Match's Mods: Make your own custom flashlight (no lathe!)
+1
cool!
I'd try to keep it that way .I know how nasty copper gets after 3 years of being under the sink with water dripping down the side of it ..I'm not sure about clearcoating it and then heating it and cooling it .
Guess the trick is to do nothing let it tarnish and see how hard it is to spiff it back up to showroom condition again
I think on copper, it's called a "patina" .. don't clearcoat it!!
anyhow, it looks like you had a lot of fun doing this one, gives us a little inspiration I think!
I assume a little polish now and then would let it dull and gain a nice patina with time, the wear points being smoother and shinier than the other parts.
Which now reminds me of the bronze statue of Peter Pan in London's Kensington Gardens. The base is covered with cute forest animals, while the rest of the statue is that dark chocolatey brown you would expect from a bronze - the animals heads are all shiny from a hundred years of children stroking them :)
ALways loved the simple look, such as the F22, and this is simply just right. I just hate the idea that the metal will tarnish. Fingerprints on a more permanent level!! EEEPPP!!
My all time favorite is the original Jetbeam E3P.
Great to hear the non cool whites are coming into fashion! As always, its something that needs to be seen in person before you can really comment on whether you like it or not.
Awesome look Match!
So does the pill assembly/dropin slide down each time the battery is replaced and then it's all pushed back into place when the new battery is inserted?
Just making sure I didn't miss a step.
Thanks.
inspiring as always. i think your mods was one of the first things i seen on BLF.
this is what makes FL DIY awesome. unique, one solid piece of shiny, light emitting goodness. and you can say you made it.
ironically i almost want you to put this on the lathe and shape up some design. not that i dont like it as is too !! GJ !
I love it! What an awesome design!
I like very much that aspect of "only one piece" without screw-able tail-cap and head.
You are right
Great torch Match, It is uncredible you found out how to do it with such common materials.
That is pretty genius, form follows function.
I don't like the orange button though.
just saw this thanks to old lumens linking it. ingenious build.
i think it'd look super cool knurled (technically, you don't HAVE to use a lathe...but you could probably buy a lathe off craigslist for the cost of a hand knurling tool lol). I can just imagine what full knurling would look like after weeks of edc - sort of multicolor probably...
nice job
Hi I want to say that I enjoyed this post so much that I’m planning on starting my own version of this project.
With plans to sell the resulting product, I know there’s no patent or anything but I wanted to let you know.
And thank you for the Idea !
You can solve that by finding a little rubber ring that will fit snugly behind the pill inside the tube — that was the solution for the same problem with M@g AA dropins sliding back out.
Wow what a beauty! I love it!
I’ve always wanted to build a flashlight, but don’t (yet?) own a lathe…
Now, my first build will probably look like this (minus the perfection, plus some beginner mistakes)! :slight_smile:
ever thought about making a few and selling it to your fellow BFLers?
I’m late to the party, but this is a gorgeous light! Might just try one my ownself, my last build of a triple impressed my aunt so much with it’s output she wanted one really bad, and she loves copper. So sometimes certain things just kind of go “click” and that’s that! :slight_smile:
Thanks Match, another great build even if it’s been in the woodwork for a while. :wink:
Match is Mr amazing in more ways than one.
Definitely another to add to my list to do asap!
I like the set screw, but I think it needs a thread able tail cap … Surely there is a tap and die set somewhere around this house…
What do you use to prevent corrosion?
Match has built some amazing lights and this light I believe was to show what you could do without any type of tools that the normal person would not have. He has inspired more people than me to give light building ago with his simple matter of fact way of putting things across.
Here is a link to his posts.
http://budgetlightforum.com/user/313/cmf
