Mine flickers a lot and skips modes when twisting it, only solution is to twist it really hard to closed every time I turn it on or change modes.
The threads were gritty and dry, but a little cleaning and grease solved that.
Otherwise it’s got the perfect size, fits the palm of my hand nicely, and it’s brighter and throwier than my SC52 on 14500:s.
My Maratacs or Itp:s are a lot better when it comes to that, smoother and more consistent in their mode-changing.
There is no boost and there seems to be no under voltage protection, at around 2.4V input it barely glows.
Tested with lab power supply and long cables and from 3.8V it gives the full ~1.9A on high, I tested up to 4.5V and it was the same current.
I got the XM-L2 version.
Hmm can’t get a stable current reading and tell for sure.
If I try with 3.3V it seems to be to low for 1.5A but it’s fluctuating up and down.
It also seems to warm up very quick which makes forward voltage go down and make it pull more current.
I can’t believe this: Been waiting for these for so long, and they arrive at my house today, but REQUIRED SIGNATURE, and no one was home. AARGH! Now I have to wait for another night/day to get them :)!
Assembled length = 9cm
Body is a simple 7cm ano tube closed at the tail.
6 front threads, an O-ring groove, no tailcap.
Some knurls, steps, and a clip groove and clip.
Very light.
4 coil 1cm high spring is jammed into the base.
The head is 2.5cm long, 2 threads screw on SS bezel, O-ring, TIR.
The pill and driver are behind a partition with the LED poking through a hole.
