18.7mm.
The battery tube is exactly 70mm deep and the bottom spring adds at least 1mm.
That titanium (looks green to me) is very nice looking. Are these still available to be ordered?
Yes, they can still be purchased : HERE
Would someone post a couple of beam shots showing off those TIR optics please?
Looks like mine are in town :)!
Edit: What’s weird is that I have two coming in, but they’ve arriving via different routes :)!
Mine flickers a lot and skips modes when twisting it, only solution is to twist it really hard to closed every time I turn it on or change modes.
The threads were gritty and dry, but a little cleaning and grease solved that.
Otherwise it’s got the perfect size, fits the palm of my hand nicely, and it’s brighter and throwier than my SC52 on 14500:s.
My Maratacs or Itp:s are a lot better when it comes to that, smoother and more consistent in their mode-changing.
edit oops… confused with a different light altogether… sorry!
Quick throw figures:
- Olight S20 Baton ~3kcd
- DQG 18650 NW ~4kcd
- DQG 18650 CW ~5kcd(measured at 2m, calculated back to 1m)
Thanks. Not I know I should stay away from all of them
Has anyone been able to confirm the buck only or buck/boost nature of the circuit?
Does it drop out of regulation at a particular input voltage or keep upping it until the 2.5v ‘low voltage protection’ kicks in?
There is no boost and there seems to be no under voltage protection, at around 2.4V input it barely glows.
Tested with lab power supply and long cables and from 3.8V it gives the full ~1.9A on high, I tested up to 4.5V and it was the same current.
I got the XM-L2 version.
Thanks for that. What voltage does it drop below 1.5 amps draw?
Hmm can’t get a stable current reading and tell for sure.
If I try with 3.3V it seems to be to low for 1.5A but it’s fluctuating up and down.
It also seems to warm up very quick which makes forward voltage go down and make it pull more current.
subscribing
I can’t believe this: Been waiting for these for so long, and they arrive at my house today, but REQUIRED SIGNATURE, and no one was home. AARGH! Now I have to wait for another night/day to get them :)!
I so love that when it works… and absolutely hate it when it doesn’t… at least you have a delivery tag… my mailbox had bills in it….
Got mine this morning, from the post office. :bigsmile:
This thing is almost my holy grail of lights.
Almost? How does it compare to your TN31?
